REAL MILK PAINT
Lathe Drive Belt replacement
Jim O
Help - I need to replace the drive belt on my Delta midi (46-250). Per the owner's manual I have removed the handwheel. It is now telling me to remove the wavy washer in order to drive the spindle shaft out. I have no idea how to remove that washer. Can anyone assist? I have called delta, and they have "elevated" my question, not sure when/if I'll get a response. I have also called a local repair center, and struck out there too.
Re: Lathe Drive Belt replacement
Harry in Beautiful Downtown Kulpsville
Jim,
The wavy washer should slip right out. If my recollection is correct nothing holds it in place. Also, in your instruction manual there is an exploded diagram of the parts making up the headstock. That should give you a clear picture of what is in there and how it is located. Hope this helps, Harry
Galen Vetterick
From on line manuals I found the 46-250 does not make reference to a wave spring. Maybe why you have not gotten Delta answer. I see manuals for 46-455 and 46-460 do show a wave spring. It appears to be like my Jet. It should fall off the shaft. I know I found cautions on line saying the wave washer has to set on the right ridge on the shaft or when you put on the handwheel it can pinch the washer and then the shaft end play will never be correct.
I have kept that print out for when I need it.
Maybe your unit has no wave washer?
Jim O
All is well. The diagram in the owners manual was wrong. The wavy washer was actually behind the bearing, so when I drove the shaft out (thru the housing/pulley assembly) the bearing on the left side came loose. When I took it out, the wavy washer was actually behind the bearing, not in front of it like the manual shows. What I thought was the wavy washer (and was trying to remove) was actually part of the bearing. Glad I did not force it. Five minutes later I was back up and working on Christmas presents.
