Jet live center for the tail stock
Carol Reed, Strawberry, AZ
How does the pointed tip come off the darn thing?
Re: Jet live center for the tail stock
Don Orr
Carol,
You can try using the small rod that came with it for holding the rotating part while screwing the cone on & off. Use it like a knockout bar. Or you might need a heavier rod that will fit through. It's just a friction fit like a Morse taper.
You need the long skinny rod that comes with it. Push the skinny end in and knock out the point like you would use the knock out bar to get something out of the headstock. If you don't have that rod simply find a long piece of stiff steel. A thick coat hanger would probably work. Put that in so it touches the point. Then tap on it with a hammer.
Ken Vaughan
Taps out with a small diameter punch -
Many of those tips are MT1 taper and can be interchanged - alas but not all of them. My Jet is in Arizona and I do not arrive there until January so cannot measure.
Doc Green
Carol, I've tried to remove the tip on mine using the little knock-out bar thing, and have had no luck. And I've whacked it pretty good. Gave up when I figured I was about to tear something up. ~Doc
Dave Peebles Lyons, Ohio
If it is the copy of the Oneway, it will pop out with the rod provided. If it is the one on the Jet mini, I am not sure, I replaced it with the Oneway when I first got the lathe. IMHO it is the weak link in a fine lathe.
Happy Holidays,
Dave
Dave Gelnett
Carol I have the same lathe and the same problem the first time I went to remove the point.
I tried the rod which came with it but it started to bend. What I found works the best is the "A" size mandrel or a metal rod the same size. One sharp hit with the hammer and out it will fly.
Also I found that I needed it each time to remove it, that point really fits tight.
is it possible your question was about the cone?
Chuck Jones - West TN
If you are asking about getting the cone off the live center that comes with the the Jet 1642, insert the skinny rod through the holes on the side of the spinning part, hold the rod and unscrew the cone.
If the question is about the one that comes with the Jet mini, then I should have kept quiet... they've already answered it.
Re: Jet live center SUCCESS!
Chuck nailed it, but I had already gotten it off using the information from the previous posts.
Back to making a mess...I mean, turning.
Thanks, everyone.
