diamond grinding wheel
gary clarke
Does anyone know what the comparison grit of 180 diamond wheel is to a regular grinding wheel ? thanks
gary clarke
Re: diamond grinding wheel
Fred Holder
I believe the grits are comparable to regular wheels, they just don't need dressing and don't wear grooves in the wheel from sharpening gouges. I personally use a 360 grit wheel from Andre Martel in Canada. It produces an edge very comparable to a Tormek grinder. I've only had it since the AAW Symposium last year so I don't know how long it will last. Also, I don't turn every day and only sharpen once or twice a week.
robo hippy
If you go to the Australian Woodworking forum, there is a very long thread about the Woodcraft Green River (or whatever their house brand is) diamond wheel. It is 120 grit, with about 1/4 inch of abrasive material bonded to an aluminum hub, and about $150. I haven't tried them, but have been using CBN (cubic boric nitride about $300 each) wheels, which is also on an aluminum hub. Mine came perfectly balanced. The 80 grit wheel I have will give a smoother finish than an aluminum oxide wheel of the same grit. I know 80 grit is 80 grit, but not all abrasives are equal. I had a 360 grit wheel, and it wore out within a year. My 80 grit wheel has lasted 4 or 5 years, can't really remember any more, and still has about half of the abrasive left on it. I now have a 150 grit wheel. The 360 just didn't seem to remove enough steel to refresh the edge, kind of like honing works for a while, but then you eventually have to take it back to the grinder. The 150 is much better for that. I do take the wheels in about once a year for retruing. You can not do it with a diamond dresser because it will eat the diamonds. The diamond wheels are not supposed to need cleaning or retruing ever, some thing which I am skeptical about, but don't have any real experience. Some of the Aussies were using the rubber sticks that you use on sand paper to clean the wheels, and I think some other things were tried. This type of wheel will outlast any aluminum oxide wheel. When I was first investigating getting the ultimate grinding wheel, I heard from a couple of sources that Diamond is fine for carbide, and if you grind steel on them, they will eventually plug up. My DMT bench stones after 15 years do not cut as well as they used to. CBN is made for grinding steel.
robo hippy
Donna Banfield
I have one of the Woodcraft diamond wheels, but it is 180 grit. I only use it to put a fresh edge on my HannesTools, which are sharpened free-hand (no jigs).
The wheel was perfectly balanced right out of the box. Because I have students and other guys in my barn that have a 'heavy hand' when they sharpen, I don't have a wolverine or other set up beneath that wheel. I'm afraid that the pressure they use might 'dish' that aluminum core. And because I only use it to put a fresh edge on my free-hand sharpened tools, I use only light pressure myself. Works just fine for me.
Keith Newton----Little Rock, Arkansas
Gary, I have a Norton 360 I think. It has or had 1/8" x 1/4" on the face of a saucer shape. I have had it for ~ 25 years, and it probably is down to 1/10" thick now. None of the local sharpeners were getting my carbide as sharp as they were when I bought them. I'm sure there will be diamond left when I am gone.
If I were to choose again, I would only go for 1/16" thickness, because this extra thickness makes it hard to get in the gullet of fine blades without risking a snag on the back side.
A Koolmist sprayer is a good companion for diamond wheels, and they are cheap.
Don Geiger
I have one of the diamond wheels available from Woodcraft. You need to realize that you will wear a groove in the center of the wheel fairly rapidly and there is no way to dress it to flatten it back out.
There is only a thin layer of diamond grit on the circumference of the wheel and once you wear through it you toss the wheel out (or recycle it since it is made of aluminum). In fact, you need to stop using the wheel before the groove breaks through to the alumunim or the tool will be jerked downward violently when it contacts the aluminum.
At $140 per wheel,
I don't think it is worth the money unless your tools are made of carbide or some other very hard material that requires diamond to cut it.
Don Geiger
Bill Neddow
Dead on, Don.
The diamond wheels are meant for cutting stone, ceramic and aluminum. They are not good for the high speed or Powdered Metal tools we use. The reason is that the diamond reacts to our high speed steel and, with the addition of even a little heat, starts to carbonize -- break down into carbon. After a while you will see a mist of black around your grinder. That is pure carbon -- and that is what is left of your precious diamond.
Hand held diamond hones (like the Alan Lacer ones) will last a very long time and are OK. But, put the diamond on a bench grinder, and you are in trouble. It will go from 80 to 180 grit -- then to a honing wheel very quickly. You cannot get your money out of them.
I have been through quite a number of diamond wheels including two Wind River wheels, a sintered wheel from a gem supply shop with a quarter inch of diamond on it (don't even ask what that cost), and an Andre Martel wheel. The Martel wheel was the best, but I turned it from an 80 to a 180 grit wheel in a year. The sintered wheel still has lots of diamond on it, but always looks like it needs dressing. The tool steel in my gouges polishes the nickel holding the diamond on. You can clean the wheel easily. In fact, this diamond stone will eat chunks of aluminum oxide the way my daughter's 20-pound cat inhales food. But, one sharpening of a bowl gouge and it starts getting shiny again and loses its edge. I eventually took it off the grinder in frustration and will probably give it to some jewelry maker or stone mason.
I am not against diamond wheels. They are brilliant when used for what they are made to grind. And the industry says loud and clear NOT to use it on tool steel. The industry recommendation is CBM (cubic boron nitride) as robo hippy has discovered.
They cut cleanly and quickly and after a year of hard use, I have not seen one speck of wear in mine. (I now have an 80 grit and a 180). Eventually they will wear but one manufacturer says they will last three times longer than any other wheel -- and I have heard people claim 10 times longer. I will get my money out of them -- and have great pleasure using them. They cut cleanly and easily with very little pressure. They are not yet readily available to wood turners around the world. Peter Child sells them in England and there is at least one retailer for woodturning supplies in North America is now trying to source them for sale. If you are interested, check out metal shops in your area because they use them on a regular basis (though often not in the format we like -- as bench grinding wheels). They are available. If you can't find a local source, I bought mine from Toycen Industries 2353 Ridgecrest Place Ottawa Ontario K1H 7V4 Telephone No. 613 523 7753. e-mail at: toycen@bell.net I have no connection with the company. I am just a satisfied customer. Maybe robo hippy can post the source for his wheels.
Re: borazon grinding wheels
gtwilkins
G'day all,
I found this 6" borazon wheel at:
www.darex.com(remove this)/industrial-drill-bit-sharpeners-and-grinders.html?page=shop.product_details&flypage=flypage.tpl&product_id=767
I don't know anything about this company and still haven't got around to asking for price etc.
Trevor
robo hippy
Mine are made by Northwest Super Abrasives right here in Eugene (541-683-0801). They are a division of Belsaw, which does have several places around the country. I talked to a 3M rep a couple of years back, and he told me that 3M was getting into them. With heavy use, you will get some wear and run out in the wheels, and they need to be trued up again. Easy for me, but maybe more difficult for others. They are cleaned by using some very hard aluminum oxide. I was given a couple of old worn out/too small grinding wheels that use for truing the wheels after they are made. They will eat diamond dressers. Any place that grinds a lot of metal will have a source. Well worth the price.
robo hippy
Don Geiger
Thanks Bill! I think I'll show this my ex wife to prove that someone out there besides me believes I am right about something!
Sounds like you have a lot more experience with the diamond wheels than me. I have three grinders and one has the diamond wheel and I reserve it for the carbide bits I use in my hollowing system.
