Re: First steps in vase or bowl turning
Lyle Jamieson
Hi Craig, There is too many pieces to the turning puzzle to put in this kind of forum. Get some help from your local turning club members or the club library. The DVDs like mine and John Jordan have details on green wood characteristics and handling.
Do not cut the wood up until you are ready to use it. I prefer to take the green tree down to a finished product and it is almost dry by the time I get done turning. It will shrink and take on a character of its own in the drying process, and I like the fact that it will move as it dries. If you turn it relatively thin and uniform wall thickness it will not crack. The reason most people have cracking problems is the crack was already in the wood before they start.
If you want it to be round when you get done then you must turn it dry. But you can not dry a tree or thick piece of log. It will either crack or rot. Then, you need to do a double turning process where you turn a thick walled bowl, dry it for months, and put it back on the lathe when it is dry and turn it back to round and finish the shape.
Then there is the holding methods. I start between centers to rough out and get the grain and color balanced. Then I use a glue block process. A chuck has limitations that I dont want to deal with, many others use chucks. See...what I mean...there is a lot to learn in the beginning. Lyle Jamieson
