Veritas - Innovation in Tools
Oneway Lathe
Oneway Lathe
Oneway Lathe
Lon Erwin
Iam thinking real hard about buying a Oneway 1640 lathe...any comments pro or com that will help me make up my mine?
Re: Oneway Lathe
Re: Oneway Lathe
Don Evans
Oneway is top quality all the way. I was going for the 1640 when a new 2436 became available locally so I went for it. The 16" would have been plenty for me However. I don't see where you would have any regrets with it.
There was no competition when I purchased but now there is also Robust to contend with.
Don
Re: Oneway Lathe
Re: Oneway Lathe
I've turned on Oneway lathes (both the 1640 and the 2436). I like them.
My problem is the tailstock on the 1640. I don't like a #3 MT. I would prefer to have the tailstock have the same MT as the headstock - which is a #2 MT. Other than that, I don't like the price. IMO - there are better "bargains" to be had.
Re: Oneway Lathe
Re: Oneway Lathe
Lon Erwin
what do you mean "better bargains to be had" like what?
Re: Oneway Lathe
Re: Oneway Lathe
Dave Peebles Lyons, Ohio
Hi Lon,
If you are like me, you will not be sorry. I have a 2436 that I have had since around 1996. I have had zero issues with it. It is a dream to turn on.
As for the no 3 morse taper, I think it is a good thing, It is much stronger and, at least with my lathe the live center was included with the lathe. The only other thing I use in the tail stock is a drill chuck. I bought a no. 3 and have been very happy.
There may be better bargains out there, but inho there is not a better lathe.
Go for it!!
Best wishes,
Dave
Re: Oneway Lathe
Re: Oneway Lathe
For roughly $700 less money you can get the Powermatic 3520B. I like it better and have turned on both. I own a 3520A with lots of hours on it with zero problems. You have more swing and if you want to buy the short bed extension you can mount it on the legs and get 30" of swing for those once in a while projects. I'm a fan of the sliding headstock. Standing at the end of the lathe to hollow vessels is much easier on your back. The same is true with hollowing bowls.
Re: Oneway Lathe
Steven Antonucci
I think it has the best bearing quality
steven antonucci
I've turned on most lathes, and the 1640 that we have in the shop at PV is jokingly referred to as "Steve's lathe". I'm not a big fan of how it is laid out, but best bearings on the market. Smoothes out my cut to at least 320 vs. my normal Nova 150-220.
Agree with others that the 3520 might be a better bargain...
S
Re: Oneway Lathe
Re: I think it has the best bearing quality
Lon Erwin
tell me more about how it's "laid out" could be better
Re: Oneway Lathe
Re: Oneway Lathe
Dave in Alaska
I have the 2436. Such a pleasure to turn on. First off, get the highest horsepower option. As for layout, I tried to get used to the swinging arm for the control box. Never really where I wanted it, and when swung all the way to the left, got in the way when cutting on the backside of things like bowls. Finally took the whole thing off and mounted it on a small pedestal on top of the head stock. I fall into that school that doesn't believe in remote switches or movable control boxes. My body remembers where the switch is when I want to turn it off really fast. I don't want to stop to think where the off switch is when the lathe must be turned off right now!
One thing I've noticed reading the posts: There are many posts talking about little problems with this lathe or that. Hardly ever does anyone mention a problem with a Oneway. Nuff said.
Re: Oneway Lathe
Re: Oneway Lathe
robo hippy
When I stepped up from my PM 3520A (I turned on it for 8 years, and did wear out one set of headstock bearings), I chose the Robust American Beauty with a 3 hp motor. I am a fan of the sliding headstock. The only Oneway I have turned on is their 12 inch lathe, which for some reason, even on the slow speed range seemed woefully underpowered compared to other 1 hp lathes I have turned on. If you want a 16 inch lathe, do check out the Robust models. I believe the Sweet 16 is the one that has the sliding headstock. It may not be better than a Oneway, but there is nothing better out there. It is also made in the USA.
robo hippy
Re: Oneway Lathe
Bill Blasic
Re: Oneway Lathe
Bill Blasic
I would not begin to say that the Oneway is inferior in any way and is surely superbly built. But for myself I like the feel of cast iron, just do. 3520b or a Vicmarc would also be good choices as would the DVR XP with the cast iron leg set.
Bill
Re: Oneway Lathe
I Love Mine
Barbara Gill
I have had it for I think at least 6 years and would not change a thing. I also have the outboard bed extension. The lathe is a joy to use.
I made sure I left room between the lathe and the back wall so I had room to use both sides of the lathe. So far I have been able to turn anything I wanted to turn (size).
Re: Oneway Lathe
Re: Oneway Lathe
I like the Powermatic 3520B. I also like the Jet 1642 EVS (2 hp or 1.5 hp). The Laguna Platinum 18/47 is a reasonable lathe.
It all depends on what you are turning. Mostly spindles or mostly bowls. If bowls - the 3520B.
I just can't see spending over $4000 for a lathe when I can get a Powermatic or a Jet for less. I like Oneway. I have their chucks, the Wolverine, etc. I've turned on their lathes. I'm just not willing to spend that much money on a lathe when I can get reasonable quality for less.
Re: Oneway Lathe
Re: Oneway Lathe
Barbara Gill
I too really like the #3 MT tailstock.
Re: Oneway Lathe
Jim in Burlington Ont.
Made in.....
Jim in River Oaks, Ont.
I'm a fan, one day. I was up in Stratford Ont a few years ago, had a great tour with the plant manager, he was nice enough to make room in his day for me. That day most of the production was around the seated version of their lathe, it was so nice to see it coming together.
Sweet lathe for sure, maybe I need to add a third, my pen production has hit a peak this year....
Take care,
Jim
Re: Oneway Lathe
Re: I Love Mine
Mac Ray
I've had my 24/36 for 12 or more years,wouldn't swap it for anything out there....not one problem with it....The CFC school has 12 16/40's,8 or so years now,no problems with them......it's a matter of personal choice,just buy what you like,can afford,and be happy with it......
Re: Oneway Lathe
Re: Made in.....
Joe Dickason
I am a tool & die maker by trade. I feel that I know something about machinery. (not as much about turning) I have a 2036 (serial # 9) Just a real sweet machine. Have had absolutely no problems. Also own a lot of their accessories. They understand quality. Real point. Oneway customer service. I sent an e-mail asking about touch up paint. The next thing I knew I received a bottle in the mail with an invoice---"no charge" Not a big deal, but it shows me that they certainly understand customer service.
Re: Oneway Lathe
Steven Antonucci
It's a very "pokey" lathe
steven antonucci
I think that a lot of my issues with it the Oneway Lathes revolve around how I cut. I tend to use the handles very low to get a good shear angle and locked against my body. The often hits the ways, the banjo, the locking handles on the banjo and toolrest...and I end up getting a lot of handles poking me in the lower abdomen.
I end up having to adapt how I stand at the lathe when I am in the PV shop vs. how I would work in my own. I have a habit of sliding a tool under the ways when I am done with it, but the Oneway ways is round, so it's not really practical to do that (they balance if you are careful, but on my Nova it's just like a shelf)
Lastly, if you are used to doing things one handed, forget it. Every knob, handle or lever on a Oneway is so precisely machined that it will lock whatever it is connected to down like it was welded. You have to use two hands to do everything.
So there you have it. Handles poking me, and it slows me down at the lathe. Pokey.
S
Re: Oneway Lathe
Keith Tompkins
Re: Oneway Lathe
Keith Tompkins
If I were in the market for a new lathe, I'd consider both the Robust and the Oneway. I've turned on the Oneways for years; a couple of things I would change. The handle for tightening the tool rest is situated right in the front, rather than off to the side as on most lathes. That bugs the heck out of me. If you turn with the tool handle level, it's no problem, but if you turn with the handle angled downward, it's a real pain. Rotating the base helps, so it's not the end of the world. I've yet to turn on a Robust, but it's surely impressive.
Re: Oneway Lathe
Re: It's a very "pokey" lathe
Barbara Gill
I rarely have to use two hands to disengage the banjo, etc. It is simple, don't use so much force to lock it down.
Re: Oneway Lathe
Re: Oneway Lathe
Coyne
I have had my 2436 Oneway (3HP, stainless steel ways, tail swinger) about five years. After having been frugal (tight) all my life, I went all the way because I knew it was the last lathe I would buy. It is a REAL pleasure. It is more than just a tool for me, it is my friend (though I haven't started talking to it yet). Everytime I walk into the shop I get pleasure out of just seeing it sitting there. I am thankful for my 2436 this Thanksgiving day.
Re: Oneway Lathe
Steven Antonucci
It's not me...
steven antonucci
Since it is a shared space, I find that other folks who use the equipment tend to be a little ham-handed... Once someone torques it down, it's down and a two-handed operation.
S
Re: Oneway Lathe
Re: Oneway Lathe
Jennifer Indy.USA
Keith, I am in total agreement with you on this. It drives me nuts. When I mention it to other people they look at me like "what are you talking about"? On our 2036 I've also discovered that if I use a round rod type rest I have a difficult time getting it close enough to some of the small work I do because the banjo won't go in close enough. I need to hunt down a different small rest that will work better. The Robust is probably a good choice. Other than that, it's a beautiful lathe :)
Re: Oneway Lathe
Re: Oneway Lathe
Barry
Then, why would you spend that much money on a Jet or Powermatic when you can get a Grizzly or a Craftsman for even less than that? Instead of bargain hunting, consider going value hunting.
Re: Oneway Lathe
Re: Oneway Lathe
Barry
I have not turned on a Oneway 1224, but I watched a demo on one. There was an awful lot of vibration coming from the sheet metal cabinet. I like the lathe itself.
