Safety reminder
Safety reminder
Safety reminder
Carole Valentine
Noticed in another thread where someone mentioned something about leaving the air compressor on when they left the shop. This is one thing I ALWAYS try to check...I have even put a sign at the shop door "TURN OFF COMPRESSOR!" I throw the breaker switch. I once had a pipe crack which meant the tank never filled so the compressor was running continuously. By the time I discovered it the thing was hot as a firecracker and starting to smell. I have no doubt that had I not discovered it when I did, it would have soon started a fire. I would have to assume that maybe some compressors have a sensor that will shut them off if they overheat...but my Husky does not. Just something to be aware of.
Re: Safety reminder
Re: Safety reminder
Brian George
That is a major notice. Thank You!
I will be making a sign to post on my door yet tonight.
Again, Thank You...
Re: Safety reminder
Re: Safety reminder
Don Evans
That is good advise Carole.
It should be noted that you should NOT turn off the breaker switch while the compressor is running. Most that I am familiar with will NOT bleed the pressure off the pistons if the breaker is thrown will running.
In an emergency such as you had that doesn't matter of course, throw the breaker, I'm talking about routine shutting down of shop when leaving it.
I have a set pattern when I leave the shop that goes like this:
make sure back door is locked
check shut off ball valve on compressor output
turn off 2 breakers, one is compressor/other is cyclone dust collector (because it is remote controlled)
turn off all lights
lock front door as I leave through it.
Those that have the remote collector controllers should be aware what an stray signal could make it come on
Don
Re: Safety reminder
Re: Safety reminder
bill Crommett
An additional concern: To those who have been un-cautious enough to plumb your compressed air with PVC. Consider what would happen if a small spark had started a fire under a PVC line that was charged with air from an ON compressor. The PVC would melt and the result would be a blow torch fanning the blaze. Even a daytime coffee break would be a disaster.
Re: Safety reminder
Re: Safety reminder
Carole Valentine
Good point Don. I never throw the breaker while the compressor is running. I could just go into the room and turn it off or unplug it when I leave the shop, but the panel is much more convenient to get to. Don't have any remotes except the air cleaner.
Re: Safety reminder
Re: Safety reminder
jwoodwright
I always unplug the compressor at night. I unhook and coil the hose and "test" the emergency valve. Then I open the petcock. This drains all the moisture out. Darn thing spits and sputters for a couple minutes...
Re: Safety reminder
Dick Hines
Re: Safety reminder
Dick Hines
I went away for the weekend and forgot and left my compresser on. When I got home I heard the compresser running. Called my self a STUPID A** fro not checking.
When I went in the shop to turn it off I noticed it was HOT. The belt that runs the piston had broken and it could not fill the tank.
I have idea how long it had been running. If the belt broke as I was leaving it ran form Friday at around 6Pm until Sunday at 5PM.
I don't leave anything on when I leave home now. Even to run to the store for a paper.
Re: Safety reminder
Re: Safety reminder
Bill McWhirter
I also do not like leaving my shop with the compressor turned on.
Since I enjoy playing with electricity, I wired a light socket into the circuit controlling my compressor.
Anytime that the compressor circuit is hot, there is a 75 watt red light bulb that is also on. It is much harder to ignore than a sign.
Re: Safety reminder
Re: Safety reminder
Chuck Engstrom
A welcome post since I am currently involved in helping a friend install a new 60-gallon compressor. I admit I hadn't thought much, if at all, about the issues you raise but I'll be sure to incorporate them. Thanks!
--Chuck
Re: Safety reminder
Re: Safety reminder
Wayne Kuhn
PVC should not be used for compressed air. Should it be compromised it blow apart in very sharp shards. Copper or steel will just split and decompress.
Wayne
