I'm bowling it up
I'm bowling it up
karl jr
I'm bowling it up
karl jr
MY BOWL BLOG
By Karl Taylor Kulp Jr.
I got a commission to turn 22 NE bowls. I have some thoughts about this undertaking, and I figured it might be beneficial if I took some notes. Then I had the idea to blog it. I'll post it on my website if I ever get it finished. (In another day and age I would write it in my diary, by candle light. But then I wouldn't be able to get comments from the folks at WC.)
Here are a couple of thoughts I've had:
1) Consumable materials (e.g. sand paper, finish, beer ;) ) cost twice as much as what you've budgeted.
2) Errands, defined as things you have to do to get the job done, take at least twice as long as you think they will.
3) It takes longer than you think it does to turn a chunk of wood into a bowl. Time flies when you're having fun :D
4) Efficiency speeds things up. I can increase my production rate by using a curved furniture scraper and not hand sanding. (I stold a page out of someones book here.) Green wood cuts fast and clean and I don't have to spend hours searching for little bits of bark that fly off.
5) Do not ignore your supply chain. Even though the stuff grows on trees, unlike money (see note 1), you've still got to find it. And go get it. (See note 2.)
6) The customer may not know exactly how many they want. Expect a smaller order but plan for a bigger one. (See notes 1-5.)
7) Even though the bowl didn't blow up while on the lathe, it might still be a clunker and shoud go in the firewood pile. :)
8) Do more than required. Make more (see note 7). Get a better cut surface. Pay more attention to the finish.
Thats the story so far. Oh yeah, I should say that my customer wants 35 bowls now, not 22. Time is getting tight. Fortunately, I found a fresh cut elm tree this afternoon, so I've got wood. (See notes 2, and 4-6.)
I spent the afternoon with my nieces and got my fingernails done in red with a sparkly top coat :-)
PS the smileys have infested this post :O
KTK
Re: I'm bowling it up
Bill Neddow
Karl, you have really summed this up beautifully. I agree with everything except getting my fingernails painted red -- my wife would probably faint, thinking I had mangled myself again.
Mac Ray
Pics,we need pics......of the fingernails............
Barry L Elder
And why would you shortchange nieces and not let them "DO" your toenails too?!!! :D
karl jr
karl jr
I had to draw the line somewhere. If I had gone in for a pedicure as well as the manicure, where would it stop? I'd have gone home with matching red eyeshadow (with glittery eyelashes), rouge, AND lipstick!
Here's a small update on my bowl turning project.
Using cabinet scrapers has greatly improved the final surfaces. Both inside and out. It's also reduced the time I spend sanding. However, It isn't as much as a time saver as I thought it might be. Since I'm getting a nicer surface, quicker, I spend more time looking for very small flaws, and fixing those. Turns out its more of a trade-off than an outright efficiency boost. That is to say, add a step to the process, spend a little less time on another step, but get a better final result.
I sure am lucky I found that elm tree where and when I did. Only two blocks away and just in time. The material I had in the pile had just sat around for too long to be used for NE bowls with any hope of the bark staying on. I might get away with that on some cherry I have, but the chances are pretty good that even if it survives the turning, it will peel away afterwards.
I keep telling myself I can do at least one more per day. Especially after having seen a couple demos in which a real thin NE bowl is turned in a tiny fraction of the time it takes me. Of course the demonstrators have an order of magnitude more experience than I do. And, they actually know what they're doing! ;)
When the cleint incresed the order by almost 50%, I should have tried to extend the deadline. At least a little bit, just enough to give myself some breathing room. I think I should have asked for an increase in the price for any bowls made in excess of the original number.
KTK
Harry in Beautiful Downtown Kulpsville
Karl,
If you want to see efficiency in bowl turning, take a look at Glenn Lucas' videos on YouTube. (Just search on his name.) This guy is in Ireland and makes bowls in batches in the hundreds. He has fine-tuned the process in a number of ways and still puts out a fine product. Worth a look.
karl jr
Just watched the Glenn Lucas vids
karl jr
Gadzooks! That guy is fast! No messin' around there.
Thanks Harry.
KTK
karl jr
karl jr
Thanks again for steering me to those videos, Harry.
Between bowls this afternoon I watched them. Going back to the lathe afterwards, I tried to use as much of my big gouge as possible. The grind I have on it won't do as big a cut as he uses, but I did use all of it. Probably cut down on the number of cuts by half (or more). Even so, the finish cut was probably better than I've done so far.
The tool marks and little bumps in the profile scraped out with a couple of passes. The finish cut was good enough that I started considering not sanding at all. Now I'm thinking of not sanding during the turning process at all. It's a pain sanding wet wood. I'll just end up sanding again anyway. I might save a bunch of time by sanding (and/or scraping) and finishing in batches.
Another benefit of those big cuts was that I didn't need to resharpen nearly as often.
With a few time savers like that I can probably get this job done :)
KTK
