If you dig down under the recently felled Maple at the Jordon's you will find that the sea bead many millions of years ago came to their front door /As the oceans evaporated they left behind many echinoderms .How this one survived intact with all those roots reaching out for the water is any ones guess
I had to make about 6 prototypes before I could finally risk my last piece of maple from the stash sent to me
Had me beat for a while but finally got there
Turned similar to my winged vessels
Some would say why not carve it well I am a turner and I could
My head just couldn't figure how to blend it all together
The color I used some oxide watered down and then blew off while wet with an air gun at 100 psI
The texturing on the spikes took an age as I made up a sharp needle then with a burner dot dot dot dot and more dot dot dot
I turned a spigot on top and bottom then hollowed through the spigot so then that spigot could be used to hollow through the other
I took this piece into our club last night I was quite chuffed as many ah's and oo's were herd And also some other words which are not repeatable here
Know that I have it sorted I plane on doing a big one this is 6 or 7 inches across the spikes
Mark out the starfish shape cut out on the band saw then turn the spikes and shape them
Next I turned the inside by holding on a spigot top and bottom
First I drilled a hole right through
The wall thickness was gauged with the fingernail tap test (hence 6 prototypes went though into the void between the spikes 3 times the other 3 I lost the wings as they snapped off were the grain ran across the points
Sort of a Allan Mallard turning to start
Being able to bend my mini Kelton Hollowers helped remembering to get the shavings out every couple of seconds was a trick
turning cross grain helped as the scraping action chipped out small pieces
Then with a sharpen of the tool I manged to get a very smooth finish inside
Important as this may well be kept to go into the Royal Easter show and the judges will have torches and mirrors out
Well I better get out and finish the Waka I am making
your turning always amazes me. I barely feel adequite to respond to your works. IMHO you've transcended your media. The air up there must be pretty thin, seeing as so few people achieve that level.
Sorry that that sounds like pandering, but it's all true.
