potential hazards of being a woodturner?
Steven Antonucci
steven antonucci
Dick brought up the posibilities of getting burned or shocked by the battery charger burner, and I thought abut getting burned, bur never really about getting a shock?
What other hidden dangers have you been exposed to?
Steven
Re: potential hazards of being a woodturner?
Rob Wallace
Rob Wallace
My collection of body-damaging "stupidisms":
1. Getting a tool slammed into the tool rest and crushing a finger because I touched the rotating wood first, not anchoring the tool first. Fingers are more malleable than steel.
2. Banged-up hands from rotating chucks. Interesting collection of nicked and torn-out little chunks of skin.
3. An extremely clean cut on my right ring finger from my meticulously sharpened 1-3/8" Lacer skew as I was putting it away in my tool roll. (I now always carry first-aid equipment whenever I do demos because of this experience. Also carry CA glue for a field expedient suture!)
4. Face-mask recipient of a large piece of Russian Olive bowl blank (about 11" diameter x 5" thick) as it came apart during roughing due to excessive wind-shake. (Thanks goodness I wear a full-face shield, and always will.)
5. Use of a spindle roughing gouge on a bowl blank (during my "self-taught" phase, about 20 years ago), going out too far over the rest, and getting a bad catch - I really bent, but didn't break the tool. A helpful scare to do more technique learning than 'just doing'.
6. Various episodes of 'finger roasting' while hand sanding.
7. Getting burned and raising a blister when a drop of CA glue was on my finger (unknown to me) and was accidentally sprayed with accelerator - talk about exothermic - my finger was actually smoking! Between the cusswords, I managed to grab my spray bottle of water to reduce the heat. (I wish I had footage of that episode - it reminds me of the cigar-lighting scene in Young Frankenstein) Fortunately, I've never glued any body parts together!
8. My latest, and perhaps stupidist: Kerfed the fleshy part of my left thumb on a table saw (1/8" kerf, 3/16" deep) while cutting thin stock on the tablesaw (I wasn't woodturning then - maybe that's the problem?)
I probably have more, but these are experiences to learn from. I did - the hard way.
Rob Wallace
Well let's see. I've dropped a skew and had it stick in the arch of my foot. I was cleaning around the lathe and started to stand up hit my head on the tool rest banjo of my powermatic. Had to sit down for a minute and let the stars go away.
I don't know what it is about extension cords but when you wrap them around your arm the last 3 feet have a tendency to want to fly between your legs, rapidly and painfully.
Splinters, lord are there splinters. Clay Foster left me a piece of a railroad tie from Africa. If I get within 3 feet of that thing I'll get a splinter. Purple heart is even worse.
I tend to put really crisp (read that as sharp) details in some of my pieces. I've been slice open several times by these.
Talk about burned. How many times have you put 600 grit paper to a piece that is spinning too fast. I don't believe copper pipe will transmit heat any faster than that piece of paper. Ouch.
Are they hidden...............
Tom Collins
or just overlooked/ignored. I think Rob's use of "stupidism" is more accurate. I've had too many to list not only in woodturning but throughout life. It's a wonder I'm still alive!
TomC
Re: Are they hidden...............
Galen Vetterick
I agree with Tom. It always becomes VERY obvious after my accidents that they were set to happen. At least over life I have learned from each one as I have never repeated the same accident. SIMILAR but never the SAME!
Frederick Nelson
Besides the hazards posed by various "stupidisms" as mentioned, there are less obvious hazards as well.
Inhalation hazards of just about any kind of wood dust or finish vapors. Wood particles in a certain size range, from about five microns down to just below one micron tends to get caught in the lungs. Organic solvents from most finishes are things you don't wnat to breathe under any circumstances, yet you can't really avoid them during woodturning.
Contact or inhalation hazards of specific types of "exotic" (and not so "exotic" as well) woods producing allergic reactions. The more insidious of these don't appear immediately upon first exposure, but rather develop over multiple exposures.
Woodturning (or any kind of woodworking, for that matter) is potentially quite hazardous, but recognizing the risks, then devising methods for dealing with the risks safely can make the pasttime as enjoyable as it is.
Fred
respecting the bandsaw (and a lot of other tools) in Eastern Missouri
Steve Kubien
Steve Kubien
I've managed to cut myself on the rim of a spinning bowl-to-be.
Chuck Jones - West TN
My most horrifying event...
Buying too many tools that I obviously did not need and leaving the invoice where my wife could see it.
robo hippy
I did learn from another turner to round over my rims, so no major damage there. I have gotten some skin peeled back from spindle sanding with the tool rest too close, and getting sucked in. I got 4 stitches from a dull bandsaw blade. I got one horse shoe shaped cut on one leg from a gouge that fell on the floor. Landed on the handle, and slowly fell into my leg. Yes, it was sharp. I am sure there were others.
robo hippy
Nikos
I agree with all the physical hazards listed thus far.
I would like to add a psychological hazard: addiction.
Ralph Lindberg
nice listing, seen a few already posted that I've done :) A few I can't top :D , but i do have one that may be unique.
I store my spindle gouges, point down, on the back of the lathe stand. I used to store my carbon paper in the stand just on the back side of the lathe.
One time I was bending down to get some and backed up too much before I started standing up.
Did I mention that I had just sharped the gouges? >(
Dick Hines
Dick Hines
I got my thumb to close to a muiti axis piece and peeled a big hunk of meat back like a door. Lots of bolld and pain for a couple of days
Worse than that was last week my wedding band came up missing. I had to take a 40 gal bag of chips and spread them all over the shop to find it.
That could have caused a lot more pain than the bloody thumb.
OOoooh that's a nightmare
The Worst of the Worst
Tom Collins
Steven Antonucci
Nobody's ever turned barefoot, huh?
steven antonucci
Yeah, I used to once in a while... Aside from learning the skew-two-step (the little dance you do when you drop a tool to avoid being impaled), you also tend to find all of the bits of wood that landed pointy-side up with the soft, flesh instep.
If you have ever mounted metal on your lathe, you find all of these blackspots in your hands the next day. For whatever reason, they don't get infected like the wooden splinters, but I usually find 3-4 of them if I've been anywhere near metal on the lathe.
I also watched a guy demonstrate hollow turning once, and my Spidey sense was tingling the whole time, so I stayed back. He got a catch, and the tool went flying when he just let go ("See ya guys! Good luck with that!). It was like slow motion watching everyone scatter like cockroaches when the lights come on. Nobody ever found the tool either...
S
Paul Zerjay
Try doing it for a living. You'll find out how hazardous it can be to your financial well being.
karl jr
My dumb moves
karl jr
Last year I broke a finger turning a NE bowl, using an overhand grip with my fingers splayed a little bit. When a first started turning and didn't grasp the importance of securely holding the wood, a got ambitiuous with a 40 lb., off-balance chunk between centers. Got a catch and the wood hopped of the lathe and landed on a toe. I didn't break that digit, but I limped around for over two weeks. The usual skunned up knuckles and slices from razor sharp bowl rims.
KTK
5 down and 17 to go
Re: karl, what are you doing on WC????
Donna Banfield
You've got a commission to turn NE bowls....
Get yourself back in that shop, mister! :^)
Cowboy Proverb
Al Kapocius
Kinda reminds me of the old cowboy proverb; Was never a horse that couldn't be rode or never a cowboy that couldn't be throwed.
For woodturners: Was never a bowl that couldn't be throwed . . . .
Al Kapocius
karl jr
Yes'm
karl jr
charlie belden
Sanding underside of ovehaniging rim of a bowl - sand paper held by finger. Now I use a curved hemostat to hold the paper.
Sanding the inside bottom of a small lidded box - see above - not use dowel with foam on the end and sanpaper on it.
Multi-center turning - discover that the shadow area will wack the crap out of your knuckles.
Bench chisel rolling off a bench - tried to catch it before it hit the concrete floor. Only did that ONCE.
After reshaping a gouge didn't realize how hot it had gotten and went to use it immediately. NOT A GOOD IDEA.
Leaning over the lathe for extended periods of time while hollowing. BENDING AND TWISTING NOT GOOD FOR LOWER BACK!
Don at Central Illinois
I never repeat the same mistake twice, I always come up with new mistakes to make.
Still healing...
Tommy Holmes in NW FL
from the shadow of a square platter taking off my fingernail and broke the bone in my finger.
charlie belden
There's a significant difference between stupid and ignorant. Knowledge cures ignorant. There is no cure for stupid.
