Wood Vaporizer help-Thank You
Galen Vetterick
My thanks to Bill T, Carol R, Charlie B, and Steve A for their input 10/26 on building a wood vaporizer from a battery charger. I finally got around to finishing it and now get to learn how to use it and make tips.
I see now why it is called a wood vaporizer and not a burner after only a few minutes of testing.
I set my unit up so I can switch from burner and back to a battery charger with the flip of a switch and pluging in the leads desired. I need to work on a better burning handle after some more playing.
Thanks again!
Sorry about picture quality but pictures are just setting parts on my computer chair to put in my files.
Re: Wood Vaporizer help-Thank You
Steven Antonucci
I like yours better than mine!
steven antonucci
A good idea just keeps getting better!
Steve
P.S. If the wood isn't squeaking, you haven't reached your full potential yet!
Yes, sound on first testing made me jump!
Galen Vetterick
That's not a good thing with that hot pen in your hand!
I'm not sure the leather apron I have seen Molly wear would save your hide if you dropped the pen in your lap!
Dick Hines
Re: Yes, sound on first testing made me jump!
Dick Hines
One of these days someone is going to get lit up like a Christmas tree with one of these things
Steven Antonucci
Can you get a shock?
steven antonucci
I know that when current is flowing, I'm more worried about burns than shock...so can you actually get a shock?
Anyone know?
Steve
Re: Can you get a shock?
charlie belden
As long as you don't touch bare wire, since you're not apt to grab the glowing hot part, you're OK. People have been connecting battery chargers to batteries for a long time and I don't recall anyone ever being electrocuted by one. I have heard of people being injured by batteries that blew up. Lead acid batteries do produce hydrogen gas when being charged - and that gas will go BOOM when exposed to a spark.
Very low on my possible ways to meet demise.
Galen Vetterick
Dick Hines
Re: Very low on my possible ways to meet demise.
Dick Hines
I thought is that there people out there that will try to make one of the burners that don't have the brains to screw in a light bulb.
Can you say "krispie Kritters?"
Doc Green
It takes about 30 V to produce the sensation of a "shock" when the voltage is applied between the tips of two fingers; for example, by touching two terminals with the tips of your first and second fingers. But this depends strongly on whether your fingers are dry, sweaty, callused, covered with dry sawdust, and so forth.
The output of a battery charger is probably 15 V or less so there is practically zero risk of getting a serious shock from the output terminals of the charger.
I believe the greater hazard is a burn or, during construction, accidental contact with the 120V line that delivers power to the unit. Another serious possibility is for a wiring error or a stray wire to accidentally apply the 120V hot wire voltage to the output terminals. In this case, simultaneous contact with one of the output terminals and a grounded object would give you a potentially serious shock.
My thought is that if you aren't knowledgeable about things electrical, get help from someone who is.
My $0.02. ~Doc
We are having to use the battery charger each time we get ready to start the lawnmower. I figure I'll fix whatever it is this winter. Anyway, I have metal fence around the inside of my deck to keep the dog from jumping through the deck and escaping. My son had attached the leads of the charger to the fence unbeknownst (probably not a word but sounds good) to me. My charger doesn't have an on and off switch. I plugged it in and went around to connect it. I grabbed the fence and got a shock. It was just a gentle sort of buzz and since I hadn't had any excitement in a while I hung on for a bit. That is apparently all the shock you get from my charger.
Dick Hines
Dick Hines
John, you must not have grown up in the country. You find out at an early age not to pee on a electric fence.
As far as the burner. The trouble is there is some rewireing, on the plans I have, that have to be done in side the charger. That is where a mistake could be made.
Dick worked on the farm during the summers. Never pee'd on the fence, I new better. However I did walk under a wire one time and didn't duck low enough. That got my attention.
Chuck Jones - West TN
Try this for a thrill.
But not unless someone is there to turn the thing off fast.
If you walk up to a fence electrified that way (continuously) and grab a good hold with your hands around the wire you cannot let go. Trust me on this one. I've been there and done that. Your nerves tell the muscles to contract and the more they contract the more electricity you get, etc. etc. That's why all modern fence chargers pulse. Gives you a chance to decide you don't really want that much thrill.
Walk under a wire?
Galen Vetterick
John you must have long legged cows in your part of the country to walk under an electric fence. Maybe you mean some other type live wire?
I was more worried about stepping over the wire and what might get zapped.
Re: Walk under a wire?
This was a wire that ran from the barn to the fence. It went at an angle and was easy to walk under if you stayed reasonably close to the barn. I took a more direct route back to the house and regretted it.
Dick Hines
Dick Hines
I was doing a job hooking up a telephon line years ago. The connection box was on the toher side of a electric fence. I went to where the little red handle was that you could open the fince with out getting shocked. Well I did not take into account that me shoes were wet and the little handle was wet also. I though the filling in my teeth were going to come out.
Bob Macgregor
(Probably) more than you ever wanted to know about electrical exposure hazards: http://bme.ccny.cuny.edu/faculty/mbikson/biksonmsafevoltagereview.pdf
Here's a little bit of excerpt:
"The passage of significant current can
reduce skin resistance to negligible values (>200 V,
Biegelmeier 1985a; >240 V, Webster 1998; 100-250
V, Reilly 1998; Camp et al. 1976). Thus with
higher voltages, skin conditions are considered to
play no significant role (DiMaio and DiMaio 2001).
Gettman (1985) noted that below 12 V skin
resistance would not break down.
Skin can provide a significant source of
insulation. Skin has a surface resistivity (in �cm2).
Skin resistance is a function of contact area; larger
contact areas result in reduced effective total skin
resistance. Camp et al. (1976) noted that if the
palms are thickened by manual labor the dry skin
resistance can reach 2000 k. DiMaio and DiMaio
(2001) concluded that for 120 V, dry skin may have
a resistance of 100 k; dry and calloused skin up to
1000 k; moist skin 1 k or less; and moist, thin
skin as low as 100 . Wright and Davis (1990)
considered the minimum internal resistance of the
body 500  and minimal hands/feet resistance 1 k;
dry skin easily reaching 100 k."
[the little boxes are supposed to be the omega sign, the symbol used for ohms of electrical resistance]
They also note that wet or broken skin can have resistance reduced by 99%!! I read somewhere that a VOM can kill you (by stopping your heart) if you actually stick the probes through your skin, but I don't have (and don't want!) personal experience to validate this claim.
BOB
