glue for pen making
DaveL
Quick question---what glue do you pen makers use to glue the brass tube in the blank?
Thanks in advance.
Dave
glue for pen making
DaveL
Thanks in advance.
Dave
Re: glue for pen making
Harry in Beautiful Downtown Kulpsville
i don't really consider myself a pin turner since I only make a few a year, but I have always used polyurethane glue. It takes a little longer to dry and is kind of messy when he gets on your hands and clothes. But, it fills the voids and I have never had a failure with the tubes moving once the glue was set.
Ken Vaughan
"highly personal decision" with advocates for several perspectives -
I have had poor success with CA glue in long term applications and tend to use either the polyethylene (gorilla glue or similar) or epoxy. Production runs tend to be the polyethlene glue because of pot life limitations with epoxy. Tubes tend to shift/slde with the polyethlene glues and I use small rubber bands around the ends of the glueups (centered on the brass tubes) to keep the tubes in place.
I do abrade the outside of brass tubes and color them if there is a chance of the brass showing through (laser blanks, polyester, etc). Sanford markers usually win.
Bill Howatt
I'm not a prolific penturner but I like 5 minute epoxy since it is cheap (you can use dollar store stuff), it fills gaps should you have any and it isn't too messy. I have used CA glue and polyurethane glue and they work fine. For me the epoxy is less messy than the poly glue and it dries faster. I did have some trouble with CA glue but it likely was a sloppy hole problem - I normally only have thin CA on hand.
I normally coat the tube and slide it into the hole with a twisting motion. I push it about 3/4" through the blank and dab a bit more epoxy on the exposed end which may appear dry and then push it back flush.
Bill
Don at Central Illinois
While don't make a lot of pens, I have used medium CA with no problems (yet).
CA glue-no problems yet
Charles Yawn
Two Part 5 Min Epoxy
Jim in River Oaks, Ont.
I used to use CA glue but to any brittle glue failures on the lathe led me to epoxy. It's all I use now.
Take care,
Jim
Bernie Weishapl
I use nothing but 5 minute epoxy.
Re: Two Part 5 Min Epoxy
Jim Sebring
I've settled on 5 minute epoxy. CA can interact with the oils in some woods like ebony and will set before the tube can be fully seated (DAMHIKT). I've not had any problems with poly. I've used "Fusion" from Michael's with good results, so I rate it as the second best.
Slow set medium CA glue (5 mins)
Colin
2 Part Epoxy
Joe Pack
I use 2 part epoxy exclusively. The tubes from WalMart, HD, Dollar Store, etc. are fine. Buy the cheapest...they all work fine. I like the 30 minute type when I can get it, just so I don't have to rush, but the 5 minute works fine. Just mix smaller batches.
The best economy, though, is the West System 2 part kits sold thru Woodcraft, Rockler, etc. You get two large bottles (red and green label) that are easy to use. If you use a lot of epoxy, you will save a lot of money buying the larger kit, and you will not have the "hardened in the tube" problem I have run into with several of the 2 part syringe tubes.
Wally Dickerman in Arizona
The new rubberized CA. Has a little give to it. If the drilled hole has a sloppy fit I use Gorilla glue.
Wally
