I think I've done about as good as I can. I tried to make a smaller captured ring goblet but broke 4 of them. I decided that was enough. The largest 2 ring goblet is 1/4" or 6mm. If you look in the plastic cube you will see the ebony goblet that is the smallest I've turned without rings. I don't know how big it is yet. I should be able to find someone at the University who can measure it. It's really tiny.
That little black one takes the prize. I did a few miniatures, but nothing to compare to those. Takes one steady hand. Kudos to you. Tells us a bit how your mind works.
I had to go look at a penny and get an idea what size the black goblet must be. Looks smaller than the date on the penny and that is roughly 1.3 mm high.
If you try one smaller we would just have to believe you cause we would not be able to see it!
It looks smaller than your turning tool tips so not sure how you hollowed it either!
... that you made your own tools for this enterprise, John. Very cool.
Seems to me there was a carver who made sculptures so small that you needed a microscope to see them. Anybody got a link to that fellow? He's the only person I've seen making stuff smaller than your goblets. Can nanotechnology be far behind? At some point, the pores in the wood will be bigger than the sculpture.
I saw (rather, barely saw) your goblets in Hartford. Steve Paulsen never turned stuff that small. You've raised the bar.
Ellis The artist is Willard Wigan Micro Sculptor of Birmingham England. His sculptures set inside the eye of a needle. If you do a search make sure your anti virus is up to date. One of the sites I don't know which one gave my computer a cold this past summer.
...... are you turning these fantastic goblets from? Curious to know what wood stays together to form the captive rings, to allow this level of hollowing, and most of all, to stay together to keep those stems intact.... reat accomplishment John!
Outstanding macro shot as well - are you using a bellows?
Rob Wood choice was interesting. Apparently at this size wood varies from board to board. At first I had good success with Cherry. Then on the next try they kept breaking so I changed to Yellow heart. It has been the best overall but often has pores that run parallel to the grain and if one ends up in the stem or goblet bowl area they break. Ebony has been hit or miss. One batch wouldn't work at all but when I kept blowing up the yellow heart at this size I tried some other ebony that I had and it worked.
Many years ago, Rex Vaught traveled to Australia on a woodturning tour. He watched someone there turn miniature goblets, totally impressed. The turner gave Rex two of the goblets and not knowing what to do with them, he put them in his pill box. (Rex is now deceased and he was old-ish then.) Later that night, forgetting that the goblets were in his pill box, when it was time to take his pills, in his usual manner, he popped the entire contents into his mouth, took a huge swig of water, and swallowed everything. As soon as the slurry went down his throat, he realized what he'd done!
He told on himself the next day at the demo and the turner gave him two more goblets. He managed to get those home, safe in a small container.
A few years later, I was visiting Rex and looking at his turning collection. I picked up a small bowl, noticed what I thought was dust inside, and blew a puff of air. Yes, the goblets fell out . . . onto a blond shag carpet! It took me about half an hour to find both goblets, but darn! I wasn't going to leave his house until I found them.
I expect, John, that if those goblets had been yours, I would never have found them in the shag carpet. Yours are smaller!
I can see where you would have had best success with diffuse-porous, somewhat dense, tight grained woods like yellowheart - also makes it clear that different sections of the same piece of wood may have different turning properties too. You might want to experiment with some of the following (if you haven't already tried them): hard maple, cocobolo, African blackwood, and Bradford pear - all of these cut and scrape very nicely. You are providing much inspiration for me to get out my collet chuck mini-turning system and do some small scale turning again (....but not to the 'near nano-scale' that you are at!). I just have too many normal sized pieces to finish by the end of the month. I'm starting consignment sales at a 5th gallery on Nov. 1st, and am doing lots of sanding and spraying right now to make sure the body of work destined for the new gallery will be of acceptable quality. (It would be hard to sell a 2 mm goblet there!).
Thanks for the reply, and keep us posted about any new woods you try that work at that scale!
It has been written that you can do just about anything with a 5/8" bowl gouge with an Ellsworth grind... Somehow I suspect these don't qualify for "just about anything".
John, If get anywhere near Newport News Va. you need to go see the Applegate collection of ship models..at The Mariners Museum........I think you even have him beat for size.......well worth a visit anytime.......
I saw a segment on this guy on TV and wanted to post the same message but couldn't remember his name. His stuff is really amazing. He times his cuts between his heartbeats to keep a steady hand. I don't think he drinks coffee either. He made his tools out of lint and stuff you wouldn't believe could be used as a tool. Can't remember how he colored them, but it was just as amazing. He definitely raised the bar higher than any normal mortal could challenge, but I would say that John's work is getting there.
