cutting a large log
I'm trying something I've never tried. I want to cut a couple of platters as large as I can. I cut 2 flat sides although I kind of wish I had cut them parallel. Then I rolled the log on it's side using a chain and my truck. I cut some lines about an inch or more on each side of the pith. Now all I have to do is cut all the way through.
That will be the challenging task. This log is 34" on the narrow end and over 40 on the long end. I only have a 20" bar. I'm hoping it will be less than 40" thick 20 inches from each end. If it isn't it's going to be really interesting.
It will also be interesting connecting the cuts when I flip the log 180 degrees to cut in from the other side. I'm sharpening the blade often so that I can keep the cut as straight as I can.
