Piercing tool ?
Piercing tool ?
Piercing tool ?
MMann
Hello, new poster here. I'm in the market for a quality high speed (300 - 400K RPM or higher) piercing tool. Any suggestions of make/model and where to buy would be appreciated.
Re: Piercing tool ?
Re: Piercing tool ?
Dave Long
You might want to look at J. Paul Fennell's website (JPaulFennell.com). He is the master of piercing work and has some different tools available. Or send him and e-mail and see what he recommends.
Re: Piercing tool ?
Rob Wallace
Re: Piercing tool ?
Rob Wallace
I have a Powercrafter and it works OK, however many are now gravitating to the NSK model - a search on WC or on other sites will yield a wide range of comment on this topic, with various recommendations.
If recommendation by association helps, master piercer (and master artist in general) Binh Pho uses the NSK, and actually sells these tools, along with other piercing and air brushing supplies.
Rob
Re: Piercing tool ?
Re: Piercing tool ?
MMann
Thank you both, I'll check out the NSK but would not buy it from Binh Pho.
Re: Piercing tool ?
Re: Piercing tool ?
Bill Neddow
The NSK is available from a number of sources, including Craft Supplies (http://www.woodturnerscatalog.com/store/Carving___Pyrography___Carving___NSK_Presto_High_Speed_Carver___nsk_carver?Args)
Re: Piercing tool ?
Re: Piercing tool ?
MMann
Thanks for the info Bill, I'll check out CS.
Re: Piercing tool ?
Don Geiger
Re: Piercing tool ?
Don Geiger
I have the NSK and really like it. I assisted Bihn Pho with a class at Arrowmont a while back and one of the students brought a Powercrafter and it is was much louder that the NSK. The sound was very annoying.
There is a source for the NSK that is less expensive than any other I've seen and it is from: Jaymes Carving 888-638-8998.
Don Geiger
