Sealing with wax: why?
Aage Rendalen
Aage Rendalen
John Lewis mentioned going out for more wax to seal some round blanks.
1. What kind of recipe do you use, John?
2. What advantage does it offer over Anchorseal?
Re: Sealing with wax: why?
I'm Not John, But
I can tell you that Anchorseal , because of the emulsifier in the mix, makes a very soft coating. If you wanted to lock up a turning blank, coat it all 6 sides with hot parafin with some Bee's wax mixed in. Brown Victory micro-crystalline works well also.
I use the wax to sort of put the wood in hibernation. It seals the wood so air doesn't get to it. Since it's not drying it doesn't crack. It's not perfect. The wax eventually dries out and let air get to it. However I've been playing with it for the last 3 years and I've saved bowl blanks made from Cherry and Apple for a year or more without checks. That's stored in my shop on the concrete floor out of direct sun.
Anchorseal lets the wood breath but slows it down. The idea is you seal the endgrain to even out the drying. It works really well for me when I rough turn vessels and seal the end grain with it. It doesn't work worth a darn if you seal the end of a log and leave it in the yard unprotected from the weather.
I can't turn as much as I like and I tend to get green wood at inconvenient times. Consequently I've had to figure out how to save it. The scheme I've come up with is to cut up what I can into bowl or hollow vessel blanks. Seal them in wax and store them in the shop. The rest of the logs will sit in the yard with Anchorseal on one end and the other end on the ground (short logs). Long logs are just left alone. When these start to check I try to get some bowl blanks out of them. If they've checked too much I cut them up into spindle blanks and seal the ends with wax.
I use an old electric skillet to melt the wax. I have hot glued the temperature dial at the minimum setting it takes to melt the wax. this should stop any fire danger but I still stay with it anytime I'm using it. Don't want to take any chance.
George Guadiane
Like John, I used melted paraffin wax in a garage sale electric frying pan (the biggest one I can find).
The hot glue idea is fabulous, and as soon as I dial in the perfect temp, I'll glue mine in place!
In the last year or so, I've been using AnchorSeal. In honesty, I have lost a considerable amount of wood with the AnchorSeal, compared to melted wax... I have a lot (seriously, A LOT) of prepared blanks in storage in a temp controlled room. With the paraffin I lose less than 10%. With the AnchorSeal, it's much more than 10%.
My one little "trick" is to let the wood sit in the pan till it sizzles/bubbles just a little. My thinking is, the water in the end grain comes out with a bit of air and sucks the wax in, making a stronger/tighter seal. I let blanks get to room temp in winter otherwise the wax doesn't stick as well.
AnchorSeal is easier, more convenient, and probably safer to handle, but the wax is more reliable and keeps wood a lot longer.
Chuck Jones - West TN
Try the propane torch method
I agree with all you say George and I've had the same results. I think you are correct about the "sizzling" technique and that lead me to start using the propane torch (can't remember where I first got the idea). I flash the flame back and forth across the end grain a few times to remove some of the moisture, then using a large block of wax melt it on to the wood. You can go back and forth over the wax a few times and melt it in. PIA but worthwhile for good blanks. Obviously it's a good idea to get away from the shavings pile to do this.
I've used Anchorseal for years on my saw logs, but I'm not happy with the results on turning blanks. Like everyone has said, nothing's foolproof when you are arguing with mother nature.
Neil Longhenry - Rogers, MN
John, Thanks for your input. Your ideas along with all of the other members are really helping this newbie out.
One question:
Do you wax just the endgrain or the entire blank?
I wax the entire blank unless it has the bark on. I don't wax the bark side. These are solid bowl blanks not roughed out bowls.
Hugh Widdup
are you just using parrafin wax?
Barry L Elder
I've not tried the paraffin wax but my problems with Anchorseal went away when I started putting on two coats on the endgrain.
Source
Nick Tuzzolino
A local lady that sells blanks coats all her pieces with wax.
She uses Houseblend #140 from General Wax and Candle. This is a very clear wax and you can easily read the grain, etc. I bought 24 pounds for $26 plus $10 shipping. www.generalwax.com . Clear wax and a lot cheaper than one pound at a time in the market.
Re: Source - FIND SOME FRIENDS
George Guadiane
If you have to, but buy from them or a source like this, in the hardware store, it's over $6 per pound...
However, if you don't care about being able to see the grain, you can get old candles for even less per pound at garage sales, salvation army and the like...
The all white ones will come up clear after melting down if you want to see the grain (I do).
Yes. I just go to the grocery and by canning wax.
I pay about $2.88 a pound and it goes a long way. I can melt 2 lbs and do an awful lot of wood. I'll bet I haven't gone through more than 4 lbs in a year.
Michael's Craft Store
Don Orr
They carry candle making parrafin wax in large slabs-maybe 5 lbs. They usually have 40-50% coupons in the Sunday paper. I got a couple of slabs that way and it lasts a long time. Whack it with a hammer when it's cold and it breaks up nicely.
CAUTION - Hot Wax
charlie belden
Working with hot wax poses several non-obvious threats to your safety and well being.
First is how you melt it - and the fire that can result if you do it wrong. Really hot wax can produce flammable gas versions of the wax. If the hot wax or it's vapor and an open flame meet . . . A Double Boiler - water in the lower pot that the heat source is directly under, wax in a pot sitting in the lower pot - but with its rim well above the hot water level - is safer than a one pot melting method. And if the hear source is electric - no exposed flame.
The second danger is less obvious. If you've ever added some water - to a pan of really hot oil - you know about hot oil (or hot wax) spatter. Not fun to experience. So the wood you want to seal in hot wax SHOULD NOT be dunked / immersed in the molten wax - especially if it's REALLY "green". With some woods, like sycamore for example, fresh cut wood can leak water - which can pool at the bottom of a standing fresh cut log / logette.. Dunk THAT in hot wax and plan on some unforeseen hair removal where ever the hot wax solidifies on your skin. The resulting blistering will hide the hair loss initially ; )
Re: CAUTION - Hot Wax
George Guadiane
Your concerns are justified, and your points well taken.
I suggest:
Working in a well ventilated area, away from flammables, wear protective clothing and gloves to help prevent skin contact - EYE PROTECTION and be very careful about your temp setting. It was suggested that one hot glue the dial in place once the optimal temp is found, I'll be doing that.
Bill Jacksonville, NC
Spilling hot wax on yourself is the greatest danger you face using hot wax as a wood sealer. You want the container (pan or pot) you melt wax in to remain stable during melting process.
If using the double boiler method to melt wax makes you feel safer do it. Remove the melted wax pot from water pot before start dipping blanks.
Never had a problem with flammable gas from melting canning wax on electric hot plate with no thermostat. I do pull the plug on hot plate when enough wax has melted to dip and end seal.
Melted wax cools fast, so dipping is best method of application. I have tried to paint brush and pour hot wax over end of a log, not happy with results.
Commercial wood sellers dealing with thousands of pounds of wood dip entire blanks in wax. Entirely stops wood drying process. Prevents drying defects regardless of relative humidity, and they sell wood by the pound. Think you will find more direct heating melting tanks than water jacket melting tanks used.
Steve Kubien
Steve Kubien
Geez it seems lots of folks have had bad experiences with Anchorseal. I do not share that experience. I really like the stuff. I do not have a pile of logs sitting in the yard, exposed to the elements like some, though.
I use it all the time for sealing the end-grain of rough-outs, be it bowl, platter, hollowform or rounded spindle stock. I recently got into using a refridgerator as a kiln and everything goes in there. Once dry (about 4 weeks), I bring it out to sit in the shop for a few weeks. Some piece end up sitting for a couple of months and I haven't lost any, except those with really funky grain which I expected to lose.
Some species get an extra coating of Anchorseal, those prone to cracking like cherry.
Of course, I live in southern Ontario and our temps and humidity are different than a lot of places. We're kinda like western New York, I guess.
Steve I got a load of cherry from a friend who lived 20 miles away. I cut it to about 4 foot lengths and took it home. It was cracking badly on the ends by the time I got it home. I have a terrible time with that wood. Next time I'm going to try and seal it as soon as I cut it.
