It was finally cool enough to spend some time cleaning up the wood in my yard. I cut up the smaller stuff. I still have a ton of maple. I'm going to seal most of this with wax because I don't have time to rough it. I'll try to rough some of it into bowl blanks and few into vessels. I've got to head to the store to get some more wax. I ran out after sealing the flat areas.
We had a discussion the other day about bandsaw blades. I use a 1/2" 3tpi cheapy that I get from my local saw sharpening service. They cost me $6. I can't tell you how much work I've done with this blade. At least a dozen of the maple peices, all of these and many other projects in the last 6 months. I've cut up a lot of wood. With this last batch it started to get to the point where the blade would flex when you started the cut. I was still able to cut out about 5 blanks but it's finally time to replace it. Here's a shot of the mess involved in cutting up all that wood.
Cleaned it all up. I've got to repair a piece of furniture for a return client. Once you do a furniture repair or restoration for someone your stuck forever. I pursued this about 10 years ago and decided I didn't like doing it. I still get repeat customers that I can't say no to.
John, I agree with Terry. Bi-Metal bandsaw blades are the way to go. The teeth are much harder but they are attached to a more flexible backing (thus bi-metal) and they last much longer. Well worth the extra bucks.
Bill I tried 2 of them. Then bend too easy if you have the slightest twist in the wood while your cutting. As you know when you chainsaw blanks they are never truely flat on the bottom. I rarely have a problem with it catching the blade but when it does my cheap blades survive. The $40 dollar ones don't.
John, I've never had that problem with mine. Of course I'm using a 1/2" blade with plenty of tension. I can cut a full 13" tall blank without problems. Sorry they didn't work out for you.
Bill They did seem to cut better than my cheapies and I would cut lots of blanks. But you only need one to catch and bend the blade. My cheap blades easily cut 12" blanks and when I get a catch due to the blank rocking they don't bend.
Yea I know I could probably stop those problems by shimming the bottom but with the small table of my 14" saw you don't know where to shim and it takes too much time.
