Bowl Deconstructing Fixture
Doc Green
This is in response to a post by Carole, a few clicks down . . .
Here is a fixture that will support the underside of a bowl or platter while it is being deconstructed on a bandsaw.
A pedestal with a dome on top is attached to a strip of plywood which is, in turn, clamped to the table of the bandsaw. The saw blade enters the pedestal at the very top of the dome.
To use it to deconstruct a bowl, place the rim of the bowl on top of the dome and push it into the blade to start the cut. As the cut progresses, tilt the bowl as required to keep the point of contact at the top of the dome. This keeps the point of support exactly where the blade is doing the cutting.
It is very stable in operation and exhibits no tendency to grab. Of course, you must not try to cut a curve whose radius is too small for the blade or the blade will twist, etc., etc. And, it is conceivable that if you were to let a thick-walled bowl tilt significantly to either side, you could cause the blade to bind in the cut, but this would be an extreme situation.
The pedestal is about 4.5" at the bottom; the dome at the top is about 2" in diameter. It is 6" tall, which is about half the maximum capacity of my bandsaw. The pedestal is attached to the plywood strip with four #6 drywall screws, 1.25" long.
The pedestal is turned from an end grain piece of ash, centered on the pith. I trued it up between centers, and then mounted the blank on a faceplate for final shaping.
I made the saw cut into the pedestal after attaching it to the plywood. It was a simple matter of slowly pushing it into the blade, and it didn't tend to grab or tip over. I stopped the cut at very nearly the exact center of the top of the dome.
After clamping it to the bandsaw table, I tried cutting a piece of flat stock. No problem; it was smooth and stable. Then tried it on the only bowl I had that I wanted to sacrifice, and it went smoothly as well. The curved piece of scrap at the left in the photo was cut flat-side-up, with the cut perpendicular to the flat side. This was uneventful even though the point of support was offset a small amount from the blade.
I think you could cut any bowl or part of a bowl safely as long as you can manipulate the bowl so as to keep it in contact with the top of the pedestal. To do a preliminary test, clamp the pedestal to the top of a work table and see if you can run the bowl across the dome of the pedestal while keeping it in contact with the dome. If this works, then move it to the bandsaw and let the good times roll.
Be careful. Bandsaws are dangerous, as are lathes, table saws, jointers, routers, and pocket knives.
~Doc
Re: Bowl Deconstructing Fixture
That is similar to the jig I rigged up to drill holes in sided of bowls. I needed the holes to be perpendicular to the sides or at least visually very close. The jig let me level that particular spot and also prevent tearout on the inside of the bowl.
Carole Valentine
Pretty cool, Doc! One thing I do like about this method is that if something happened to go wrong, it looks like your hands are more likely to just fall down toward the table where the blade is shielded by the jig. Not to say you couldn't get cut - whenever there is a moving blade accidents can happen, but you are more or less protected from the entire lower half of the blade.
Chuck Jones - West TN
Ingenious!
... now if I can just figure out why you'all want to deconstruct a bowl. I'm still trying to learn how to construct one.
Re: Ingenious!
Carole Valentine
But Chuck, there are all sorts of reasons to cut up a perfectly good bowl that you just spent hours perfecting! :D Stay tuned...may be a quite a while though since this will be a new area of exploration for me.
It's called saving a bowl
Remember those pieces that blew up. Cut them up and reassemble them. Steven Hogbin made a fortune doing that.
Here's one of mine that's been in the works for a while. It's going to be a flower when I get it done.
Bob Moffett
Bob Moffett
doc,
That's a great idea and it looks a lot safer than some other methods that I have seen or heard about.
Re: That's very slick Doc!
JamieDonaldson
