[AD] Thompson Tool Handles - Special Offer! *LINK*
Hurry! This offer ends September 30!
Special offer on Thompson Handles
Re: [AD] Thompson Tool Handles - Special Offer! *LINK*
Mark Wollschlager
This is a really nice deal.
I received mine the other day and they are NICE.
I have yet to see a better made metal handle.
You will not be disappointed, not by Doug's work.
mark
D. Hansen
I received mine the other day as well. Really neat. The only down side is my dumbness. I was going over the literature Doug sent with it in the "reading room" Unscrewed the plug to see how much room I would have to lead it with lead shot. Surprise it is already packed with tiny tiny tiny pellets that reained all over everywhere. SWBO was really ticked about the mess on the floor. Luckily the pellets are steel and a magnet cleaned up everything but my ego.Super nice handle and they don't roll off the work bench.
LOL!!!
Molly Winton
Mark Wollschlager
Did the same thing.
The shot is so quiet, I didn't realize it was there.
Steel shot goes everywhere, fast, doesn't it?
Magnets are your friend. :-)
mark
D. Hansen
yep just remember to wrap the magnet in something like maybe "TP" then when you remove the paper the stuff falls off.
Doug Thompson near Cleveland
Oups! Maybe I should crank down on it... there is a notice on the tag to tighten before use. You did notice the O-ring... it will hold oil if you see a need. Hey that's something new oil filled handles.
An Oil Fill
Russ Fairfield
An oil fill in a steel tool holder is an old pattern shop trick. The oil adds some weight and reduces vibration. They were a real mess when they sprung a leak, which was most of the time. Then I discovered that sharper tools and lighter cuts did a better job of reducing vibration and giving me a smoother finish cut.
Dick Hines
Re: An Oil Fill
Dick Hines
Doug, do you have to change the oil every 3000 turnings?
Re: An Oil Fill
These go 5,000 turnings before the oil has to be changed. The O-ring is nothing to put in so it was done, I do like the concept of oil mixed in with the shot to dampen the vibration but they will not be shipped with oil.
If you need shot I have some...
Glad I got my order in!
david
Don't laugh, 90W works best
Russ Fairfield
Re: Don't laugh, 90W works best
Russ, I'll try that so far I've tried thinner oils to dampen the movement of the shot.
Russ Fairfield
Just be aware that it is the most difficult of all oils to clean up after a spill.
Agree
Jorge Casta�eda
And it stinks!
Jerry Whitaker
Same thing happened to me....all over the sofa, down the cracks, under the seat cushions and all over the floor and in front of a bunch of friends. Vacuumed them up and replaced them with #8 lead shot. That was all I had. Doug....maybe you should leave out the shot or put at warning sticker on the handle.
I have a sticker that the bag is closed with a warning to tighten the cap. The thought was woodturners want to play with a new toy, take it apart, look and adjust. From now on I'll crank it down, that was the reason for the hex broached in the cap for a 3/8 allan wrench. These need a way to adjust the weight therefore the cap.
All over a couch is a good one, I did see one emptied in a resturant. The need to take things apart is strong with woodturners...
