Anatomy of a hat failure
Steven Antonucci
steven antonucci
I felt like doing something last night, and the wife had the kids at the beach, so I had the house to myself. After putzing around the garage for a few, I settled in on making a hat.
This would be hat #5, and I would try to incorporate everything I had learned from hats 1-4. I estimate that the time spent is usually in thirds. The first third is spent roughing out, which gets you to this point. If I had a bigger lathe, I could probably cut this time in half, but there is a lot of time spent at lower RPMs. As you can see, the lower RPMs don't throw the shavings very far :)
The hat is mounted on a face plate from the bottom, which means I will need to turn it around. Here is a little trick I used for getting the other face plate on and almost perfectly centered. It worked within 1/32", and a quick retrue completes the first "third". (A thick hat form)
The second "third" is spent making the brim. The hardest part is the inner transition measurement where the brim meets the inside of the hat. If you get this wrong, they won't bend. Light is the key, but it also plays tricks. If you look at this picture, you might think it's all uniformly thin, but it's not. When the hat failed, I measured it in a few spots. Brim 60/1000ths. Transition 125/1000ths. Upper spot 40-60/1000ths.
The failure is somewhat of a mystery to me, although I think I know what happened. When you are hollowing the upper, it gets very easy to hog out material from the middle, since the fine cuts aren't usually until you get under 1/4". The problem with doing this is that you have a large mass of shavings that ball up inside the hat, and I had a slight "tear" in the crown that I think came from the ball pushing against it. It would have been repairable.
I reverse the hat against a pair of cole jaws and started pairing off the upper mass. I was probably about 3/16" thick in the top when my turning was interrupted by a loud bang. No catch, just the bang... and the flying hat pieces.
Now, the issue is like a CSI episode. As you can see, my cole jaws are missing a piece, but I think that happened "after the fact". A while back, I lost one of the screws in a pile of shavings, so that jaw was only held on with one screw (duh!), but I am not sure if the jaw came off first, causing the hat the dislodge or if the split caused it to flex out of the tailstock point. The hat was broken along that failure line...
It seems that it may be time to make that thing that Johannes uses to reverse the hats...
Steven
Re: Anatomy of a hat failure
At the risk of being obvious...
I know very little about making hats, so i won't comment.
But, I too lost a screw in the shavings and spent way too much time searching. Did two things. Bought a Harbor Freight magnet made for dragging around on a cord. Was astounded at how many little pieces of metal it got out of my gravel drive. It's a wonder I had any tires that were not flat. And I thought I had been careful all these years. Its great for searching the sawdust. Every once in a while it finds stuff in the sawdust that is baffling. How did that get there? And glad it did not get shoveled out or go through the DC The other thing I did was buy a set of spare screws and spare rubber grippers.
Steven Antonucci
Have something similar (and a metal detector)
steven antonucci
just never found that screw? BTW- the metal detector is useless around a lathe... did you know that most lathes are made out of metal? LOL stupid thing just beeps constantly...
If I ever win the lottery, I am going to make the end-all-be-all of turning shops, complete with an automatic clean up (big fan and an open door) and a electromagnetic plate that I can turn on to hold the metal bits that I dropped to keep them from blowing out...
Steve
Well ventilated sun hat !
Don Orr
Re: Have something similar (and a metal detector)
I bought a Dust Collector. Hundreds of dollars. Put it in the shop and turned it on and let it run for hours. Got nothing. There was nothing in the bag. hardly any dust in the upper bag. All the shavings were still on the floor. What a Disappointment. It did not even put any tools away. I should have taken it back.
I have a couple of hats just like that!  ):
Mike Jones in Redding Ca.
Steven Antonucci
You are welcome to wear it
steven antonucci
I'd get a sunburn on my thin spot...
Harry in Beautiful Downtown Kulpsville
I believe that the thickness variation that you saw is a result of how light is transmitted through side grain and end grain. I believe Binh Pho mentions that in one of his videos.
Dick Hines
Dick Hines
Sorry about your hat.
As for the missing screw. When you get a new set of jaws you get a new set of screws. I put all my extra screws in a pill bottle. I have 5 chucks so I don't change jaws much. But when I do and drop a screw in the dust pile I just go another one out of the pill bottle.
I don't spend much time looking for small parts in the dust pile unless it happened to be the only small part I have. Then a old speaker will usely do the job.
ed hoxter
ouch!!! ed
Dick Coers
My first thought on the failure is that the wood had a weak spot. Probably from one of the ambrosia streaks. I was doing a small thin wall cherry bowl that had a very slight discoloration on the rim. When I shut off the lathe, that bruise area had two cracks. Nothing anywhere else.
