Kristen Kone
Kristen Kone
George Balock
Kristen Kone
George Balock
Does anyone know where I can get one of these commercially? I saw the Don Pencil one, but it doesn't look quite right, so if you use the Don Pencil one and like it let me know.
For those who don't know of what I'm talking about, here is a picture.
Re: Kristen Kone
Re: Kristen Kone
Bill Hale The Wood Spinner
Very similar to the Oneway system. I don't know what the front extension would do. The Oneway has two cones The larger beeing reversible for external capture. The cones screw directly to the end of the live center.
Re: Kristen Kone
Re: Kristen Kone
Fred Holder
Those were originally designed by a member of the San Diego Woodturners. They ordered more than their club could use to get a good price on production of the piece. It was designed to reverse turn hollow forms. I was lucky enough to get one of the original batch they ordered. I don't know if they are still making them or not. Perhaps they have turned them over to Don Pencil.
You can make one very effectively completely out of wood. I made one for my sister-in-law that worked very well. I didn't realize it was called a Kristen Kone.
Re: Kristen Kone
Re: Kristen Kone
Carole Valentine
George,
I think what you are looking for is the Woodchucker mandrel. Google and you will probably find it at some of the larger turning suppliers.
Re: Kristen Kone
Re: Kristen Kone
George I believe there was an article in American Woodturner on how to build one. I would have to go back a few issues to look and see. It was several years ago.
Re: Kristen Kone
Re: Kristen Kone
Fred Holder
The Kristen Kone you illustrate was documented in my book, The Woodturner's FAQ Book, which was published in 2007 by Linden Publishing. Here is the text describing the book;
The best method that I�ve encountered is a jig that the San Diego Woodturners had made up back in 2002. I purchased one of these and found it invaluable when remounting a hollow vessel to turn the foot. Oskar Kirsten designed the jig and Nan Bushley made design improvements before the club had any units manufactured.
The jig is a long steel rod about 3/4" in diameter. One end of it has a Morse Taper #2 machined onto it. The other end has a 1/4" hole bored into it for gluing in a 1" sanding mandrel. On the rod, there is an aluminum cone with a pair of set-screws. The cone slides up and down the shaft except when the set-screws are tightened.
When you are ready to reverse-turn the foot of a hollow form, you mount the jig into the spindle taper. Next you place your hollow form over the rod until the rod touches the bottom of the vessel. The sanding mandrel with a sanding disk presses onto the inside bottom of the vessel. The tailstock presses the other side of the bottom. The cone is then slid up the shaft until the pointed end of the cone engages the mouth of the vessel. The set-screws are then tightened. You are ready to turn the foot. The advantages of this jig are that the vessel is driven at the foot instead of through the body of the vessel.
Considering that the San Diego Woodturners likely didn't patent the item, there may be several companies making a copy.
Re: Kristen Kone
Re: Kristen Kone
Barbara Gill
It probably wouldn't have made a difference it they had received a patent on the design.
Re: Kristen Kone
How to:
Allen Neighbors
Make one for yourself. Locate a 3/8 round shaft about a foot long.
Mount a 4" x 4" piece of wood in your chuck, and drill a 3/8" hole through the center.
Turn the wood into a cone shape. (I have three. My most used is about 5/8" at the pointy end, and about 4" at the end that mounts in the chuck.
Drill a hole in the large end, perpendicular to the center hole, and tap it to accept a 1/4 x 20 bolt.
Insert the 3/8" round shaft into the center hole. Tape a chunk of leather on the end of the 3/8" shaft.
The Cone is fastened into the chuck, the hollowform is reversed, by inserting the tip of the cone into the opening. The rod is moved out until the leather covered end is against the inside bottom of the hollowform. Tighten the 1/4 x 20 set screw against the rod, to hold it in place.
The tailstock applies pressure to the bottom of the piece which is against the end of the rod.
Now you can finish the bottom except for a 1/8" nub. Part off, and sand the nub.
The Kirsten Kone is a lifesaver...
Re: Kristen Kone
Re:George- I have one of the original.....
JamieDonaldson
...production models that I don't recall ever using, and will sell it to you for a good price if you're interested.
Re: Kristen Kone
Dick Hines
Re: How to:
Dick Hines
Woodturners catalog has the for $50. You can do your own for about $15 max.
Go to one of the big box stores and pick up a steel for of about 3/8" and a locking collor. Turn a cone that will fit on the rod. Drill a hole in the end of the rod. Glue an old sanding disc holder into the hole with CA. Add a 60 grit disc and you are ready to go.
Re: Kristen Kone
Re: Kristen Kone
Harry in Beautiful Downtown Kulpsville
Here is one I made quite inexpensively. It uses a piece of 5/8 inch rod with a piece of 60 grit sandpaper glued to one end. I turned the plastic cone out of some scrap plastic that I had. The cone is held in place with a collar from either Enco or MSc. I hold the end of the rod in the #1 jaws of my Talon Chuck.
By the way the hollow form is bleached Box Elder with more red staining that I have ever seen.
Re: Kristen Kone
Re: Kristen Kone
Terry Scott
I got mine from Craft Supplies and would recommend if you do any hollow forms they are an essential part of your kit .By varying the cone sizes or by making cups that go over the knick anything can be held to tidy up the bottom or even use to hold the work while carving like I am in the picture
Re: Kristen Kone
Ask Art Liestman
Craig Daymon
I'm pretty sure he's the one that introduced it to the Bucks Turners...or possibly the weekend before the meeting at Dave Hardy's. I bought one shortly there after. Unfortunately, I don't recall where I bought it. Art posts here once in a while, maybe he'll respond.
-Craig
Re: Kristen Kone
Oskar Kirsten's web page *LINK*
Craig Daymon
I don't know if the San Diego group is still making them, but here's some info about buying it listed on Oskar Kirsten's web page. (Took quite a few searches to find it, but searching on his name, woodturner and Kirsten Kone finally turned it up.)
-Craig
Oskar Kirsten's page with Kone info
Re: Kristen Kone
Re: Ask Art Liestman
Art Liestman
You know, I try to lurk undetected here, but every once in a while someone takes my name in vain and I have to comment. What can you do? By the way, Craig, thanks for remembering something from a demo that happened five years ago. I'm lucky if I can remember things from demos that I saw last month!
I got my Kirsten Kone from the San Diego gang and have used it in lots of demos over the years. I don't think they are making them now. I had a longer mandrel made by my local machinist and I also made a smaller plastic cone. Just yesterday, I was thinking about getting a shorter mandrel version made for one of my demos in Hartford - mainly to save weight in the luggage. If you don't want to work with a machinist to make your own, the Don Pencil and Craft Supplies versions seem to be a good place to start.
The pictures they show to illustrate their products feature large cones. I'd suggest making one that would be big enough for the largest opening that you are likely to turn. (Large cones eat up length of mandrel, so you don't want them too much longer than you really need.) Please note that the cone is not used for pressure to drive the piece, just to center in the opening and keep the piece balanced so that it doesn't wobble.
The Craft Supplies version also shows what looks like a 2" sanding disc on the end. Again, that's bigger than any openings that I regularly use, so you'd probably like to use a 1" sanding disc. In a pinch, you can actually put the sandpaper (for the friction drive) directly on the end of the mandrel.
I've often thought that I'd like to have a smaller diameter version for openings of under 3/4", but haven't done anything about it.
The Kirsten Kone is an extremely useful device if you are doing hollow vessels. I keep finding other uses for mine, too. As I hinted above, it will make an appearance in Hartford but not for a hollow vessel.
As long as you drew me out of lurking mode, I might as well mention that I've recently updated my website, so check it out if you are interested - www.artliestman.com.
Re: Kristen Kone
Steven Antonucci
Why would you need that?
steven antonucci
I turn lots of hollowforms and I don't understand how that would be helpful? I turn a cone with a tenon that I can grip in a chuck. I start my hollowforms between centers, so I always have a center mark when I reverse. I simply put the cone in the chuck, and the tailstock point in the original center mark. No muss, no fuss.
If I wanted to do a professional job, I'd probably wrap the cone with 60 grit and get a better grip. (Good idea, DH!)
Steve
Re: Kristen Kone
Re: Why would you need that?
Mark Wollschlager
rumor has it that it works by distributing the pressure.
Less friction required to drive the form at the opening. Just centering it there, not burnishing.
Putting most of the driving friction to the inside bottom where the finish is not so important.
You are also supporting the vessel near the cut.
Maybe its just one more tool in the arsenal :-) .
mark
Re: Kristen Kone
Art Liestman
The idea is to drive the vessel with solid wood between the drive center (at the inside bottom of the hollow form) and the tail center. That way, you can put as much pressure on the piece as you need to drive it while you turn away the waste wood at the bottom of the hollow form. If you have a thin walled vessel, you don't want to put a lot of pressure pushing from the top opening to the foot. With this system, you don't have to do that. In addition, you can make the foot the size and shape that you want without worrying about hitting your chuck jaws. The cone is simply to keep the top part from wobbling and doesn't have anything to do with driving the piece. That said, if you don't need it, don't worry about it. To me, it's a very valuable tool.
Re: Kristen Kone
George Balock
George Balock
Thanks to all for the info. I'll be looking to make a buy soon.
George
Re: Kristen Kone
George Balock
George Balock
Jamie,
I'll be in Hartford if you want to do a deal. How much would you want? E-mail me at gbalock@hotmail.com
George
Re: Kristen Kone
Re: Kristen Kone
John Scheideman
I bought one of the originals through Joe Fleming several years ago when they did their production run and I have used it constantly. I would hate to be without it.
Re: Kristen Kone
Terry Scott
Steve on allot of my forms the neck wouldn't take the stress as they are so thin so supporting at the bottom as well spreads out the forces and load
Or alternatively I have finished the carving on the work before I take off the bottom so I need to place something on the inside bottom
My view
Plus its another tool us toola- holics can add to the kit l.o.l
Re: Kristen Kone
I don't turn that many vessels, but the ones I turn are often out of spalted wood and seem to be very fragile, especially the top shoulder that is very short grain. I would be sure to ruin a few if I set a cone in the opening.
I made one of these out of wood. Most of the openings in my vessels are about an 1" so I turned a piece of hardwood an inch in diameter about 12" long with a taper on it that matches the taper in my lather. (Just copied the one on my drive spur.) Put it directly in the head stock, slide the vessel up over it and bring up the tail stock. A piece of carpet pad in the vessel will provide extra drive friction and can be removed with a wire bent into a hook. I leave the tailstock center mark on the base of the vessel just for this purpose. It appears it doesn't matter if the stick is perfectly straight, the tailstock centers the vessel nicely even if the stick continues to wobble. If the stick is too slender, I just wrap blue tape around the shaft until I get a loose fit. I suppose I could make or find some collars for that purpose. To avoid throwing it away I name it Dicky the Stick. You can make one in a few minutes out of a scrap. You could have different diameters and lengths for different jobs. You could make one even faster if you mounted the stick in your shuck and turned it, but I am not sure it would center up as nicely next time.
Re: Kristen Kone
Steven Antonucci
Thanks- I get a little burnishing,but it sands out
steven antonucci
pretty easily. I can see that have the support at the cutting point might be valuable, but for the vessels that I make, I don't know that this would be any use. The cone is too big to be used on smaller vessels with small opening (I think?) so I assume that this is aimed at larger vessels with openings of 1" or more?
Probably the way to do it is to have omething like this incorporated into some kind of donut chuck rig. Full access to the bottom, support where you need it, and two points of friction to drive the vessel (cone and donut. Anyone want to make a fortune? I get 10%...LOL
S
