spindle adapters and inserts
Carol Reed
I need to get my chucks to fit on my 1642. I have three, two of which have 1x8 inserts for the Jet mini lathe. The third is a Nova compact which just is 1x8.
What is the downside to getting a spindle adapter for the 1 1/4x8 1642 spindle to 1x8 that fit my existing chuck inserts?
Re: spindle adapters and inserts
Bill Howatt
If the adapter is well made, that is, it runs true, then not too much.The truest the chuck will run is when it is directly fastened to the spindle.
Bill
Steve Kubien
Steve Kubien
I wouldn't get a spindle adapter to go from 1-1/4" to 1" because you are introducing another variable which could add to vibration. Get new inserts. now, for your compact chuck, you have no option. I am in the same situation and I only use my Nova midi chuck with #1 jaws these days.
Gordon Seto
The spindle adapter from 1-1/4" to 1" is over 2" long. The overhang would have more stress on the bearings if the blank is heavy.
Doc Green
Carol, I have been using a spindle adapter on my PM since the day I got it to step down 1-1/4 to 1", as you are proposing. It runs true and has held up under some pretty heavy loads.
I think the one I have is made by Jet. It is solid black as opposed to metal-looking.
I like the fact that it makes the chucks, etc., stand a bit farther from the headstock. Gives a bit more room to work, and it's convenient when jam chucking a tall bowl because the walls can overlap the chuck. This reduces the length requirement of the jam chuck, in such cases.
FWIW, ~Doc
Carol Reed
Thanks, Doc. Another reason I had not thought of - the further extension.
Amazon has the Jet adapter for $55 and free shipping. Best Wood Tools has one for $10 more plus shipping. But it is shiny!
Still thinkin'
Cyril Griesbach
Carol,
I'm not familiar with the Amazon product but Best Wood Tools makes quality products. Just be certain it's steel and not aluminum.
Cyril
support the small local toolmakers
Local, that is, to John Lucas and just down the road from me. I've been impressed with those guys and have been happy with everything I've bought from them.
I could pick one up the next time I'm over that way and save the shipping but I would have to pay the in-state sales tax, however so it would cost about $60 total. You wouldn't get it until June but that might help make you REST YOUR SHOULDER!!
Bill Neddow
I agree with Bill. I have a Oneway and a Nova and use spindle adaptors so I can use my assembly of chucks on either lathe. I have used Oneway adaptors, and cannot tell whether or not I have an adaptor on the lathe as far as turning goes.
Roger in MO
Roger in MO
I have been happy with my PSI adaptor used on my 1642 Jet.
Roger in MO
Re: spindle adapters and inserts *LINK*
Fred Holder
Hello Carol,
I have spindle adapters from Craft Supplies USA for the 1-1/4" to 1" spindles and 1" to 1-1/4" spindles. They work very well. I have a Nova DVR and a Vicmarc VL-100 evs with a 1"x8tpi. My wife has a Oneway 1018 with a 1" x 8 tpi spindle. We change chucks back and forth using the spindle adapters with no problems.
More Woodturning magazine
$60 from craft supply..$20 from  PSI
bob davis
have one of each. work equally well
Harry in Beautiful Downtown Kulpsville
Carol, check out Penn State for spindle adapters. I have one to adapt an old Nova mini chuck to my 1-1/4 DVR lathe. It seems to run true and cost a whole lot less than some of the others. He
Mike Brazeau
I have a 1"x8 TPI adapter to use with my Talon chuck on my Oneway 2436 which is M33. If I tighten the locking screw too much it can throw the adapter out of alignment a small amount. Other than that works great and saves swapping adapters (which I have ) on the Talon when I want to use it on my Delta Midi.
