Pot life for open can of Waterlox?
david
>Waterlox(semi-gloss)has recently been my finish of choice. Seems to fill the wood pores and after a couple of coats where the liquid is not completely absorbed is ready for the Beale buff and a very nice finish. Problem I have been experiencing is that I can't get down to about 60% full on a quart can before the liquid starts to gel up on me. The second time it happened, I added mineral spirits thinner and the liquid thinned out nicely, but a couple of days later the solution was like thick molasses again. When thick, the solution seems to have a film on it and resists absorbing into the wood. I am terrible recounting the passage of time, but it seems like the can was opened fresh not more than three months ago. Is this common for others when working with Waterlox? Should I be thinking of purchasing smaller containers? Don't know if a pint size is available.
Re: Pot life for open can of Waterlox?
Dave (PacNW)
>You are running into the problem of the tung oil curing in the can. You can either, use a product like Blogyen (sp) to displace the oxygen or pour it into a smaller container. once a finish has started to cure in the can it's done, throw it
Dave(PacNW)
Play it by ear
>Waterlox is perishable but too expensive to chuck unless you really can't use it. I've found that a skin over the top of the finish isn't the kiss of death. The liquid finish under that film is still quite usable, especially if you're wiping it on with fingers or a rag. Once it starts to gel uniformly throughout the product, you can only hope to get some use out of it if you rub it on and wipe off the groaty stuff that's left.
Keep in mind that I'm a "waste not, want not" kinda guy. But I've been using Waterlox since it came in orange and yellow cans and cost $15 a gallon.
Carole Valentine
>I pour what I'm going to use into a jar, hit the can with Bloxygen and seal. Store in a cool place. Like Ellis says, the finish under the skin is still perfectly good until it starts to thicken. I have a meat basting hypodermic that I poke a hole in the skin and suck it up...just don't accidentally depress the plunger and blow air into the finish.
Leo Van Der Loo
Leo Van Der Loo
>I use a glass bottle that I keep full by adding water to the finish as I have used some.
The bottle lets me see how much finish is left, and the finish does stays just fine for well over a year this way, works for me :)
Mike from St. Clair Shores
>I have a bag of 3/4 inch glass beads from an old aquarium that I cleaned and I add them to the can as needed to keep the level right up to the cap. It's worked for me. I've also heard of people using marbles, ball bearings and rocks.
Mike
Dick Hines
Dick Hines
>I took my Waterlox and put in into some baby food jars. Then I stored it in a cool place, except in the summer, upside down. That way the film will be on the bottom. Make sure the lid and lip of the jar is clean before you reseal or you will not git onpen again.
russ faifield
>What works depends on the climate and the changes in humidity and temperature the Waterlox is subjected to.
Using water is a mixed bag. If you add it to the can you can't get it out without water coming with it. You can put it in a jar so you can see the water, and dip it, but the exposure to light makes it darker and it turns the wood darker too. You might as well be using Linseed Oil. Also the exposure to air during pouring and the open jar while using will shorten its shelf life.
I have tried rocks, marbles, and Bloxigen. None of them worked for me in North FL or Western Washington. I have tried nene of them in Idaho because I don't need to. Even decanting to a smaller container is iffy because there is enough exposure during the pouring to start it. It will keep well as long as the container is closed, but goes quickly after it is opened. The container is also important, because plastic food containers were made to keep in the mustard, and water vapor and oxygen molecules pass quite quickly through the plastic, so they do little to nothing to extend its life expectancy. You have to use the Nalgene squeeze bottles from the beauty supply or the scientific supply. There is a problem with baby food jars because once opened the seal is never tight enough to keep the water vapor and oxygen out of the jar.
The only thing that really worked for me was knowing that it took 2 weather cycles after the can was opened to push Waterlox over the hill, and the best solution was to buy a small container and use it up before the seasonal change. It has a pot life of about 2 years here in Idaho where the humidity is lower. I have never bought Waterlox by the gallon because I always threw away half of it.
I prefer to mix my own because the Tung Oil will last for several years when they are stored separately, but rather quickly after they are mixed.
Bob Moffett
Bob Moffett
>Russ, what is your mixture that you use?
Ric Taylor
There is No Need to do Any of Those Things
Ric Taylor
>There is no need to use rocks, marbles, special gasses, unique containers, storing upside down or anything else. There is nothing wrong with the Waterlox.
As Ellis said, under the crusty film, the Waterlox is just fine. All you need is a pipette or a straw to poke through the film, and draw the good Waterlox up from below. My current can was opened nearly two years ago in a very humid climate, and it still has all of the characteristics of Waterlox right out of a fresh can. It works just fine. Don't make life so hard.
Ric
Leo Van Der Loo
Re: There is No Need to do Any of Those Things *LINK*
Leo Van Der Loo
>I thought the Manufacturer would know best on how to keep the finish good.
so I had a look at their site, and it is just like I thought, they do tell you how to prevent the finish from going bad.
Just as my experience has been with Polymerized Tung oil, keep the air away from it and it will keep indefinitely, as it polymerizes with oxygen, (can't be reversed), now maybe if other ingredients are in there, like a varnish, it might be still good varnish in there after the tung oil has gone hard.
http://www.waterlox.com/site/492/default.aspx#dry
