Sanding pads
Sanding pads
Roger in MO
Sanding pads
Roger in MO
>What is a good source for 2" velcro sanding pads? ( see below post)
Thanks
Roger in MO
Re: Sanding pads
Re: Sanding pads
david
>Try Steve Worcester or The Sanding Glove.
Re: Sanding pads
Re: Sanding pads
Jerry Hall
>Others are more expert than I but I have two thoughts:
First slow your sanding speed way down. Maybe use a drill at maybe less than 1000 rpm. Heat is the enemy of sanding I have been told, and found it to be true. The cheap harbor freight VS close quarter drills are worthless as drills, except they seem to last forever for the less demanding sanding task.
Second re pads: You can make your own pads any size and custom shapes, cheaply, with old twist-on 3M roloc disks. I hot glue blue sleeping pad foam padding to the roloc. The foam is $5 at Kmart or sporting goods store for a lifetime supply. You can use any foam and thickness that has characteristics you like. Then I hot glue a 1" wide heavy duty hook piece to the foam. The hook tape is available from any fabric store, or sometimes art supply stores. I make one pad for each sanding grit so it is a fast twist on twist off from the roloc holder. Auto shops throw away the used pads and they work fine for this purpose. Introductory packs are available from some auto supply stores for less than $20. I dedicate one drill with an extension and another without. See pic.
Infrequently you have to break out the hot glue and refasten stuff, or the foam breaks down a bit and you tear it off and replace it. A fast and easy fix.
I use Klinspoor 4" wide loop roles and rough cut little rough octagons in 2" and 3" sizes in small batches as I need. I find it is inexpensive and good quality. It doesn't have to be perfect round cut.
Re: Sanding pads
Re: Sanding pads
Thad
>I picked up a variety of 2" hook&loop disks from Klingspor a while back.
Can't seem to find them on their website, but maybe in their catalog.
Re: Sanding pads
Re: Sanding pads
D. Hansen
>vinceswoodnwonders.com or industrialabrasives.com
Industrial abrasives has 1 meter x 36" sheets that you can use to cut your own at about $18.00
Re: Sanding pads
Roger in MO
Re: Sanding pads--Thanks
Roger in MO
>Thanks for the responses. I'll check these out Roger in MO
Re: Sanding pads
Re: Sanding pads
Vince Welch
>HI Roger,
I have a variety of sanding pads available. Feel free to contact me for more info. www.VincesWoodNWonders.com
Vince
