Chainsaw chains
Paul Zerjay
>Just wondering how many extra chains you have. I cut a lot of wood, mostly for heat, and I have eight. Is that a lot? Average? Or low?
Chainsaw chains
Paul Zerjay
I have 4, but only one good one
steve antonucci
>The other three are for jobs where there might be buried metal or rocks in what I am cutting. They have all been used many times, and I should probably toss two of them...
Steve
I have about 4 - but one that kicks a$$
KurtK in Indy
>I was turned on to a chisel chain in an article I read somewhere. It really tears through wood and I highly reccommend one or two for anyone's supply.
Hope the subject wasn't inappropriate
KurtK in Indy
>I guess I let er fly before thinking about it. Sorry Ellis and all.
Re: I have 4, but only one good one
Ken
>I lost count,I have some older ones that I take to cut the rough wood with,where the may be a lot of dirt or rocks in.But if they get in to bad of shape,or if I hit a rock or piece of metal.I toss em,because its almost impossable to get them sharpened right after that and it makes the saw work twice as hard.As to whether you have to many though,NO! you can never have to many.I think I have about ten saws (I think)
Re: I have about 4 - but one that kicks a$$
DC Powers
>For those of us who don't know, what is a chisel chain and
where do you get them? Cost?
Thanks.
KurtK in Indy
>I have a Stihl saw and went to the parts counter. The chisel chain has a more aggressive tooth design that really hogs out the wood. The cost as I recall was about 20% more than a standard chain. I was given a caveat from the parts guy that this chain can be very aggressive and pay close attention. I was told pro loggers use these as it makes their cutting go much quicker. But it has a greater risk of kickbacks, especially when cross grain cutting. But cutting with the grain...its like a warm knife through butter.
Re: Chainsaw chains
Mfoster
>I have 5. Like you I cut my own firewood off of my property (100 acres of woods). I also do a lot of maintenence of the woods, so am friendly with my chainsaw. I have a number of chains mostly because as I have been cutting around our fields, I tend to try to cut some of the smaller trees near the ground and hit the dirt more than I care to admit. Remarkably, this tends to dull the chains rather quickly. I finally decided it was worth it to buy an electric chain sharpener. This was a great investment. Now I usually have 2 or 3 sharp chains with 1 or 2 waiting to get sharp.
Re: Chainsaw chains
>I like to keep 2-4 extra new chains on hand for each saw, in case of severe damage. A local farmer's co-op has chains and bars for 1/2 price a couple of times a year. I keep an extra bar for each as well in case of damage.
(An extra bar and chain are very handy if you get the saw jammed. Just remove the head and install the extra bar to cut out the jam.)
I sharpen until only a nub remains and keep the old chains for cutting roots and things.
Re: Chainsaw chains
DC Powers
>Where's a good place to get an electric chain sharpener. It cost 8.50 to get it sharpened at the saw shop I use which is about 1/3 the cost of a new chain.
I have 3 and one extra bar.
>I have the extra bar for those times when I trap the saw in the cut and can't get it out. It doesn't happen often because I'm getting much better at reading the trees but sometimes no matter how hard you try it just flex's the wrong way. I've got wedges of steel and wood and always carry an ax just in case. I think taking the extra bar has probably made it so I don't need it.
good point
steve antonucci
Re: Chainsaw chains
bill Crommett
>Anyone who hasn't knocked a tree over backwards either lives in a real windy place or else hasn't done much logging. My chainsaw shop used to charge me $3.00 to sharpen a chain, so I always had a couple of chains ready to go after hitting the dirt -- or cutting into a punky log that has been down for several years.
Re: Chainsaw chains *LINK*
>DC,
I bought an inexpensive Oregon sharpener at Northern Tool but there are many suppliers. My favorite chain saw and logging accessories place on line is Bailey's.
You don't need a very expensive sharpener if you don't saw professionally.
I use the sharpener when the chain needs a lot of work. Many people use a Dremel and a stone. Before I got the sharpener I used this when I hit a rock or metal and had to clean up a chain. Most of the time I use a file. Two licks on each tooth with a file in the field after every couple of tanks of gas will keep you on the cutting edge.
If you are paying 3x $8.50 for a chain you must have a really big saw or you're paying too much. I just bought a bar AND chain for my Stihl 250 for less than that. Check the prices at Bailey's.
Re: I have 3 and one extra bar.
I noticed that too - if I take an extra bar/chain or extra saw seems like I never get jammed.
I'm amazed at how well wedges work. I use the cheap plastic wedges that don't hurt the chain if I run into them. I'll cut a large suspended log straight down from the top about 1/2 way, drive in a couple of wedges, then finish the cut. The wedges hold the kerf open so I don't have to cut upwards from the bottom.
Re: Chainsaw chains
DC Powers
>Thanks John. I have a Stihl 290 with a 20 in bar.
Paid $25+ for new chains at the local saw shop.
Checked and got a similar price from Ace Hardware.
Is there anything special about Stihl chains? (Except the price)
I'll check out the link. Thanks
Re: Chainsaw chains
Terry Quiram
>2 chainsaws, 3 chains for each.
Re: Chainsaw chains
Mike Nelson
>"Used to" is right on sharpening, I used to pay a couple bucks, now they want five! Is there an inexpensive sharpener out there??
Can I use...
Steven Kubien
>...a non-Stihl bar on my MS390? It would be nice to have good one in the 22" range and keep the 18" which came with the saw as a back-up (or whenever I get the big one stuck).
Do I have to use a Stihl bar and chain?
Thanks,
Steve Kubien
Re: Chainsaw chains
I don't know - I've always bought Stihl since they were available and reasonable (especially at 1/2 off!). They do have a line engraved on the top of each tooth to indicate the sharpening angle and usable life, but maybe other chains have the same. The chains and bars I just ordered from Bailey's are a different brand, so I don't know about them yet. However, Bailey's is well respected according to posts I've read on the logging/sawmill forums so I'm optimistic. (I would normally buy the Stihl but I needed a chain now since I'm down to one spare for that saw.)
Note that Stihl (and probably others) sells two kinds of chain - a "green" which is less grabby and a "yellow" which cuts better. You choose. Stihl officially recommends the "green" but I'm sure that's a liability issue.
If you do a LOT of sawing, you might check into bulk chain. I calculated the chains would cost about $6.50 each for my 16" Stihl if I bought a 50 ft spool. A good set of chain breaker and installation tools would be about $100 so it would take a few chains to come out even, but after that it would be cheaper to throw the chain away rather than pay $8.50 to sharpen!)
BTW, according to one book I have there is a good reason to never pay a shop to sharpen a chain. The author said they set the sharpener to the worst tooth and sharpen them all to that. This can waste an incredible amount of the potential life of a chain, since much useful steel will be ground away on the other teeth. When you do your own sharpening you can remove only what is needed on each tooth. (There is no truth to the rumor that all teeth have to be the same length - a few teeth longer or shorter will not make any difference unless all the short teeth are on the same side. In fact, a chain cuts just fine with a tooth or two missing completely.)
Also, you probably know this, but make sure to check and file or grind the depth gauges as needed as the teeth are shortened, otherwise the chain won't cut well (the wood will be riding on the depth gauges rather than being removed by the teeth.) Some shops that sharpen (including my local saw shop) don't even know this. You can buy a very inexpensive tool to check the depths. Some chain grinders include a special wheel for grinding these, but I just use a stone on a Dremel. You can use a flat file but the steel is pretty hard, at least on my chains.
Re: Can I use... *LINK*
>Lots of vendors sell bars that will fit your saw. I think more companies make them to fit the Stihl saws since they are so popular. I checked my favorite supplier (Bailey's) and found them from about $40 to $100+. I saw a variety of brands in 20" and 24", but not 22". I'm sure others have them as well. You might save a little with the bar/chain combos.
BTW, I have a 24" on a Stihl 361 and while it is great to have the length at times, it does make for a poorly balanced saw - I think a 20" bar would have been a better choice for that saw. The little Stihl 250 is by far my favorite for everything up to 28" or so. The longer bar is most useful when ripping big chunks for bowl blanks. I used it once to cut up a 48" white oak.
http://www.baileysonline.com/itemdetail.asp?item=WBC+20+SS50&catID=691
>I have 4 chains, 2 16" and 2 18" and the corresponding bars, as John pointed out, carrying an extra bar is a self rescue approach, the ax is the back up. I also carry plastic wedges, those will not hurt my chain if it touches them.
Use the 18" for felling and the 16" for everything else. I buy a new
chain every year, they last me about 2, and they get sharpen with a file and get discarded before they are down to nubbins, I don't feel safe with a chain that is not sharp.
Jorge
Re: That extra bar...
Gary Evans Tallassee, TN
>keeps Murphy from coming along on the job. I've only had to use mine once since I started carrying it. John K. is the one who posted the tip that got me started.
Gary
Re: Can I use...
Steven Kubien
>Fantastic John. I wondered if since Stihl is only available through authoruzed dealers then maybe makers of bars and chains wouldn't bother of something odd like that. Thanks for the info.
Steve
P.S. I will remember what you say about balance and longer bars. That's something I wouldn't have thought of.
Re: Chainsaw chains
Roger in MO
>Mike, I've filed by hand for maybe 50 years. It takes maybe 10 minutes to touch up a chain, holding the saw in a vise and sharpening the chain while it is on the saw. I normally have only one chain per saw but I will take two saws if I'm working away from home.
Roger
