Re: Sure beats the .41 method
Juergen
>I tried your method as best as I understand it and the numbers just don't work for me. Can you provide more detain on the layout. For example if the diameter is 100mm and it's multiplied by .41 that's 41mm If you lay it out by measuring 41mm from the left and then the right you end up with an 18mm division in the center. Then if you take 42mm and divide by .5, that's 82mm. How is this layed out?
I spent 5 hour with Soren and this method, as I understand it, isn't even close to what you get with the caliper. One thing I did notice with the caliper is that the layout of the cylinder was not in 3 equal divisions. The left and right divisions are smaller than the center one .
