Re: Oneway Vari-grind jig
Gordon Seto
>"My understanding is, that the distance that the pocket is from the grinding wheel set the side/wing angles, and then after that, adjusting the angle on the Veri-grind will establish the nose angle."
Which changes which is not important, and they are just some of the variables in setting the Varigrind jig.
For the sake of argument: If we are just using the pocket (not using the Varigrind) when sharpening SRG and traditional grind bowl gouge, the distance of the pocket sets the nose angle. That is very close to setting the Varigrind at the top notch. There is no side grind. We move the pocket closer, the nose has a steeper angle. Every notch we move the leg towards the bottom, we can get a longer side grind. If we lock down the leg to the bottom position, we can get all the nose angles by moving the pocket in and out but they all have very long side grinds.
I know what I say is opposite to what the sharpening DVD said.
Just as I said, the terminology is useless. The only things that matter are the right combination for your style of using your tool.
I don't think there is a magic tool and grind that will fit every turner. Mike Mahoney, Stuart Batty and David Ellsworth are some of the best bowl turners. Richard Raffan, Nick Cook and Alan Lacer are skew masters. They don't even agree on the best tools and have the same grind. Probably none of them is setting the jig at 22.3776� or most are not using the jig at all; I doubt they would reach another level by doing so either.
Gordon
