Calif. Buckeye Vessel
Bill Clark
>This is another piece in my California Buckeye series. This vessel is 7 �� in diameter and 4 � � tall. The entry hole is 1 5/8�. The piece has a �disappearing� base and sits on a 1 �� turned flat spot on the bottom. The walls are 3/16� thick. It is finished with 2 coats of shellac to seal the soft wood, then 3 coats of satin MinWax Wipe-On Poly. The vessel is also sanded and finished on the inside. The blank for this piece was taken from a much larger Buckeye root ball. It�s been very interesting watching the differences in figure and color display themselves as each piece is turned. It�s like opening a series of surprise packages and not knowing what to expect inside.
All comments/critiques welcome.
