turning tool holder
Bob Haines
>Hello,
I am looking for suggestions, drawings, photos, etc to construct a lathe tool holder. Anyone that has a particular design that they are happy with, I would appreciate your input.
thanks,
Bob
turning tool holder
Bob Haines
>Hello,
thanks,
Bob
Re: turning tool holder
Troy German
>I don't know how to link to previous threads, but this is the header info for a thread that will help you:
Subject: Tool holder -this rack reduces .... *PIC*
Posted By: Jamie Donaldson jdonaldson14@aol.com
Date: Monday, 22 January 2007, at 3:49 p.m.
Bob Moffett
>There are plans for one in this months Wood Magazine. It fits on the end of the lathe and swings out.
david
>Bob: Here is one option. Built an A-frame on top of a standard rolling utility cart. Pegboard went over the frame. Plywood backing with PVC (1-1/2", I think) cut for holders. Little shelf in front holds lathe accessories, drive spur, live center, etc. Attached a bar with dowels to hang faceplates underneath, which also includes shelf slots for sandpaper sheets. Vacuum chucks are on the top. Vinyl sheet covers tools when chips are flying--saves on clearing off the stuff later. Opposite side has similar arrangement. Pegboard hardware used for hanging whatever where there is room. Had to put a weight on the bottom of the cart because everyting was top heavy. What I need to do is cut down the height of the PVC pipe--shorter tools barely peek up. I like the ability to see the tips of the tools rather than them being point down.
Jorge Castaneda
>Here is a picture of the one I have now, it took all of 30 minute to create. It is funky but serves its porpouse, as you can tell Now I need a larger solution, too many more tools than when I started.
Jorge
Peter Hyde
>This one sits on a Workmate alongside the lathe. It has a lazy susan bearing in the base.
>Obviously you all haven't gotten all the e-mails I got after putting the tip in American Woodturner about a tool storage bin. It had the tools with the cutting edge up. Carl and I both got lots of mail telling us how stupid and dangerous that is. Oh well. I feel better after seeing that someone else does that also.
tripods and self timer
>I forgot to mention that shooting at sunset and indoors will usually mean the camera should be supported someway, not handheld. A tripod and cable release are best. If you don't have them try proping in up on a chair back. Then use your self timer to let the camera take the photo. This will give you 2 hands to steady the camera on whatever support you have.
Five gallon paint bucket
Stuart Johnson
>with holes in the lid. The tools are stored point down in the bucket with each hole labeled such as skew, 3/8 spindle, scraper etc. The only problem is trying to remember the skew goes in the scraper hole, the bowl gouge in the skew and so forth. You can see the problem of only seeing the handles.
I think the need to have twenty or so tools at your finger tips is over rated. How many are you going to use? I normally take out the tools I am going to be using and lay them under the ways. If it turns out I need something not already selected I just bit the bullet and spend the 15-20 seconds it takes to go pick it up.
keith tompkins
>Hey John, I've always been taught that a craftsman NEVER places his tools on the cutting edge. Planes are stored on their sides, etc.
Robert Henderson
>Bob,
That looks like a very cool support jig you have there.
Can you give us some details as to use and construction?
eliot d
>I don't like that one because it effectively shortens the lathe bed. (Of course,if you need the lathe bed space, you could take all the tools out and remove it, but who wants to do that?)
Re: turning tool holder *LINK*
Mike Brazeau
>Here is a lazy susan based holder I put together about four years ago and am still happy with. I have added some more holes to it since this picture was taken. The cabinet below holds all kinds of turning related stuff in a semi-sorted fashion. Also have a project oriented one in next post. More pics on the construction at my photo site at the link in My Tools & Jigs album.
Mike's Photo Gallery
Project oriented tool stand
Mike Brazeau
>This is one designed to hold the tools for any particular session, but also a handy place to toss sandpaper, small bottles of finish etc. I have added a projecting tray in front with 1" holes for tool rests, blue handled hex key for Oneway chucks etc. On the right I keep miniature tools and on the left centers, jacobs chuck, keys for Oneway chucks etc. Again very happy with it. Have to have a clean up/purge session every once in a while. It sits beside the lazy susan/cabinet. This is an old picture when I was temporarily tuning in the basement before I got setup in my garage. It stands on a piece of 4x4 that was my mailbox post before a truck backed into it!
Re: Mine too, John, point up.
Allen Neighbors
>I made this one by building an A frame on an old gurney base, and it is very useable, to roll around wherever I need it. If I'm going to be turning offside, it's there, if I'm going to be onside, it's there.
Points up on my Oland tools and scrapers, etc, so I can see the installed cutting tip. It's large enough, alright, and sometimes I think it's a little too large. But I have room for it.
Never, Ever
Ron in Drums PA
>Never ever place your tools cutting edge down. That's how I learned with my wood planes and still makes sense with my turning tools.
Re:Hey Mike- mount that stand on .....
Jamie Donaldson
>.. an old chair base with rollers and it can follow you around the shop! You might be able to put casters on that base if its wide enough.
Mike Brazeau
>Hi Jamie. I actually have bought some castors but haven't got around to mounting them. When I want to work on the outboard end of my 2436, I need to rearrange stuff somewhat and it will be useful to just roll out of the way instead of dragging it. Must get to it, because bowling is a lot more fun on a short bed.
Some weaponry Allen
Mike Brazeau
A few ideas...
Peter Teubel
>I keep all my turning tools in one large cabinet. I built small tool holders for each of my lathes. They hold enough tools for a particular project that I'm working on at the time.
rolling cabinet
>Wow Peter, nice. You obviously have a lot more room than I have. I bought a tool cabinet and put the tools I use most around it. Keeps the tools point down and safe and since they are always in the same order I know exactly what tool I'm grabbing. The only problem is when you get new tools there's no where to put them, consequently they are 4 tools laying on the top.
I should have put 2 shelves for each set of tools so they stay reasonably straight. They tend to get shavings between the ferrule and wood and they all sit crooked most of the time. Not a big deal unless your anal like me.
THANKS FOR ALL OF THE GREAT IDEAS!
Chicago Bob
Re: A few ideas...
Allen Neighbors
>You like calipers, don't you, Peter? :o)
That really is a beautiful, well organized, and stocked, tool chest.
Re: Some weaponry Allen
Allen Neighbors
>Good for a 15" vase, endgrain. :o)
Here's my setup
John Carr
>Yes, I store them point up, but against the wall they're fairly safe, as long as I'm careful taking them out and putting them back.
