Soon-to-be-bowl???
Soon-to-be-bowl???
Soon-to-be-bowl???
Allen Neighbors
>Here's a shot of a blank that has the propensity to become an 18" bowl. The blank is green... I want to turn it to finish, so it will do funny things to itself while drying out. I don't know what it weighs, but I'm going to ask for help to lift it up to the lathe. I think it's probably 70 or 80 pounds. (I don't have a faceplate larger than 3".)
My question is this: Will a 3" Oneway face plate, with 8 #12 2" wood screws hold it?
Allen
Re: Soon-to-be-bowl???
Re: Oh, yeah... it's about 7 " thick
Allen Neighbors
>at the thickest point... and that's an 18 inch ruler.
TDaniel
>Sure will Al, go to it! I rarely use anything larger than a 3" faceplate but I only use the thick ones like One-way. The #12 screws are big enough if they are good quality screws.
TD
Re: Great!!
Allen Neighbors
>Thanks for the info, TD. Now if my Son will only drop by... :o)
Gotta get that A-frame built!
Thanks,
Allen
...Depends on the size of the catch you get ;-)
david
>I doesn't look like you will be mounting in end grain, and the only problem I see is a massive catch (come on now--we all get impatient sometimes and hog off too much material at once).
Re: ...Depends on the size of the catch you get ;-
Allen Neighbors
>David, I'll be so scared with this bowl, that I'll probably take all day to turn it. :o) I don't think I'll get in a hurry.
It will be the largest chunk I've turned so far.
Allen
Mike from St. Clair Shores
>Allen,
I always bring up the tail stock while I'm roughing the outside and making a tenon. Then when I put the tenon in the chuck I bring up the tail stock and remove as much of the interior as i can which leaves a tenon about 1 1/2 inches and when I get the tailstock out of the way I remove it and then finish the interior after most of the weight is gone. It's not that scary. You will do great. Just post the finished bowl pic tomorrow so we can see it.
Mike
Re: ...Tomorrow?? Gotta wait on help.
Allen Neighbors
Bob Fawcett
>Go for it.
You have the lathe to handle it.
Start slow, and bring up the speed as it gets more in balance and lighter.
I know I don't have to tell you this, but I had to say something relevant.
Leo Van Der Loo
Re: Soon-to-be-bowl??? *LINK*
Leo Van Der Loo
>Hi Allan
Allan if your blank is not to much off balance you should be OK, I have turned a 15"x6" black cherry on a wood worm screw, and 24"x8" (finished) willow burl off centre held by just 4 screws, My faceplate that I use most is approx. 4"D and I use 1" screws or 3/4".
I'll put a pic. here that shows a 22" half log Sycamore that I turned held on with 9 screws 1" long.
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum26.html
Barbara Gill, Remlik VA
>I bought a 6" faceplate for those large blanks. I never tried the smaller but if Terry does not have a problem with those big blanks he uses; it will probably be ok.
Brian Simmons, Heflin, AL
>On larger pieces I have attached a 3/4" 7-ply plywood disk to a smaller face plate. Any increase in diamter counteracts the leverage that a bumby surface near the screws can create. With the plywood disks I can install the screws where the blank makes contact for the best rigidity. If the surface is very irregular, I glue support blocks between the plywood and the blank before installing the screws. Best of luck!
Be sure to use your tailstock
Bart Rhoads
Re: Thanks, Folks. Appreciated.
Allen Neighbors
Stop! Make a hat, it just the right size.
Doug Thompson near Cleveland
Re: Stop! Make a hat, it just the right size.
Allen Neighbors
>I have a hard enough time trying to turn bowls. Wouldn't even think about trying a hat. :o) My expertise (if it could be called that) isn't perfected to the point I can do anything of that category. It'll take several more years practice, first.
Allen
>You would do just fine... no kidding. If you are ever in the neighborhood I will show you how it's done.
A little rambling;
I'll start a blank like that on a faceplate with 10-12 screws. Turning starts at 150 and as the corners are knocked off the speed is increased slowly. When the blank is round the speed is around 400. The lathe is then stopped and I start looking for cracks. If no cracks are found the speed is increased to 6-700rpm's. Then the shavings fly.
Have fun,
Doug
