walnut mirror
>Here is a walnut mirror I finished with Tru-oil. I'm going to make a second one just like it but finish it with Lacquer to the same sheen. It will be interesting to see the difference.
walnut mirror
Re: walnut mirror
Chris in KC
>John,
When do you sleep?? I do believe you are one of the most prolific artists ever. Each facet of your woodworking is amazingly elegant and yet you have the time to be a renowned instructor and educator, let alone photographer. We're very lucky to have you and your inspiration. Very nice work, as always.
Wow! That is some finish!
David
Re: walnut mirror
>Very pretty. Great grain on that walnut.
Re: walnut mirror
>Chris Actually I get frustrated because I have so much to do that it keeps me from turning. I guess I'm one of those people that has to always be on the ball doing something. Thanks for the comments.
Re: walnut mirror
Carole Valentine
>Wow, that's some beautiful wood, John. What is True Oil? Looks like sort of the same thing as Waterlox. How many coats did you have to build to get that sheen?
Re: walnut mirror *LINK*
>Carole It is Birchwood Casey Tru-oil. it's a gunstock finish. You can buy it in Walmart at the gun section or probably any other good sporting good store. It is a wipe on varnish. It took 10 coats to get there. I don't believe it's as nice looking as a lacquer built up that thick. I'll know better when I finish the next mirror because I'm going to finish it with lacquer in the Mark Kauder technique so that I can explain to my club the difference.
What I do like about it is it's durability and ease of application. You wipe it on, let it dry and then steel wool almost all of it off until all you see left are shiny spots where it has partially filled the pores and defects. Then apply another coat and do the same. I do it late each day and first thing in the morning. Eventually (6 to 8 coats) you have filled the pores and when you steel wool you get a nice even matt sheen. then apply a couple more coats and your there.
It has tiny streaks under the finish(no one but us picky turners would ever notice). I think this might be due to 4/0 steel wool not being fine enough. I think I may try sanding the last few coats to a much higher sheen. I did do a final buffing with the Beal system but it almost doesn't need it. It's one of the easiest high quality finishes I have tried. I've done several gun stocks with it and they hold up really well to abuse.
http://www.birchwoodcasey.com/sport/index.html
Re: walnut mirror
Ron in Drums PA
>All of the work you posted is really nice John.
I stopped using 4/0 steel wool for the reasons you mentioned. I now wet sand the finish with a fine grit paper (anywhere from 800 to 2000 depending on what I what to achieve)
(Russ correct me if I'm wrong) I think 4/0 steel is about the same as 600 grit sand paper
Re: walnut mirror
Wayne Leach-NW Ontario
>Hi John,
Looking at the image, it would be hard to beat that finish. It has such a deep 3dimensional look about it.
I will definitely pick some up next time I go to Wallmart.
Lovely work as usual!
Regards,
Wayne
chris rolke
>i bought a gallon of it from bosesguns (cheapest place on the net) $42 shipped to the door
here
Re: walnut mirror
>Ron I think it might be a little over 600 because I polish the Clear Inlace and Corian by finishing to 600 grit and then a finer polish with 4/0 steel wool. I also wondered if the cheap steel wool I use probablly has oil in it. I thought about buying some of the Liberon steel wool. Of course I already have sandpaper to 1500 grit so I'll probably try that next.
Re: walnut mirror
>Chris How do you store it? I've had lots of trouble with is skinning over in the small bottle. Thought about trying TD's trick of storing it in a mustard jar upside down so the skin is on the bottom when you pull it out to use it.
Re: walnut mirror
Ron in Drums PA
>How about storing the oil in mason jars that are topped off?
Re: walnut mirror
Bob Fawcett
>I bought some of that expensive bloxygen stuff to help with storage of waterlox, then I read on this site that someone else was using propane from their torch to displace the oxygen. Thats a lot cheaper solution, especially if you already have a torch. After reading that it dawned on me I have a MIG welder and the shield gas should work. I think I have at least a 50 year supply sitting on the back of the welder.
Try this in combination with the upside down jar and you should be good. For that matter the upside down trick should work with the original can you just need to sit it on a block of wood next to the cap.
YA -- Wow's right !
Brad Vietje
Re: walnut mirror
Norm Smith in Nova Scotia
>Hi John,
That is a real sharp finish. I will be looking forward to seeing the comparison.
Norm
Re: walnut mirror
Carole Valentine
>John, I'm beginning to think the trick is upside down. I started turning my Waterlox half cup mason jars upside down (after a shot of Bloxygen) and it lasts a LOT longer. Though mason jars are air-tight when you use them for canning (cooling of the contents draws a vacuum), when you just screw the lid on by hand you cannot get an airtight seal. Turning them upside down keeps air out. It also should be stored in a dark cool place. Before I started turning the jar upside down, my Waterlox would last about 8 days before geling, even with Bloxygen. The current jar (stored upside down), which I have been using for at least 2 months is still good.
Re: walnut mirror
Mike from St. Clair Shores
>John,
Excellent looking piece, again. You never fail to amaze me. Also thanks for this post, I read all the responses and it turned out to be quite informative.
Thanks,
Mike
Re: walnut mirror
chris rolke
>right now i am pulling out wat will fin the the small containers and going from there
Re: walnut mirror
bob davis
>AMEN
Wowza! Beautiful design and execution.
Jack Savona
Re: walnut mirror
Barry Turner
>John, this one is gonna be a hard act to follow........you've got your work cut out for you to improve on this one.
Stirred but Shaken..
Gerry Meekins
>Bob,
No need to turn the can upside down if you are using �Propane� it�s heavier than air.
Also, be careful turning Waterlox upside down. (Not sure about Tru-Oil) It will glob up on you. (Had it happen.. 18 bucks down the drain!) The rep at Waterlox told me to stir Waterlox, never shake it or you will get globules.
Gerry
Another Nice one John!
Gerry Meekins
Re: walnut mirror
eaglesc
>Beautiful work and finish on the piece, John.
What is ironic is as I read your account of the method you used with the tru-oil I was getting a Deja vu experience.
The way you described finishing the piece is essentially the same way I use Deft lacquer including the intermediate steps about filling in the pores and gaps until a uniform surface is achieved.
The difference being I use MM 1-9 between coats as opposed to the 0000 steel wool you used.There have been times when I had a "heavy" hand I left the telltale scratches you described...back up und start over again if the blank was a "special one"
The amount of coats is about the same.
AS far as cost goes I think the Deft is quite a bit cheaper and it seems the amount of effort in the application are the same.
