Milwaukee bearing help
Ed Moore
>I messed up the rear bearing in my Milwaukee drill last evening. I have the replacement bearings, the drill is apart, and I have the armature. And since I bought some of those 1/4" Enco bearings I am delighted to learn that my drill has a 1/4" shaft.
First: THANK YOU ED KELLE for posting the picture with daigrams because my switch handle and associated parts fell out.
Second: I seem to remember someone posting directions to follow when replacing the bearings. I have not succeeded in finding those instructions and would appreciate any help available here.
Apparently the first challenge is to remove the rear bearing without destroying the plastic fan. And the second challenge is to put things back so that the drill works.
I am beginning to realize how much I value Wood Central and that I regard it as a first line of defense. Much appreciated.
Ed
Re: Milwaukee bearing help
Go ahead! Laugh!!
Ed Moore
>Got that rear bearing off rather quickly, went to put on the new bearing ... now where did I put those bearings. Half an hour later I found them. Took off the retaining ring on the front bearing, then the bearing. I started to put the retaining ring back on and .. oops! The ring sprang off the shaft and I think I know which corner of the shop it landed in. No sign of it. So, off to Lowe's ... and 45 minutes later we're back in the shop.
Now to put it back together.
Ed
Laugh? Not me!!!!
>I have fired too many things into the nether regions of my shop. My advice would be to set up a "Clean Room". Probably should get inside a large bag, maybe a white cotton mattress cover or something and do the assembly in there. At least all the exploding parts would be inside the bag. I lucky though, Lowes is almost in sight of my house and so is Home Depot. Made many a trip to rebuy something that was just a little "springier" than I thought. Good luck.
Re: Laugh? Not me!!!!
>Ed and Barry As a former camera repairman I can't tell you how many times I've been searching the floor for itsy bitsy teeny weeny really tiny screws and springs. Looked for a spring for over an hour once. Gave up and went to take a shower. Found it in my hair. That was the 70's and I had an Afro. Don't laugh or I'll have to find a photo.
so YOU were the One...
TDaniel
>with the Afro and the yellow leotards; I shoulda known!
Re: so YOU were the One...
>TD I couldn't get a beret on that Afrobut my gymnastic pants would closely resemble yellow leotards.
Not that bad
Ed Moore
>The drill sounds great with its new bearings. With the help of Ed Kelle's photo with diagram, things went back together fairly easily -- well, easily for that sort of thing anyway.
And best of all, SWMBO really seemed to understand the need for a back-up and why it was already being shipped. ;^D
Ed
...Been there, done that!
David
>I replaced the rear bearing, but couldn't get the trigger assembly back right. The new bearing did not spin freely. Hoping TD will still help me put it together after his gathering.
Re: Photo ? Diagram?
>Hey Ed,
Missed that post. Link please?
M
Re: Photo ? Diagram?/bearing slipping?
Ed Moore
>Mark,
Do a search on "Enco bearings and a photo" and Ed Kelle's post will be the bottom one.
I suspect that the rear bearing of my Milwaukee was slipping. Now I am considering putting some double faced tape around the outside of the bearing and putting it back together in the hopes that the new bearing will not slip. Good idea? Bad idea?
Ed
Here it is Mark  *LINK*
George Van in WI
Re: Here it is Mark
George Van in WI
>Sorry Mark, that did not work.
Enco bearings and a photo *LINK* *PIC*
Ed Kelle -- Sunday, 12 February 2006, at 6:11 p.m.
Re: bearing slipping
>Doubt it, Ed. the bearing will get warm enough in use to nix the glue. You might, however, gently scratch the outside surface of the race, clean and carefully degrease that surface only, and apply a wee bit of pure (100%) silicon caulk as glue. That stuff will withstand 500* and will act as a good, flexible glue if it can get a grip on the metal surface. Make sure you don't get any on the bearing seal, however.
Hey, it's worth a try 'cause otherwise the drill's pretty much toast.
Mark
Re: Got it, George.
>Thought there was a diagram, but I see just the photoshop stuff to ID parts.
Thanks
Keith Tompkins
Keith Tompkins
>John, we must both be old hippies!
A bearing shim might work
Brian Hahn in SW Wisconsin
>I found them in the McMaster-Carr catalog (www.mcmaster.com) a while ago. Search for "bearing tolerance shim" or part number 3547K13. (The Milwaukee drill bearings are size R4.) It'll cost more than the bearings ($4.32 + sh&h) but less than a new drill. They're probably available from other suppliers as well, but I've had really good luck with McMaster-Carr and they're close enough to me that standard shipping gets them to me the next day.
Re: A bearing shim might work/ Thanks!
Ed Moore
>Thank you very much, Brian. I just ordered 4 shims. Hopefully they are easier to install that retaining rings. ;^D
I appreciate your input.
Ed
