We value your privacy.
Well, got me a chainsaw. Ive used them before, but never for making a finished product.
First problem I notice is I need a way to hold the logs so I can slice them longwise to make pieces small enough to cut up with my bandsaw.
I finally managed to do this by simply cutting log in the dirt. I let the chainsaw blade dig into the ground and slice it.
Dont seem like the right and proper way to do things. So I thought I would ask you guys how you might do the same.
I was thinking maybe I could dig hole in ground and place logs up right position. That way I could cut sections at the top, flip the log over and cut the rest.
Just wondering if you guys have better method for log splitting. I doubt I would like to use an ax to do this. Because I may even like to split into 3 pieces. So I need more control.
>RJ I keep meaning to build myself some sort of table to put them on but for now I prop the piece up on other logs and cut most of the way through. Then I rotate it 180 degrees and finish the cut. Sometimes if the logs are the right size I can set the log length wise on 2 others and then the blade runs inbetween the two ground logs so I can cut all the way through in one pass.
Hitting the dirt with you saw blade dulls it like you wouldn't believe.
>Don't let the saw dig in the dirt. Depending on the soil, even slight or momentary contact with the dirt could dull the chain and it may get grit in the chain and bar, causing wear. You could also hit rocks and debris, damaging the saw or throwing the debris around.
Most people have a holder of some sort, ranging from a couple of boards with a space between them to some pretty fancy benches. Some have benches that elevate the log or piece off the ground and some of them have clamps on them to hold the piece still while you cut it.
Think about how you hold the wood, you don't want metal such as nails or screws anywhere the chain might hit them. You can use a couple of logs, side by side, "chocked" together and then lay your blank between them in the "vee". Many saw benches are made from pieces of large timbers or logs so the fasteners can be under the bottom and not likely to damage the chain even if you cut into the bench, and you will cut the bench.
I'm sure people will post pictures. I don't have a bench, I still chock the logs together, because I don't do this every day and am too lazy to build a dedicated bench. One thing that comes up is how high to make the bench. If the wood is on the ground, you have to bend over to saw it and that becomes back breaking if you have a lot to do. OTOH, if you raise the bench, you have to lift the blanks and that can be a chore if you are cutting huge blanks. Think ramps.
>I am hardly an expert. Chain saw is a very dangerous tool; beware of the kickbacks. When the tip hits a hard object such as rock, the saw may swing back towards you. The kickback would be so fast and so powerful; you won't be able to react. I don't think a hole in the ground is a safe solution. Your log would fall into the hole after it is partially cut and squeeze the bar and may jam.
Do a search on chain saw sawing horse. You can find plenty of ideas that you can build similiar to this:
>I learned Bill's technique and applied it diligently! I add a little twist (rotation actually) to it.
Here's what I do - decide on my cuts. Cut off a flat section on each end as Bill shows. Use them to stabilize the log for further cutting. Then make the two center cuts to within an inch of the bottom. Rotate log 180 degrees and continue the cut in the kerf UPWARDS rather than start a new cut down towards the existing kerf. This allows for a nice, flat, continuous surface on the blank, making bandsawing and faceplate attachment much much easier.
I always use a chainsaw bar that is slightly longer than the log I am cutting is tall. That way I can make a single cut making that flat even nicer. My longest bar is 25" and my lathe's max swing is 20 so ask the arborists I work with to cut me up to 22" long trunk sections. Works perfectly well.
Here's a good rule to live by - chain touches earth - sharpen. Chain touches rock - sharpen. Chain touches anything other than wood - sharpen. Touching earth generally renders a chain useless.
You'll notice what a useless/dull chain is by the following:
* Increased pressure required to cut. You should only need the weight of the saw, not much more.
* Burning/smoke
* Dust rather than shavings (but cutting end grain results in dust too)
* Blade wanders rather than makes a nice straight cut.
A good sharp chain should pull the saw into the cut and not require much more effort than holding it steady to make chips/shavings.
If I don't touch anything other than wood, a sharp chain will last through most of my sawing sessions. I always sharpen after use so I have a nice freshly sharpened chain ready for the next time.
>LOL I was getting the same feeling and started to post to that effect yesterday when he said he wanted a chainsaw. Then I thought, nah, suppose the guy really is serious but just really...well, you know what I mean. ;) He's probably an accomplished craftsman/artist who could turn circles around many of us. Fess up, RJ!
>I am being honest in my questions. You have to realize that not everybody has the intial money to invest.
Here is a clock finial that I have made so far.
http://www.picpuppy.com/finials/oakfin.jpg
I don't really care about tool snobdome.
It reminds me of my X brother in law. Never lifted much of a finger ever in his life for work, but a self proclaimed expert in all the trade fields. He inhereted via marraige an Ace hardware.
Example:
He designed and built his own house (with our help). But being the kind of person he was, he would not listen to advice about anything and especially pooring concrete foundation and slab. Very snobby and petty personality.
He marked out the foundation with string and we dug. Thing was he leveled the forms with a line level. (He read a how to poor your own concrete book the night before, figured he knew everything).
Needless to say the line level was highly in-accurate. Especially since it stretched more than 50' with 2" level...??
So, comes the time to have the slab poored. He decides to tell the concrete truck drivers to make the mix really dry. (He read this in the book also).
Ahhh you should have seen the disaster!
We all snikered under our breaths cause we all hated his guts. Rocky clumps pooring out with clumps of powder mix. After a couple of truck loads like this he finally listens to us and thins the mix a bit.
Took forever and ever to finally get that mix smoothed out reasonable. Rocky patches everywhere. Should of heard him screaming like a b when the concrete started to set. Rocky patches everywhere.
Not only was the finish poor to miserable, when the slab dried you could put a ball on one end of foundation and watch it roll and pick up speed till it got to other side. It even had a ripple that made the ball bounce a little.
Everybody laughed thier a* off.
The masons had to slice blocks from about 1/2 there original size to about 1/4" and it wavered. The masons did a good job and got the walls level.
You see, he was a tool snob type. Usta laugh at others for thier cheap and shotty tools. Always bragging about all his possesions.
Me, I know I was not suppose to stick the chainsaw in the dirt. But I didn't think it was that sensitive. I figured maybe once would not do too much damage. Thanks for heads up guys.
I also figured somebody would be kind enough to show me how it is properly done. Information is king.
>>Then I thought, nah, suppose the guy really is serious...
I think RJ is for real and just needs some help! ( See link - the second page has some pictures of the type of clock and finials of interest here)
RJ (Richard?), if you are going to use a chain saw and have no experience, you NEED to get some instruction before you lose a hand or foot or disembowel yourself or remove part of your face. This can happen in a fraction of a second. The best is to get some instruction and training from a professional. There are also some web sites with good info: type "chain saw safety" or "chainsaw safety" into Google (without the quotes, of course). And please use proper safety equipment - eye, ear, leg, feet, and helmet (if cutting trees). The chainsaw is one of the most dangerous tools you can buy.
Here's a deal for you - if you promise to put the chainsaw down until you get some instruction, I'll SEND you some dry cherry, walnut, and maple suitable for practice and a few finished finials. (You just pay the postage)
If you have touched the dirt with your saw, it will probably need to be sharpened. A dull saw is even more dangerous. You can take the saw to the dealer to get it sharpened but that takes a lot of time and costs money so it is best to learn to do it yourself. I generally resharpen after every tank or two (or immediately if I touch a rock, dirt, or barbed wire). It is very important to either keep the wood off the ground or put other wood under.
Read these for how to maintain and sharpen your saw:
To hold the logs you can prop them carefully or build a sawbuck. Some people make a sawbuck with a clamp. I generally place some large pieces of wood under and wedge the chunk with other pieces as necessary.
Note that most of the chainsaw cutting advice you will get here will probably be about cutting up wood to use as bowl blanks. If you are primarily wanting to make 3" squares for turning your clock finials, you may be better off splitting the wood instead of cutting it, especially if the grain is fairly straight. Cut the log into short finial-sized sections with your chainsaw. Allow a few inches extra on the ends for waste, chucking, and loss from checking. Turn the section up on the end and split with a wedge or two and a sledge hammer. Make the first split down the middle and keep the center (pith) out of any piece. It's pretty easy to get roughly square pieces if the grain is straight. The pieces will not be perfectly square but that won't matter since you will be turning them. Turn green for practice, or allow to dry for a year or so for finished work - or use one of the accelerated drying methods (the microwave works well for me).
Another way to process a log section without using a chain saw is to use the band saw. If you want a 4" long finial, cut a log section about 8" long. Put the section flat side down on your bandsaw table and cut in half, straight across. (Do NOT try to cut with a round edge down without a jig or you will damage your blade and possibly yourself.) Then lay the flat side down and slice each half into sections - repeat to get turning squares. This may require a bandsaw with a riser block to process larger logs, or split them in half first and then bansaw the halves.
I'll take you up on your offer of the cherry wood. I really dont need much to start out with.
Write to me at rjsoftware2000 at yahoo dot com
My lathe seems to work fine enough for what I need to do with it. Thought I'd better develope a nice safe method for using chainsaw to handle logs.
I like the ideal of the wedge. Forgot about them. I live here in Florida so the only time I ever seen anybody chopping logs for fire wood is in the movies....
I have been an electrician for over 30 years. On and off. So I got allot of basic hand and power tools down pat. As per chainsaw, you know typical yard work. Used bandsaws, chipping hammers, sawzalls etc..
You see, I sorta also like the ideal of purchasing already cut pieces. Spend a couple of bucks and save my fingers. Cause accidents do happen.
I don't really think it is a money thing or a snob thing that generated the "is he pulling our leg" response. I'm still a newbie (I've been turning about 8 months now, and don't get a lot of time to turn), but your approach is a world different from most of the other people on this site, and it is refreshing and even a little amusing (keep reading).
I think everybody is really enjoying watching you get started with this. Everybody got started once, everybody needed help a million times, and everybody can relate to the new turner. For most of us, we hedge and hedge, and debate on this site and in our own heads, and study about tool purchases. Which lathe, what tools, what kind of sandpaper, it goes on and on. It took me a good few months to study and debate my way into selecting my starter lathe tools and mini-lathe. I've been trying to decide on a good dust collector for no less than six months. I think that is pretty much the norm except I probably take longer than others.
Then one day this new guy showed up, and told us he wanted to make finials for clocks. Great idea for the lathe! RJ is enthusiastic, so everybody likes that. The amusing part is that where most of us debate endlessly about what lathe, etc., you jump right in with gusto, and we see posts like "I bought a lathe! Now what?" "I got a chainsaw last night. How do I cut blanks?" It is just the reverse of what we typically see - I've been debating the purchase of a chainsaw since approximately June, and probably won't do anything until I don't know when, whereas you went straight out and took care of it. I think this is, in large part, why the site has embraced you so. Very few people who visit this site would be comfortable with making tool purchases without studying them to infiniti first, and there is a certain amount of interest in the guy who does.
You get a lot of responses to your questions, your enthusiasm and lack of pretense has definitely drawn a bit of a following - and that doesn't always happen. I know whenever I see a post from you I read it, I think I've even responded to a few to help where I could, and a lot of other people have too.
Think about where your logs have been before you started sawing them up. They've probably been rolling around in the dirt and dragged behind a tractor after hitting the ground hard, and there will probably be lots of dirt caught in the bark. Dirt in bark dulls a saw just about as quickly as dirt in the ground. If you are not sure that the surfaces of your logs are clean, you should hose them off, with as high a pressure stream of water as you can manage, before cutting into them with the chainsaw.
The same thing goes for rough sawn boards before you run them through your joiner and planer, if you also do flat woodwork, but a good stiff brush will probably work for these, especially if you are worried about moisture content.
>Thanks for the post John....you beat me to it...I was going to offer some cherry also. PS, RJ, mahogany works well for finials, should be common in FL. area.
I had no ideal the chainsaw blades where that prone to becoming dull due to sand.
I only had the blade sticking in the dirt for just a brief few seconds. But I really had it in the dirt...!
For now I have resolved to just buying pre-cut wood. I think that the money spent is better than the effort to cut my own.
Certainly allot less work.
Man,,
When I think about how hard the old old timers had to work to make boards without power tools...
I tried sawing with manual saw on log. Would have taken a few hours maybe just to cut out nice section to work with for bandsaw. Blade kept sticking in non dried thick oak trunk.
Forgetdaboutdit...
I have read that way back when, they had allot of water powered machinery in there saw mills.
But can you imagine even before that like in "Danial Boones's" day imagine how hard it must have been to make a wood plank!!!
If Danial Boone was sawing and chopping wood all day he must of been a Hell of a man.
Sing it with me now...!
"Danial Boone was a man! Was a big man, but the bear was bigger so he ran like a n..... through the woods".
>One thing everyone forgot to mention, NEVER EVER cut with the tip of the chainsaw bar. That is the surest way to make a trip to either the hospital or morgue.
>Take a large round. Turn it up on its end. Take a V-cut in the top to lay the log you want to cut on. Lay the round on its side. Take another V-cut with the top cut parallel to the end of the round.
Stand it back up and start using it. Takes about 10 minutes of prep work and a deep-jawed bar clamp allows you to clamp your workpiece to round it off or make it smaller.
Here's a picture. I have some others if you need to see them to get the whole idea.
>You not kidding about the manual saw. So far every blank I have cut has been using a bow saw, my two very worn arms and inadequate clamping techniques. Generally speaking, I end up with some giant log propped up more or less on top of my vice, and slice at it for two hours until I get what I want. Cleanup is no problem because the sawdust coagulates with my sweat.
But the funny part is, aside from my reluctance to get a chainsaw, I'm really proud of it when the finished product is done. I can look at a bowl and know that my own two hands did the work. There's just a lot of swearing that goes on before the wood ever hits the lathe, and a totally broken heart when I kill a piece on the lathe that took me so long to get there.
>RJ, Darrell Feltmate has a great couple of ideas on how to hold logs for chain sawing. I made and use both his sawbucks. Cheap to make,long lasting, and renewable.
>Here is a better picture, RJ. The V-cut in the top gives you a place to lay rounds to cut to length or split down the center. The cut in the side lets you clamp a piece in place to work it into shape.
