Drying rough turned bowls quickly.
Dave Smith, Longview, WA
>Fred Holder was kind enough to publish an article I wrote about drying bowls in More Woodturning. I am not sure where you can obtain a copy of the November issue or if Fred has extra copies available for purchase. The process is something I have worked on for many years and it has proven very effective.
In the interest of turners who would like to turn bowls from green wood and give them for gifts this coming Christmas I am posting the process in a nutshell. Please let me know your results, good or bad, so I can write a followup article about the general use of the process.
ALCOHOL SOAKING GREEN BOWL BLANKS IN A NUT SHELL.
Turn the bowl to a thickness of �"for small bowls(< 6 inches). Larger bowls may need to be thicker to allow for distortion.
Place the bowl in a container of denatured alcohol.
Let soak for 2 or more hours.
Remove the bowl and place it on a rack upside down for 1 hour to let the surface dry.
Wrap the bowl in heavy paper such as a grocery sack. On a bowl simply gather the paper around the rim and secure with a couple turns of masking tape. On a closed form the paper can be tucked into the opening and held in place with masking tape across the opening. The opening must be open to allow air circulation.
Place the bowl upside down on a rack so air can circulate into the opening.
Record the weight and date on the bottom of the paper. When the weight stops decreasing it is ready to finish turn.
Small bowls will stop losing weight in one week or less. Large bowls will take about two weeks. Hollow forms very in drying time due to the small opening which inhibits air exchange. It is not necessary to record the weight every day but initially you may want to check the progress to satisfy your curiosity. I keep my shop heated and dehumidified year round so my drying time may very from what you may experience.
Nearly every turning I have posted on this forum has been dried using this process. There have been some failures but they have been rare exceptions. So don�t use a priceless irreplaceable piece of wood to test this drying protocol.
I owe a big think you to the many people who helped me test the alcohol drying process during the past year and those who encouraged this project. They validated my findings, edited text and gave me the confidence to publish the results. In no particular order these people are David Propst, Bill Grumbine, Dominic Grecco, Jennifer Shirley, Mark Kauder, Larry Hancock, Scott Greaves, Sean Troy, Barb Siddiqui, Mike Schwing and Ellis Walentine.
Good luck.
Dave Smith
With a shop full of dry bowls in Longview, WA.
Re: Drying rough turned bowls quickly.
Verrry interesting!
Alan Tolchinsky
>Thanks Dave,
Very interesting method. What kind of scale did you use to weigh the bowls? How do you think this method compares to the more traditional method of turning thick, coating, then waiting a year? Thanks Alan in Md.
It works!
Mike Schwing from Md.
>Dave was nice enough to lay this info on me a few months ago, and I can report great success with it as well. I've taken wet maple blanks, platters, and hollow forms to dry enough to finish in just a week and a half or so.
I haven't yet come up with a method to soak really large bowl blanks but I'm working on it. Not sure I want that much alcohol on hand though!
Dave it was really hard to hold your secret, but I did it.
Re: It works!
Gil
>Wierd I was using some shellac last night, and denatured alcohol, I placed an apple wood blank in a bucket of it to see what would happen. Thanks for doing the research for me!
Cheers,
Gil
Large Blanks
Gil
>A 5 gallon bucket with a lid will work with most blanks. Anything larger would be maybe a canning kettle or something like that?
-Gil
For large bowls.
>Hi Mike,
Large bowls can be placed in a heavy plastic bag and then nested into a pile of shaving to conform to the bottom of the bowl thus limiting the amount of alcohol needed to cover the bottom. The inside of the bowl can also be filled to reduce the volume of alcohol needed to completely cover the bowl. That sentence does not say to do the filling on the outside of the bag. Just make sure the bag is a thick one. DAMHIKT
Thank you Mike for editing the final draft. Your comments were excellent.
Dave Smith
Sun is shinning and I am working in my shop in Longview, WA.
Make sure you wrap the bowl.
>Hi Gil,
The key to drying a bowl is to wrap the outside only. The inside drying faster than the outside will cause compressive stress which limits cracking and movement.
Dave Smith
Barbara Gill, Remlik Virginia
>Dave, this is very interestin. Usually I am not in a hurry however it is nice to know there is a method for speeding up the process if I am.
I am going to Richmond next week and will buy some alcohol and several containers.
Where would the least expensive large quanities of denatured alcohol be found, Lowes or something similar?
Thanks so much for sharing your technique.
Any hardware store for the alcohol
>Hi Barbara,
Denatured alcohol cost about $10 a gallon. I suggest plastic containers with snug fitting lids. You can expect to lose some alcohol with each bowl that is removed from the container. Because I add to the container from time to time I have not worried about the dilution of the alcohol.
Dave Smith
Gil
>Have you done any experimenting with the nightmare woods such as cherry and apple? I recently turned 20 cherry bowls and boiled them via the prescriped method. I've lost 5 bowls so far, which stinks big time. I think boiling and then anchor sealing might be the key. Also my basement might be too dry 30% Relative Humidity.
-Gil
Wally Dickerman at Green Valley, Az.
>Sounds like you've come up something Dave. Do you have a good answer for WHY it works?
Mike Schwing has been telling us that he's going to be showing us some wild new turnings. Do you suppose that he's come up with these ideas while he was inhaling all of those alcohol fumes?
Wally
sycamore, apple, plum, wild cherry, pecan
>Just to name a few of the types I have dried using the alcohol soaking method. I do not think your basement is too dry for the process to work. Wrap the outside of the bowl and place it upside down on a rack so air can circulate inside the bowl. I will post some pictures later.
Dave Smith
Get my groceries in paper bags in Longview, WA.
Wally you have a good since of humor.
>Hi Wally,
I was working on the drying process when you told me about your method of putting wax on the out side of turnings. That confirmed my notion that only wrapping the outside of the bowl was contributing to the success of the process. Soaking in alcohol apparently allows water trapped in the cells to migrate out with minimal stress. Nearly every turning I have shown you has been dried using this method. Including the piece of apple we turned when you visited my shop a couple years ago.
Dave Smith
Wife wants to wash cars, YUK, in Longview, WA.
Re: Wally you have a good since of humor.
Gil
>Dave do you wrap the bottom of the bowl in paper as well? Or just tightly around the outer surface of the bowl?
Thanks,
Gil
Mike Rubes, Apex, NC
>Hi Dave,
This is very interesting. Just curious, have you noticed any discolorations associated with the soaking? Does the wood turn any differently or sand differently after soaking?
Like most people, I've had some good/some bad luck with drying by conventional methods and would be interested in trying your method.
Thanks for the information,
Mike
A beautiful fall day in Apex, NC
Could be Wally!
>Some of the things I'm working on are on the insane side for sure. I really hope they work out like they look in my head. But don't look for them soon, more than half of this work is in the development. Volcanoes, fireworks, strange creatures, they all have a part somewhere in these things in my brain.
The truth is that these insane ideas pop into my head while I'm attending the symphony. I think the music coupled with the lack of anything to really focus on opens up my brain in ways that don't show up otherwise.
As in most off the wall ideas, they'll be a hit or a flop.
Re: Could be Wally!
>Mike!... what kind of music does your symphony orchestra play? Volcanos, fireworks, Strange creatures?....Couldn't be Strauss waltz's. Must be something wild.
Wally
Discoloration is only skin deep.
>Hi Mike,
One of the things I wanted to know was if light colored bowls would be discolored if soaked in a solution which previously had dark wood in it. My experience has been that there is no permanent discoloration. The surface darkens with oxidation when it drys but it is turned away when the bowl is finished. The surface of an alcohol soaked bowl looks similar to a boiled bowl when it drys.
Dave Smith
Got to go do some finishing in Longview, WA.
Re: Discoloration is only skin deep.
Kevin Gerstenecker
>Dave is RIGHT on with this method. I just finished turned my first bowl today using Dave's method. I cut this Sycamore the neighbor had taken down on November 7th. Later that afternoon, I roughed a bowl and put it into Alcohol. I soaked it overnight (12 hours) and followed Dave's instruction......wrapped the outside with grocery bag paper, folded in over the rim, making taped it in place, and cut off the excess paper. I finished turned it this morning, and it stopped losing weight after 3 days! I can tell you, this bowl was DRY when I turned it today. It turned like dry wood, sanded like dry wood, and soaked up Watco Oil like you would not believe! I have about 6 more bowls in the process of drying right now, and they are looking VERY good. A little distortion, but NO cracks, and they feel and look dry. I will let these go longer than the 6 days I did with this one, but I just couldn't wait any longer! Besides that, it was DRY as best as I could tell. Sure is a revolutionary idea Dave, I really appreciate you sharing it with me when we met after Steve's BBQ.
Comparative results?
Andrew Hilton
>Have you done any comparisons with a control and a few other common methods/protocols of drying at the same time?
Dick Hines
Dick Hines
>Ok I like the idea of drying bowls in a week or two. Now I want to know how safe it is to have a bucket of alcohol sitting around the shop. The safety question has not been answered or asked for that matter.
Jerome Laux
>Thank you for sharing. I have a couple of kitty litter buckets that I can use. I wonder if isopropyl would work??
Jerome Laux
>Denatured alcohol kept in a closed container doesn't pose that much of a hazard. Besides, you are only soaking the bowl or rough piece for 12 hours. The rest of the time it is drying.
You should have reasonable ventilation to your shop (exhaust fan or large open door). The explosion limits for ethanol are about 3% vapor concentration to about 25%. The flash point is relatively low (12-14 C) so it does present a fire hazard - so no open flames, and probably no sharpening (unless you have a Tormek or similar wet grinder).
Re: Any hardware store for the alcohol
Fog Tanner
>Dave,
Have you tried methonal alcohol. I usually buy that in 5 gallon quanitities from a local raceing fuel supply for at $2.50 a gallon. You can also buy it from dirt race tracks, just bring your own container.
When I get a chance I'll try your method using methonal. Thanks for the info.
Fog
Methanol is dangerous stuff.
>Hi Fog,
I am not too sure about methanol. It is the stuff that is used to denature ethanol. If it ain't good to drink then it can't be too good to breathe. I don't recommend its use.
Dave Smith
Not a chemist in Longview, WA.
