Pith removal
Phil Murray
>When creating bowl blanks, how much of the log center is considered the pith and needs to be removed? Vary by species or size?
Thanks, Phil
Pith removal
Phil Murray
Thanks, Phil
Re: Pith removal
JamieDonaldson
>Varied by species and size is the correct answer- some will always be a problem,like fruit woods, and others are stable if turned uniformly thin and cured using the old paper bag trick!
Re: Pith removal
Jim Pugh
>You generally cut on either side of the pith so that there is not a complete growth ring in your bowl blank. Usually about a two inch width will do it. On the other hand, if you cut 2 inches on either side of the pith you will have a 4 inch thick slab with the pith in the middle of it. This can be quickly removed on the band saw and the remaining pieces are essentially quarter sawn.
