New Lacquered Bowl PIC
Mark Kauder, Phenix City, AL
>Here is a bowl I have been working on for the last 6 weeks.
It is 9" in diameter. The black wood is ebonized Walnut, the other woods are Maple and Cocobolo. The finish is Deft lacquer. No grain filler was used - just layer upon layer of lacquer sanded until smooth. I sanded the wood to 400 grit, and then sanded the laquer with up to Micromech 8000, then polished with 3M Finess-it. I then coated it with Muguiers Carnuba (car) wax.
Sure is tough to photograph something this shiny.
Any an all critiques are appreciated. How else do we get better.
Mark
Re: New Lacquered Bowl PIC
No "glad handing here"
Dominic Greco in Richboro PA
>just real praise. I am astounded at the overall shape, wood selection, and fit and finish of this piece.
Fantastic job buddy!
See ya around,
My ugly mug
Dominic
>Mark Good job. No Great job. I think segmented turning has to me more than just a bunch of wood put toghether. It needs shape and good lines and the contrasting wood has to work well with the shape. You did both well.
As you noticed glossy black thing are really hard to photograph. Try covering part of your top panel with black paper or cloth to change it's shape. You will see whatever shape you create refected in the piece but sometimes you can create a shape that is more pleasing. It requires a lot of playing. Usually just making the top light look thinner helps.
Wally Dickerman at Green Valley, Az.
>Beautiful piece Mark. And that lacquered finish! Wow! What did you ebonize it with?
Wally
>Thanks Wally.
I just used the old rusty steelwool in vinegar solution on the Walnut.
Mark
Chuck Ludwigsen
>Wow!!! Excellent.
Chuck in Memphis, TN.
Beautiful piece!
Alan Tolchinsky
>Hi Mark, That's just gorgeous. I like the finish a lot. Did you spray it on and was all the sanding of the lacquer done with the lathe on? Alan in Md.
Ohhhhhhhh........
John Trant
>You made my wife squeal like a little girl when I showed her the picture. She prefers the shiny, highly-polished look opposed to the rustic, natural-edged, "feel the wood" look so she wa very impressed. I am not so selective ... I like what I like and I love your vase. Excellent work! Thanks for raising the bar for all of us!
John
There is only one word to describe this
Ron Sardo in PA
>BEAUTIFUL!
WOW Mark!
Fred Deadrick--Livermore, CA
>Wow Mark that is beautiful! One of the best I have seen from you. Normally I do not like high gloss finishes, but this one is outstanding.
Fred -- Waiting for warmer weather to try out hide glue 8-).
>Mark
was the piece already built when you used the Ebonizer. I was just thinking that this solution doesn't change many woods so you could feasibly turn the whole piece and then ebonize. If you chose your woods carefully it would only affect the ones you want.
I had trouble with the ebonizing not going very deep. Even too much sanding went through the color.
Glenn Hodges
>Mark, this is something else, I love it!!! I don't usually care for the segmented stuff, but this piece changes my view on life.
Nashville, Georgia
>I sanded, then wet the wood to raise the grain, then sanded again. The ebonizing was the last thing I did before shooting the first coat of lacquer. In my build up, you cannot see it, but there are two layers of dyed black veneer between the Walnut, and the Maple Layers. This gave me a barrier to work with. I was careful and could work right up to up to, and even touch the veneer, w/o risking the Maple. It is a good thing the ebonizing is not thick, because I got a damp finger print of the solution on the Maple, but was able to scuff it off with 400 grit.
Once ebonized, and shot with the lacquer, I had to be very careful not to sand through the lacquer to the wood. While leveling, I errored on the side of thick layers of lacquer, and less sanding then I otherwise would, Until I was confident that there was enought lacquer between me and the wood.
Mark
Re: Beautiful piece!
>Alan,
Lacquer will melt most of the time when you sand with the lathe on.
All the sanding was done with the bowl parted off. All sanding was done by hand, piece in my lap - usually in front of the TV at night.
Mark
Scott Hogsten
>Very Very nice piece and one to be proud of. Great work and nice shape and form to the piece as well. You just want to reach out an touch it even in the picture.
Scott Hogsten
Beautiful..
David Eaves
>That is an awesome piece. The form and technical aspects just look perfect. The many hours you must have put into the finishing, were certainly worth it. It really suits the piece.
A truly inspirational piece.
David
THAT IS AWESOME!!!!!
KurtK in Indy
RonZ
>Absolutly stunning!
I personally like a gloss. This finish has me looking for the hood. =o)
Sean Troy
>Hi, What is Finess-It and where can you get it/ Thanks, Sean
Bill Grumbine, Kutztown PA
>Very impressive piece Mark! I am not much for high gloss finishes, but I think it is very appropriate for this particular piece, and you have done a great job on both the turning and the finishing.
Bill
Robert Savit
>I'm not generally a fan of segmented pieces, but this is really wonderful. The form is great, the segmentation is used tastefully and with restraint, and I very much like the way the minimum and maximum diameters (aside from the very bottom), occur at the segmented bands. I am curious to know whether and to what degree the inside is finished. Does the sanding and/or finishing extend far below the neck?
Really a great piece.
Bob Savit
Absolutely stunning Mark....
Marc Phillips
>That is incredible...
Great job...
Marc
Tomy Head
>Mark,
You have out done yourself!! Absolutely beautiful!!!!
Museum Quality - Great job!
Ric Erkes
George Troy
>Great job Mark. Hope you can keep all the noise and hand prints off of it. Keep up the good work. Thanks for showing. GT
