I have to admit...
John in NM
After trying pins first and coping out the waste yesterday, I do prefer both methods. Now I just need to make one of Frank Klausz's "around the corner" saw blades
I still hate using pine for drawers. This was a utility drawer I would otherwise have done differently, and it was made of scraps of pine I had around. Pine is horribly variable stuff these days, the best I have ever used came out of the attic of my house up in the mountains. It is quite resinous stuff, basically local #2 boards cut in the 1960's, but all older growth and works far better than what you get at the local store these days. I could see using it if you have old growth material, but I still much prefer a hardwood.
For a utility drawer, dovetailing was not quite as quick as if I'd set up the dado set on my saw and cut box joints as I normally do for such applications. However, it was not so much slower that I won't do it again for a similar project. Its very good practice and kind of refreshing to do in a context where one isn't overly concerned about tight results.
Haven't seen anything like it since other than large SYP boards, which often have clear quartered sections in them, but the latewood in SYP once dry is a real bear when combined with the soft earlywood (and even when perfectly sawn, it's a bit homely).
