A Gigantic Shooting Board!
The hall table for my niece was completed and delivered, but the wedding was postponed owing to Covid-19. Australia locked down early, and we have suffered less than other countries.
I realised early on that I would have to change the way I ran my psychology practice, and began to research and gear up for Telehealth using video. I found this quite stressful as I intensely dislike using the telephone (and cannot avoid doing so through the day), fearing that video may have the same impersonal feel. It has been reassuring that it has turned out quite a decent experience, and it will usher in changes in the future for consultations. Distance and mobility may become barriers of the past.
Still, the past 6 weeks have been exhausting. Working in front of a screen is intense. I've probably put in 15 hour days owing to the extra admin needed.
What has this got to do with woodworking? Well, I really haven't made it into the workshop until about two weekends ago. It is a refuge from the stresses of the world, and I can chill out just tinkering. I managed to tune up all my machines. Do you know that bicycle lights are the best lights for drill presses and bandsaws? Got a couple of them. Attached a spare Wixey to the bandsaw. Love it! Made a rack for router bits. This is sounding desperate. My energy levels are too low to tackle the painting Lynndy wants me to do. I really just want to push a plane around.
Blame Rod Cosman. He has a daily video on building drawers. If you can ignore the constant sales pitches, Rob is one of the good guys, and there is always something to pick up. I would watch one episode after the last patient was done, with a coffee and my feet up.
Well, Rob was using this large shooting board. He likes to shoot with a #5 1/2. The board was nothing special, but it reminded me of a project I had thought about some time back - a shooting board for tuning the long edges of drawer sides. Keep in mind that the drawers I build tend to have sides 6-8mm thick. You cannot plane this accurately in a vise (well, only Warren can). I must say that Rob demonstrated wonderfully precise work, and this rubbed off on me. Hence the interest in creating a shooting board for long edges.
Numbers: the runway to the fence is 750mm. The total length is about 880mm. The total width is 450mm. This is a large shooting board. Yet I can reach down it. It is not cumbersome to use. Its principal use is long side edges, but it can shoot ends as well (not to forget that I have a shooting board and plane dedicated to shooting ends).
Solid wood? Well, sort of. The choices are MDF and ply. MDF is really not a great choice as it had a hard exterior (good) but soft interior which does its best to imitate a sponge when water is nearby (very bad). It is also very heavy. The plywood in Oz is .. well .. cr@p. There really is no other word to describe it. It is light, since full of voids, and generally looks like a pretzel. It is possible to purchase marine ply, but it is very expensive. My local Bunnings had these laminated panels on special, and they were cheaper than the unspeakable ply. The thicker panels are Merbau, which is heavy and hard. The lighter stuff is unknown and softer. The laminations will minimise movement.
The panels were all 300mm wide (12" for those who have not yet entered the modern era). One-and-a half panels made up the base. These were planed down on the jointer and thicknesser, and then joined level with the aid of biscuits (yes, I have one .. damn useful they remain, when most traded theirs in for a Domino. So silly of you .... I have a Domino as well. These machines do different things). I digress. Glued up ...
I use mild steel section (covered in tape) for cauls.
As good as the results may be out of the thickness/planer, the surface is not going to be flat. I have not used this Marcou in yonks. Traversing to flatten across the grain ...
Winding sticks are used to check for twist ...
The high spots are marked and planed off ...
For fun, I decided to enter the 21st century. Behold, the new winding sticks ...
Then it was the turn of the runway. What are the chances that it runs parallel to the platform?
Here are two squares on the platform. There is no gap between them as the panel is flat and level ...
Now when I take them over to the runway, it can be seen that this is not parallel ...
The next task is to plane the runway, checking along its length ... until you get this ...
Next step: remove the fence from a Small Plow (plough!) and run a 1/4" groove along the side of the runway/base of the platform ...
This is for dust, to keep the corner of the runway clear.
Next step: shoot the rebate for the blade. I use a Veritas LA Jack. It does not matter much as I have three planes I could use, and the other two (seen shortly) have similar dimensions (the blade is about 6mm above the sole) ...
This electrified router plane was used to create mortices for T-slots ..
Now the fence could be attached. It is aligned with the blade rebate, and squared to a plane. I use a little glue to set it, then screw it on from above and below ...
Here is the side fence being morticed ...
Finally ... ! Here is the shooting board ...
Shooting the sides of a drawer with a Veritas Custom #7 (the advantage of this plane is that it has a 40 degree frog, so can shoot end grain, plus with the chipbreaker it will plane sides very cleanly) ...
Remove the side fence, close up the outer runner, and use the LN #51 to shoot ends ...
The underside of the board is covered in rubber underlay ...
This is as the long shooting board with live under the table saw and be used on the outboard ...
I am not sure if this build was just a way of having some fun, or whether it will get serious use. Either way, it was time well spent.
Stay safe.
Re: A Gigantic Shooting Board!
David Weaver
maximum gizmocity!!
Where's the ramp???
(just kidding :) )
William Duffield
That's an interesting device, beautifully executed, and another well done tutorial. You should find it very useful for fitting drawers and for shooting panel glue-ups, too.
A few rhetorical questions/comments:
- Of, course, you have competent table saws and a power jointer for building panels. :D
- It seems like the differences between a biscuit jointer and a Domino are all in favor of the Domino. When I got mine, I immediately unloaded my biscuit jointer (a DeWalt), and have never missed it. I can't figure out what it can do that the Domino can't do better. Maybe biscuits are cheaper?
- It seems that the T-tracks and fence on the stock (left) side and the T-tracks and fence on the plane (right) side would just get in each other's way, so you couldn't use them both together. Together, they add quite a bit of size and weight to the shoot board.
- You might be able to use the left side T-tracks to mount a removable (and adjustable) miter fence or two.
- When you are not using the fence on the left side, you could use a pair of screw clamps in the T-track to hold the stock down to the shoot board. You might find this useful when fitting pre-assembled large drawer cases.
- When planing the right side parallel to the left side, I think you could get more accuracy using a dial indicator instead of the two squares. The squares are an ingenious technique, especially for those who don't have a dial indicator and base.
Philip F Duffy
Derek, I am certain the following idea has been smoldering in your mind for a long and loving time: it is time to write a book!! A loose leave, perhaps spiral, so clueless guys like me could flip to a page and see how to do thinks correctly, with precision, and with love of the craft. Please get started if you have not done so already. With kindest regards and admiration for your work. P.
William Duffield
One More Idea: That shooting board must be very heavy (especially the fences :D ) and therefore unwieldy. You ought to be able to remove a lot of mass without sacrificing significant stiffness and stability with judicious application of a large Forstner bit. Fo example, I recently saw this table saw crosscut jig somewhere on the web, probably here on WC. I would give credit, but I don't remember who posted it.
Clamps
William, thanks for the ideas.
There were a number of photos and comments I might have added, but thought that I had probably said too much already. One of the photos omitted was with clamps.
I decided against the T-track style clamps here (as you know, I have used them elsewhere) as they are too directional, which limits their range of cover.
The side fence does not just travel parallel to the runway, but can be angled so, for example, one can hold an out-of-square board or deliberately plane a taper. As the end of the board will not sit flush against the far fence, clamps are helpful to prevent movement (this is unnecessary when the side fence is parallel).
The clamps can be moved along the side fence, as needed. That is the reason for the many holes you see ...
Re: Clamps
William Duffield
If you use the toggle clamps you show in the picture, then the weight reduction holes I suggested in my other response will not work.
Yes, the problem you noted with the T-track screw clamps is a serious deficiency. You could partially overcome it with more T-tracks, or even with a bed built of 80/20 extrusions. :D
(Maybe you need another T-track in the fence instead of the row of T-nuts hidden in the bottom of the fence? You can never have too many T-tracks :D :D :D )
Philip, I appoint you my publicity agent and manager.
I am waiting for Chris Schwarz to offer a Large, up front retainer. I checked the postbox yesterday, and the day before. And before that. Nada. How can this be?!
Many thanks for all your kind words. :)
Philip F Duffy
- -ONLY after the first draft, DEREK~~!! P
roger lance
Derek.....That's a beast! Enjoyed following along. When you were placing two squares back to back to check the level of platform to runway, I don't recall seeing any one do it that way before. I just made sure that my platform was 90* to my shooting plane's side.....
I follow Rob Cosman as well.....sometimes it takes him awhile to get on point.....but, what great work.
Re: And a Gigantic Plane *LINK*
Steve Voigt
Looking good, Derek. But you need a giant plane to go with it! Here you go:
Giant Plane
The torch is passed...
Jim Matthews
"Now available for three easy payments of thirty-five, ninety-nine (99)."
They get to throw shade *and* pay homage in the same gag.
It's a woodworking rap video.
If the iron in this plane could hold up to..
David Weaver
...jarrah, I'd practically donate it to your cause down there as you actually have a board big enough for it.
Unfortunately, the front iron (not sure what I was thinking) is an ohio tool iron and it's not that great.
Needs a mouth insert, too as erosion with end grain only work in one spot is pretty quick. But that wouldn't be difficult to address.
Doctor Doolittle plane
Jim Matthews
One a dem dere "Peruvian Pushmipoolyu" planes, innit?
A foundry read those plans...
Jim Matthews
They made a lighter version in cast iron.
How many men did it take to pass a board over "The Beast"?
it's like when you see...
David Weaver
..one of those old pictures of a plane that you really never see often...
...and then you make one and try to use it and say..
"hey, it's not really that great, is it? maybe I should've bought a miter trimmer instead of wasting $100 of materials on it"
In the immortal words of Paul Hogan ...
... that is not a plane ... THIS is a plane!!! :D
I made this some years ago. 36" long Jarrah body. 3" wide E.A. Berg blade bedded at 50 degrees. Bloody heavy!
Alongside a Veritas Custom #7 ...
On the shooting board, planing edges ..
I must tell you that this is AMAZING! It powers through anything and everything ..
Re: A foundry read those plans...
David Weaver
I could make a jointer like that fairly easily, even the iron thanks to the foolish purchase of a half million btu propane torch, but....and a big but, finding a single solid straight and stable piece of quartered beech of that size wouldn't be as easy as it would have been 250 years ago. A laminated version would look kind of cheesy.
Re:Big French planes
Steve Voigt
Warren, I've never seen one that big, but here is one i photographed in Alsace.
David Weaver
Thanks for that picture (you may have provided it before in discussion, but I've forgotten).
Interesting top of the iron - I guess you don't need the right side of the iron if there's no chance you'll ever touch it.
I want to make a cooper's jointer, but nothing of that size - just with the biggest of my beech billets (about 60 inches long) and with the widest iron I have on hand.
Top of the iron
Warren in Lancaster, PA
Roubo mentions a tab to hit with a hammer to remove the wedge and iron.
Re: Top of the iron
David Weaver
Thanks, Warren - a very practical thing - I was literally just sitting here thinking about it being relatively easy to advance the iron, but not so much retract it. Makes sense.
