I used gray water based primer and target coatings black satin finish. The detailing is Testors metallic gold enamel. First picture is of the chair apart on my bench. The second is the finished chair.
Bird cage rocker waiting on my fitting the rockers. As you can see,the shop in cluttered. I'm getting undone work out of the way so I can get back to the chair building. Next job is recaning the seat on a friend's bentwood rocker. Not my favorite occupation.
This chair was in rough shape. Had been poorly repaired at some time in the past. The joints came apart easily with reverse clamping and soft hammer. Many repairs.All turned pieces I chucked in the lathe and sanded off the old finish. The rest I scraped and sanded after assembly. I replaced some dowels and cleaned off old glue with scrapers and files. Breaks were repaired with titebond 2 . All joints and dowels were assembled with liquid hide glue.
