Bathroom cabinets picture
Kees
Yes, I have been slacking greatly the last few years in the woodworking department, but I did finish my bathroom with hand made cabinets and mirror frame.
It's all heavilly influenced by Peter Follansbee. I also drew inspiration from English antique furniture websites and several books. It's all made from cherry, American and European.
BTW, Dutch bathrooms are tiny! It was a squeeze.
If you want to see more detail, feel free to ask ;-)
Re: Bathroom cabinets picture
looks excellent!!
David Weaver
Very peter follansbee, just like you say. I'm sure there's historical precedent, but since I'm a low-reading dope, Peter is what I see with that style.
Looks great, though. Definitively better than RTA cabinetry.
Most older houses in the US don't have large bathrooms, either, unless an attic or closet room has been converted.
My two full baths probably average 50 or 60 square feet.
My parents have a house that was originally 3200 square feet (built by a wealthy couple as a summer home in 1924), it had one bathroom that was no bigger than mine. I guess people didn't camp for an hour in a bathroom until more recently.
What a great way to start the day!
Did you do that carving?!
Wiley Horne
Kees,
The carving is beautiful, and the moreso because it is so extensive, and carried all the way through. Cherry is a fine choice. Is that ‘Rembrandt lighting’ just ordinary everyday in your country? :)
Thanks for showing! We don’t see much carving here, though I believe Warren is very accomplished at it.
Wiley
Michael Brady
Kees:
That is a beautiful melding of early and contemporary styles. Is is the first use of the carving so well curated by Follansbee that I have seen that works well with modern themes of decorating. The modern bowel sink and faucets are nice too. Well done!
Wonderful work ..
.. beautifully made and a great aesthetic!
I have watched you grow with your carving over the past few years, but the door handles look turned - have you taken to turning as well?
Brian Holcombe
Well worth the wait, exceptional work!
Re: looks excellent!!
Kees
My bathroom is 1.9 meter x 3 meter, so also about 60 square feet.
Here another picture of the shower area in the other corner. Looks pretty modern but I used Portugese hand made tiles. Not two are the same, so it was quite a bit of work!
Re: Did you do that carving?!
Kees
Thanks Wiley, and yes I did the carving myself. Who else :D
I learned from Peter Follansbee that you don't need to be afraid in this kind of work. It is very simple relief carving. The style is more what you would see in a farmer's home or a village church. Not the high brow stuff from the upper class.
Kees
Thank you. It was a lot of work, but also a lot of fun. I had this vision of the combination of modern and antique from the start. The walls and floor are done in some kind of lime plaster (not by me, professionally done) which adds a lot of charm too because it looks simple and clean like modern designs, but up close it is full of life like in an old house.
Kees
BTW, the lightning is more or less by accident. The LED's in the armatures in the ceiling are more yellowish then I though they would be.
Re: Wonderful work ..
Kees
Thanks Derek,
And don't flatter me too much with the carving work, it is really simple stuff!
The handles were a bit of a disaster. First I tried to turn them, but I don't seem to understand turning, bits of wood flying everywhere. Then I tried to carve them which didn't turn out so great either. In the end I chucked them into the drill press and used rasps, files and sandpaper!
They do look fitting to the design though. All three are slightly different.
Thanks! NM
Probably what Rembrandt used also
Joe shelton
Still, wow!
I think it's terrific.
Charlie
One often runs across stunningly well-executed crappy designs. Not so here. Your project is perfect in every way. That style with the sink -- brilliant. Furniture has to work in its surroundings. Yours does so extraordinarily well. A piece can look great in the workshop and fall totally flat in the room in which it is placed -- ruins the whole thing of course. A builder is by necessity also often an interior designer. More to it than cutting tight dovetails!
Kees
That's a huge compliment Charlie! Sometimes you just get lucky and hit a home run, I presume. I have made some duds too in the past.
Kees
The real homerun was when I designed the large cabinet. I always wanted to make one of those blanket chests, but I don't have a place or purpose for a chest like that. Then I looked at those panels and the idea came, why not put some hinges on them and turn it into a cabinet?
Excellent! Do not let my wife see this.
Clint Searl
Outstanding work.
