I hang each of my backsaws on a single Shaker Peg, with a short row of them on a board, screwed to the wall behind the bench.
I would never hang saws, or any other tool, directly over the bench, because they get in the way of the project that is being maneuvered on the bench, and are easily knocked onto the work, or onto the floor, or onto my head. DAMHIKT, but it involved a trip to the ER and 11 stitches!
I also protect saw teeth (back saws, panel saws, and hand saws) with a grooved stick about 3/4" square that I attach with a mini-bungee cord. Use well-seasoned wood. I cut the guard about a half inch longer than the front of the saw plate. I find it is easiest to cut the groove with the table saw, or even repurpose a used push stick. One end hooks onto the heel of the blade and the other end (slightly modified to fit with a pair of pliers) hooks onto the back. Since the guards are all different lengths, to match the length of the saw teeth, I write a description of the saw they fit on both sides of each stick.
A lot of people will build a saw till to hold them, but I don't think that would work so well for me, since I often do woodworking away from the shop, and I would have to go look for the guards every time I put a couple of saws in my tool tote. Later, I would have to find a place to store the guards and bungee cords when I got back to the shop and put the saws away. This is not an insurmountable problem.
If you do build a saw till, make sure you make space in it for your saw vise, saw files and saw sets. You might also want to add pegs to the sides or bottom to hang your turning saws, coping saws, fret saws, etc.
Till with pegs on the side top and bottom so that the backsaws can be hung on the outside of the till. I have pegs on the sides and nails on the bottom of my till, for the backsaws and japanese saws, respectively, though the japanese saws are mostly gone.
I took a small piece of cherry with a live edge and attached a cleat to the back to make it into a small shelf. Then I cut saw kerfs into the edge spaced about an inch apart to hold each saw. I cut into the outside edges to accept the back of my backsaws. Simple,but I have used it for years. The saws hang with handles up. If this doesn't make sense I'll get a picture.---Jack
I got the plan for these many years ago out of a woodworking magazine. I now have 4 of them. 3 in the shop, and 1 in the garage. I find a 1 3/4 inch spacing works well. They are placed just to the right of my bench so they are handy to grab when needed. I can supply details if you want them. Good luck with whatever you decide to go with.
Yours illustrates a major design issue of saw tills in general: Should they be stored handle up or handle down? Both ways work, as long as the handles are at a convenient height when you reach for them and put them away. Handling them by the handle is important, as it increases efficiency, reduces the chances you will drop a saw, and you transfer less salts and oils from your hands to the blade.
A google Image search for "saw till" will give you lots of ideas for designing and building one that will work for you.
I guess what I was looking for was examples/experience with storing/hanging an open handled back saw flat against a wall or in a hand tool storage cabinet.
I only have 5 such saws and do not intend to add to the collection which would certainly warrant a separate saw till.
Examples I've seen of the type of storage I'm intending to use make use of some type of formed filler in the saw handle area and a pivoting piece that can then be turned to help secure the saw.
When I said I'd be storing the saws above my workbench, I may have created the wrong picture. My bench has a tool tray and the storage area for the saws is behind the tray.....so the saws being stored individually and flat on the wall will expose them minimally above the bench.....still need to be careful as you've indicated but the saws should be out on line with the action on the bench.
I've kept the plastic tooth protectors that came with the saws and find they do their job. I wish that we could buy some of this plastic in length to use on saws when the need arises.....TFWW does sell a flexible plastic product in 5" length which might work.
They have a durability problem (at least compared to a western saw that you can continue to file until you're either out of files or out of saw plate), and I've built myself a couple of push saws and refurbished others.
I thought (and probably most do) that pull saws were easier to use for accurate joinery when I first started, but I became more acclimated to push saws when I started to dimension by hand because there's not much around in japanese saws that is good for ripping rough lumber. Custom made is an option, but that's very expensive.
Anyway, the accuracy issue went away with western saws, and I can now work faster with them, and last year, a friend expressed interest in the japanese saws. He was in the shop a short time later and I asked him if he wanted to just take all of the saws that were undamaged (i did keep an azebiki, but will sometime make a round tooth line saw to replace it, too).
"I only have 5 such saws and do not intend to add to the collection which would certainly warrant a separate saw till.
Roger, last night I was going to (perhaps a bit cheekily) suggest hanging your saws on screws or nails sticking out of a convenient bit of wall or similar, but decided against doing so because my rather utilitarian approach to woodworking, tools, tool care, their storage and use doesn't always jive with some of this forum's visitors who may take a somewhat more reverential view of their woodworking equipment.
However, learning how small your saw collection is, smaller than mine, my screws/ nails in the wall suggestion is, in my opinion, back on. In truth, if you follow my idea your saw storage will be more sophisticated than most of my saws experience, e.g., chucked into my site bag, tossed on a shelf in my tool cabinet and/or cupboard, hanging off a clamp clamped to a ceiling joist in the workshop, bit of a muddle I guess, but every one of my saws is easy to locate and use (for me anyway) ha, ha. Slainte.
I went upscale and used dowels (but the cabinet they're in was already there, and they were an afterthought when I realized the saws wouldn't fit in the till itself without things being cramped).
When the front tooth of my backsaws clanks into the concrete block wall sometimes, I think of a friend of mine who dutifully puts his plane down a certain way every single time, whether or not it interrupts work, and who wipes his planes about as often as he uses them. He'd be horrified...certainly the front tooth of some of those saws has lost its sharpness...
... but I've never cut anything with the front tooth on a saw, and they're on and off the pegs so easily.
If I didn't have so many saws, the pegs would just be on the walls with no till.
This is something I threw together to get my saws where I could grab them easily. I used a couple scraps of cherry that I probably should have thrown in the woodstove. I don't like spending alot of time on shop fixtures as you can see.
Looking from left to right ,the slots are for small dozuki saw ,LV detail saw,LV dovetail saw,LN dovetail saw,antique english made dovetail saw,Adria x-cut tenon,adria rip cut tenon,japanese flush cut and last,the saw I use most, a marples version of a ryoba that I discovered is the best tool for leveling chair legs.
Well, I've employed several of your ideas and techniques over the years.....but, this particular method.....although a good one, isn't what I need to do in the space I've got to do it.
I look forward to delighting you (Platonically , of course) another time.....
That's my kind of holder. I have something similar in a chisel case. It holds a lot of chisels and it's really ugly. And it was really cheap and easy to make.
This is an independence tools saw, and they have a little semi circular clip to the handle. It sits on an male semi circle at the top of the block of wood, which also has a slot down the side. The washer means the handle can't move to the front. For a flat mounting it is very well captured, and yet completely free to be removed from the rack. I copied it somewhere.
Most of my saws are mounted vertically as I have a few of them and don't have space, but I have three of these independence ones and they are rather nice to look at.
