Corrections and elaboration
Teachings vary. However, no one I've read recommends a longish back bevel--the ones who do recommend it envision one so slight that it comes off with the next sharpening. Mr. Charlesworth's thin ruler method has been mentioned; fellow named Brent Beach has for years recommended a series of 3 or 4 back bevels, adding to a few degrees in total.
Hi Wiley
There is some confusion here, which I will correct.
Firstly, the use of "back bevel" (as used by others in this thread) may be accurate but is misleading when discussing David Charlesworth's "Ruler Trick" (or I think it is now referred to as "Ruler Technique"). A back bevel is used to significantly increase the cutting angle, and generally starts at 5 degrees and may go up to 25 (or more) degrees. For example, a common angle frog + 15 degree backbevel = 60 degree cutting angle. This has been a long standing technique for reducing tearout - possibly a few centuries.
The Ruler Trick creates a backbevel of approximately 2/3 degree. It is used to ensure that the bevel face meets the bevel back cleanly. I believe that it started as a remedy for pitted blades, but it became a tuning tip for sharpening generally. It certainly benefits beginners, who find it difficult to hone the rear of the blade, such as failing to judge that there is a wear bevel. It also can benefit some bevel up plane blades, since the wear bevel occurs in this region. This is an easy way to avoid its incursion.
There are two ways to do the RT. The way that David Charlesworth recommends is a front-and-back motion. This would create a long (but low) bevel. The other way it is done, and the way I would do it (and I gather from David that Rob Cosman does it this way as well), is a side-to-side motion along the steel rule. This creates a smaller, more localised back bevel.
I tend not to use a RT, but have done so in the past, and it is an effective way of both sharpening or even giving the plane's blade edge a second lease on life.
Now to Brent Beach. Brent does not advocate 3 or 4 back bevel in series. He advocates 3 or 4 secondary bevels (on the bevel face) using a honing guide and a series of setting blocks. I recall he presented this method in a FWW article some years ago (... very different from my preference to hollow grind and freehand on the hollow).
