New WoodChat!
Have a question? Ask Woody!
Leg Vise (Parallel Guide) Question
david weaver
How much play in the mortise for the parallel guide on a leg vise?
Screw is a wood screw, legs are 5 1/2 inches square.
I'm assuming from looking at pictures online that when the vise varies slightly in perpendicularity to the ground, some play is needed in the mortise of the parallel guide.
I've seen various parallel guides, rigid and not rigid, either looks like they'd work fine as long as the screw is strong enough to hold up the weight of the vise.
A parallel guide that's not rigid would probably remove the need to have much or any slop in the parallel guide.
Re: Leg Vise (Parallel Guide) Question
Re: Leg Vise Question
Steve Voigt
I have about 1/16" play from left to right, and about 3/8" from top to bottom. The latter might sound like a lot, but since I use a roller mechanism (a couple scavenged skateboard wheels, very similar to the benchcrafted glide system, but free), the parallel guide is centered up and down, leaving about 3/16"play above and below. I actually opened it up several times until I arrived at that amount of play.
I need that much vertical play because my pin holes are spaced on 1/2" centers. For example, f I'm clamping something that's 1 1/4" thick, the pin will be set for 1 1/2" thickness, and the chop will be out of vertical by an appreciable amount. More closely spaced holes--I think BC recommends 5/16" spacing--would allow for less play, but I'm actually glad I didn't go that route. The 1/2" spacing makes it easy to eyeball the correct setting.
I think maybe a little more play from left to right would also be a good thing, because it would make it easier to clamp slightly tapered pieces. Probably better to err on the side of caution though; you can always make the mortise bigger if you want.
The main thing to realize is that a leg vise doesn't work at all like a vise with guide rods. There is no benefit at all to having a tight fit for the parallel guide. I know that some people have rigged up guides to keep their leg vises absolutely parallel, but I don't see the point. If that's what they want, a Record-type face vise would be a better fit. One of the many strengths of the leg vise is the ability to conform to out-of-square objects.
david weaver
Thanks Steve, you've confirmed what I was guessing - that the only provision I need to consider is making enough space so that the pin board doesn't get put under lateral pressure.
wilbur
The “mortise” for the parallel guide on my leg vise is a slot cut out of the bottom of the leg. My leg vise has at least a strong 1/16” of play side-to-side between the slot for the parallel guide and the guide itself. There’s about 1/4” between the top of the parallel guide and the top of the slot that it rides in.
As far as rigidity goes, my parallel guide is made of a piece of cherry a little less than 1/2” thick, and the pin is an oak dowel. Stiffness isn’t a real factor because this end of the vise only serves to act as a fulcrum.
A leg vise is easy to make because precision isn’t necessary for it to work well. It functions as a third class lever, or in woodworking terms, a wooden handscrew vise positioned vertically.
Warren in Lancaster, PA
I have less than 1/32 inch of play side to side and almost 1/16 top to bottom. Some of that could be wear after 35 years. It could also be that I built it more snug and altered it slightly to get clearance. I occasionally waxed the bar at one time; I don't need to any more.
david weaver
One of the reasons that I picked a leg vise, two actually:
* the whole setup isn't that precise
* I do a fair amount of resawing, and as much as I really have no interest in building a bench, I can't tolerate my inexpensive bench any longer for resawing. The vise design is inexpensive and fine for everything else but it's definitely not fine for resawing as I've split it and patched it enough times to be tired of fiddling with it.
I'm a third class guy (at best) so a third class lever is fine for me.
Is the bottom of your pin board riding on the mortise?
Because the pin board does nothing other than push back on the vise so that the jaws can get maintain pressure, I'd pondered just running a 3/4 dowel through the bottom of the vise and allowing the parallel guide to move. I'll decide exactly what I'm going to do about 30 seconds before doing it but confirmation (rather than trying and finding out later) that it's not going to create a sloppy setup is good.
david weaver
Thanks, Warren.
On my grandfather's leg vise - which I still have, although it's not in service at the moment - the bottom guide, like Wilbur's, is attached to the moving jaw on the vise in a slot at the bottom. It's pinned so that it can rotate freely up and down within the range of motion allowed by its placement in the slot. Holes in the guide are about 1/2" apart*, if I recall correctly (it's pretty deep in the storage area, so I'm working from memory, always an exciting activity), drilled staggered along the guide, which is a chunk of 1x2 oak.
The mortise for the guide in the bench leg is sloppy; can't recall exactly how much, but I think it was enough for easy movement but not much more.
*The holes are, as I mentioned, staggered, so there are two rows of holes, toward opposite edges of the guide. Holes in one row are roughly an inch apart, with holes in the other row offset by half the distance.
david weaver
Thanks, Bill. No need to look. I may not have read wilbur's post close enough, but gather then that he mentioned his on a pivot also. That's my only real decision at this point, pivot or no pivot.
The impossibility of leg vises
Leg vises are kind of a bumblebee device - shouldn't work, but they do. Unless you go with one of the fancy-Dan devices that keep the moving jaw parallel to the fixed jaw, like the St. Andrews cross, the moving jaw is always slanted eversoslightly in relation to the fixed one. The metal vise manufacturers tell us all about the great pains they take to machine their vises so that the jaws will be parallel in clamping the work (closing first at the top, with the play in the vise then allowing the jaws to come to parallel, and so on). Some dang how, leg vises work. A while back, I acquired one of the L-shaped Wilton vises, which got rave reviews from Consumer Reports (of all places!) back when they were being produced (see picture below), and I've been back and forth in my head about whether I should mount that or a reconstructed version of Grandpa's vise, using the screw and nut from the vise (possibly made by my uncle) and new wood, when I finally get around to replacing the regular old Wilton WW vise on the face of my bench. I'll have plenty of time to decide - there are so many projects on the list it's likely to be a couple of years, soonest, before I get the round tuit for that.
I do like the gentle but firm authority with which a leg vise grips the work. That, and the emotional connection with my ancestors, may be enough to decide me.
wilbur
I’m applying the picture=1K words principle here, since I think these photos will explain what’s going on with my leg vise much more clearly than paragraphs can.
Here’s my leg vise in action, clamping a cherry offcut.
Here’s the parallel guide, with the vise engaged and under pressure. You can see that neither the top nor the bottom of the guide touches the slot it rides in. The oak dowel acts as a fulcrum. You can see the mark where the oak dowel contacts the leg if the dowel is placed in one of the upper holes.
This is how the parallel guide is attached to the chop. It’s a simple mortise sized to fit the parallel guide. You had mentioned using a dowel to attach the guide to the chop, if I read you right. I wouldn’t do that. Making the mortise for the guide is a trivial task, and the connection will be much more secure. Remember, this is the fulcrum of the lever, and could fail with too much pressure.
Finally, here’s a side view to show how out of parallel the leg vise chop is compared to the front of the leg.
Even though clamping pressure can be improved if I adjusted the pin so that the chop was more parallel, it’s not necessary. In fact, you want the top of the chop to be canted slightly inward. Again, think of a wooden handscrew vise stood up on end. The screw on the bottom is the parallel guide, and the screw in the middle is the handle of the leg vise.
Re: The impossibility of leg vises
david weaver
If I'd have had a vise like that, I might've used it. I originally went with a leg vise to save money (it certainly doesn't save any time, but it's not like it's too complicated and all of the various iterations appear to work fine). I blew that by calling CS due to using the wrong credit card on my original order and changing from $40 metal hardware (that would've been fine) to the wooden vise screw kit.
Not sure if that was the right decision, but it's already made, and came with a hidden cost of another $35 for a very large forstner bit. I would've done without that if this was a project I liked to build, and just drilled most of the waste out of the hole, and finished the sides by hand with incannel gouges.
I've never had luck to find a vise like you have, and when I see one, I don't know much about benches and hardware, so I'd have no clue if it was missing something I'd like to have. But it looks like a nice vise for sure.
david weaver
Yeah, I haven't really had any trouble with the concept of how it works and whether or not parallelism is important, more just a survey of what folks have done.
As far as the pivot goes, my intention was to make it housed in a mortise, round the end of the housed pin board slightly and drive a 5/8" dowel through the pin board so that the dowel retained the pin board, but allowed it to pivot a small amount. The bearing surface of the pin board would've still been the board against the chop, and the dowel would've been there only to pull the pin board out of the mortise.
That would've allowed for a fairly tight fit in the mortise, and no sagging of the vise, but in the end last evening, I just decided to forgo all of that and made everything rigid as most do - it'll be faster and I won't have to fit a pin board or wax it, etc. I don't often put things in the vise wide open and under tension it wouldn't matter if it sagged a fraction of an inch, anyway on the rare occasion that I do.
I will be glad to be done building this bench, it's sort of a throw-together thing - something I always hoped someone else would do and drop off at my shop.
thanks for taking the time with the pictures and explanation, by the way. I agree with (what I think you're saying) that a dowel itself is a bit unsavory when the whole thing can be housed and the pressure is bearing on the mortise in the chop instead of just on a dowel. I have a visual problem with being able to see anything on the front of the chop other than uninterrupted wood (as in, I don't want the pin board poking through and visible).
I've noticed that some folks put the pin board below the stretcher, and some above. I have a tendency to be lazy, and thus put mine above so that I don't have to bend very far.
Re: Leg Vise (Parallel Guide) Question *LINK*
Lars Parrington
I don't think you can have too much top to bottom clearance, but you probably do want something holding up the parallel guide. If the screw is holding up the whole weight of the vise, it will probably be hard to turn.
I would keep the side to side play as tight as you can. I had to loosen mine up in this direction, and over did it, so now the whole vise can flop around a bit side to side. But too tight, and the parallel guide will bind up.
Also, can't help but to put in a plug for my pinless vise mechanism. It might actually be simpler to build than drilling holes. I'm sure you could omit the bearings. See the video:
https://www.youtube.com/watch?v=338U49EtWso
Very good, Lars....
roger lance
You're thinking!!......I like your design.
david weaver
Funny, Lars, I saw your video on youtube and recognized the name. Nifty setup that you have (if I'm recalling it correctly - a ramp that forces maintaining parallel).
my mortise is above my stretcher, though, so I'd have to build more fixtures in the bench to do it.
I haven't planned any lateral movement into the pin board yet, and figured I'd start with a tight fit and test the board, and then plane only a little away if needed for the exact reason you stated.
Not sure what I'll do in regard to the weight on the pin board or not, the screw only has so much plan if the whole assembly doesn't stay parallel.
Speaking of weight on the screw, what do people normally do with a wooden screw - wax it? Oil it? (oil seems like it would be unhelpful). Presume the tension on the screw is what keeps it locked and wax wouldn't hurt it.
Maybe too much thinking and not enough using to this point, though (well, using is hard before the vise is made).
A few notes.
I have used beeswax on the screw occasionally. My recollection is that there is less need over time as the screw becomes polished.
I can't see why the vise can't hang from the screw as its main support. Double screw vises simply hang from the screws with no problem.
I have not used a mechanical device to avoid using a pin at the bottom, and I don't see that I would want to. Sometimes a very tight hold is wanted at the top of the vise and so we go to the next hole in the guide. Using the pin gives us chance to have some control over this rather than just accept the distance the device provides. Some days we open and shut the vise fifty times for every time we adjust the guide, so leaning over once in a while is not a burden.
david weaver
Thanks warren, the burnishing/waxing comment is exactly what I'm looking for.
I noticed that some of the vises hang on their screw and other folks have vises that don't, but I don't put a lot of wide pieces in my vise, so I expect to not have to move a pin much.
My chop is 2 inches thick, and not one of the super heavy 4" monstrosity type chops that are on some of the glitzy benches.
The comment about extra pressure is helpful, too, most of the reason I'm building a bench at this point is to be able to get a good grip on wood to be resawn - it has always been a struggle in my inexpensive bench, whereas everything else has worked fairly well. simplicity and strength are what I'm looking for.
.. most of the reason I'm building a bench at this point is to be able to get a good grip on wood to be resawn - it has always been a struggle in my inexpensive bench, whereas everything else has worked fairly well. simplicity and strength are what I'm looking for.
Hi David
I've been reading through the posts kind of trying to work out the reason you want a leg vise. I understand that you would like something that requires the least amount of work, and does not cost much. However, I do not have a good feeling about a chop that can wiggle side-to-side, especially if you plan to use it for resawing. I think that you would be better off with a wider, rigid vise, such as a double screw or even a Record 52 1/2, one that will not rack (deliberately, at least).
I think that it is important to decide whether a leg vise is the design for you. Do it right and do it once. The reason I use a leg vise is to clamp long boards for edge jointing. In this regard it is best considered in partnership with a sliding deadman. One without the other is half a vise.
I deliberately made my leg vise rigid. This allows me to clamp boards along one side without it losing grip, or plane the edge of a longer board (without the sliding deadman being used) without it tipping.
While I do not resaw at the bench (I would use a bandsaw), holding a board in a vise seems to require moving it about, extending it out, and creating pressures/downforce at angles that will weaken the grip on a board held unevenly.
My leg vise closes square, and is suited as is to parallel boards. However out-of-parallel boards are easily held with wedges.
I found that keeping the chop square maximises clamping force. To this end I built everything with minimal play.
The chop rests on the parallel guide, which in turn is supported by a small roller.
The wooden screw has slop built into it, and so I built a guide for the parallel guide to minimise side movement (and it also enables tuning of the chop) ..
http://www.inthewoodshop.com/ShopMadeTools/ParallelGuideGuide.html
I also added a chain adjuster, which is a pleasure to use, but not something for everyone. It does add to maintaining even pressure.
What I have ended with is an easy-to-use vise that excels at holding wide boards square to the side of the bench. It is not designed for resawing, but it would work well for this. I am not so confident about a design where the chop racks to hold out-of-parallel work. But perhaps I am misunderstanding how these work.
david weaver
Hi Derek , the chop won't be able to rack to hold out of square work. Laterally, it'll be rigid, as I am building the pin board with very little room to move laterally, just 1/4th inch or so to move vertically.
The provision I mentioned with a dowel would've allowed the whole assembly to work without leaving much slop in the pin board mortise, but the pin board would've still been set in a mortise and bearing against the chop, so it would've had no more lateral movement than a rigid chop, which is what I've decided on.
Figure the only range of movement will be a small vertical amount, determined by the amount of slop in the screw.
Nothing on my bench is permanently attached, and there is enough room on the end (16 inches) if I decide later to change the type of vise.
The leg mortises are not through mortises, but they are about 3 1/2" square and very tight, so I don't envision gluing anything.
I have made provisions on the front stretcher for a deadman (as well as a slot in the top of the bench). My current cheap bench has a skirt and to that I clamp a scrap and can plane long boards, the deadman will just make that a little easier, though to be honest, I've never had much trouble with my current bench other than the front vise. I get a chuckle reading the "testimonials" from people describing what "you can't do any work with".
at any rate, I'm confident at this point that everything is in order and it will work fine for what I want to do, though I have to admit that I am used to working with my bench and don't look forward to slowing down a little bit until getting used to a new one.
wilbur
I put on a liberal coat of paste wax when I first built my leg vise. A couple months later, I reapplied the wax. I might have done that a third time a couple of months after that, but either way since then I haven’t had the need to apply more wax, and that was 5 years ago.
david weaver
Presume you're getting the same type of burnishing warren mentions (Which is what I was hoping for, and what is similar to the bottom of a double iron wooden plane, where the beech gets worn and slick and sort of case hardened instead of worn and then worn off more).
Brian Holcombe
David, if you would, post some pictures when it is finished, looking forward to seeing how it turns out.
I have no insight to offer with regard to the leg vise since my bench is a derivation of the scandi style.
david weaver
Will do.
I intend for it to be somewhat embarrassing, though, being not the kind of thing that I like to build. I've chosen to cap the ends with a piece of 8x4 ash held on by three lag screws.
The leg vise won't be affected, though.
I just don't have the motivation to build a "nice one", and didn't want to incur the cost of a nice one. The only two stipulations that I had was hardwood, and better at holding boards for resawing than my current bench is.
I don't need to cap the bench, but am more curious than anything about movement - the caps can be removed later if needed, but I don't suspect the bench will move enough for it to matter that the ends are capped, so I want to test that by putting the cap in place with lags that have no give, spacing the three apart fairly significantly. I saw a relative goofy accusation to warren that the joint in the roubo bench hadn't been proven safe from lateral expansion (despite being in use for over 200 years as a type), with many "improvements" suggested after that.
I apologize in advance for what it will look like - it's been a "build it as fast as you can" project. I'm not afraid to build ugly things, I just don't usually take pictures of such things.
Brian Holcombe
That's likely the case with the screws. I have a 20" wide white ash table top affixed to stretchers with brass screws every 6" or so, the holes are slightly oversize and it has gone through a full range of seasons without issue.
Same deal with my bench, the top is actually bolted to the base with holes slightly oblong and quite literally almost all of the noticeable movement occurred from the wood initially coming into a normal range, I expect it was slightly wet when new from the yard, hasn't moved more than 1/8 in a full range since then....and that is over 36"~.
I think people often forget that with Roubo benches we're only talking about 20"~ and so the movement is easily absorbed in the distance from the bottom stretchers to the top.
