Re: The physics is not favorable
TomD
I will be interested to hear how it works out, even if there are better ways ultimately. I have two such project, one almost identical to yours, and the other the tool without a pike.
My thought is that the relative weight of the head and the handle are not that relevant. What counts is that the spike has considerable weight, so it should seat into the hole so long as the hole is correctly shaped, which might be a trick. The fact that the handle is heavy doesn't mater, it is like an immovable object meeting an irresistible force, which isn't so great, except in this case there is a hole.
Practically I wonder if I could hold a peavy and hit it hard enough, but if I could, it should work. Sorta like it doesn't make that much difference if a person or an arrow are moving at 200 ft/sec at the moment of impact, it is still going to hurt.
