THE Shop Stool.....the base.....
roger lance
well, with respect to Wegner & Derek, maybe just a shop stool. This project has been on the back burner for a long time.....a stool to sit upon comfortably while in the shop and perhaps use it at the bench while doing some small part hand work.
I've seen some stools posted on various sites and decided to proceed with a stool of my own even though I lacked a formal plan....so I made a mock-up of the stool base with scrap....
I found if I made a cut at 7° on the ends of my legs using a V block at my miter saw that the legs would be splayed at about 5°.....
Geometry was a long time ago and I'll let anyone that can do the math go for it but these angles worked well. All base joints were mortise and tenon.....
and will be pinned later. The clamped up base was accomplished by using little 5° wedges stuck to the legs with 2 sided tape.....
I'm awaiting some 8/4 cherry or 8/4 walnut for the seat.....I'm told they should be out of the kiln by Monday. So the seat will be part two.
