We value your privacy.
Latest project is a solid mahogany music stand inlaid with satinwood, with holly stringing, holly and ebony banding and ebony acccents. The tablet is solid mahogany with crotch mahogany veneer. The banding pays homage to Beethoven with a repeating pattern of the first two measures of Beethoven's Fifth Symphony.
The inlay, stringing, dovetailing, and shaping of the column were all done by hand. Electrons were burned in creating the banding and turning the column as well as rough milling, and resawing the satinwood veneer.
How did the measures of the knocking of Fate at the door get implanted into the curl of the satinwood? Was it perhaps via the axe of St. Roy? The images one sees are always of a hooded figure with a scythe.
How's the new NBSS facility? Obviously, it is not stifling any creativity or craftsmanship. Did you complete that since the beginning of this year's Fall semester?
I am agape, as are the others. Is the design from Seymour?
Thanks for all the kind comments. The design is inspired by a music stand built by Lance Patterson, one of the great instructors at North Bennet Street.
Bill, yes, this was done after the start of this semester and will be heading down to Providence today for the fine furnishings show...so, not sold yet.
The satinwood is from some planks that have been in my stash for years... Resawed the veneer to take advantage of the amazing curl.
This was a delight to build and some of the most challenging inlay and stringing I have taken on. The banding was a interesting task and the pattern one I came up with late at night...perhaps too late at night, or after too much wine
The music stand is a testament of the finest in handcrafting capability . An inspiration to anyone who even toys with the idea of crafting in wood, be it hand tools or power tools.
Like Derek, I would like to see more detailed pictures, but here on WC, we are dealing with a 100 kbyte limit on picture size. It would be great if you could get Lance Patterson to take the photos, and then you could post them either on your blog or website. I know you have said he is as skilled in photography as in furniture design and construction.
What sort of locking mechanism do you use for the telescoping pole?
I will try to get more pics up with some detail this weekend...i just don't know if I will have time before them. The pics I took are high resolution but I resized them big time to meet the upload limit.
What I will probably do is post them to a folder on flickr with public access, and post the links... Could even happen tonight since the Red Sox won last night and I don't have to stay up late.
Sir William...I am hoping Lance will be able to take his pics in the next two weeks..there just wasn't time before the show... And the ones I took will be good, when they are downsized.
And thanks everybody for the wonderful comments...it means a lot coming from you folks...
The column holds a hexagonal shaft with holes bored through the shaft about every three inches, and a hole in the upper collar of the column. Then just a simple brass pin 1/8" in diameter with a simple turned ebony knob.
I emailed this to Roger and then thought it might want to be posted here as well. It's all about the JPG compression ratio that you use to save your resized photos.
Our messageboards will render up to a 800-pixel wide image, and I have set the upper filesize limit to 100Kb because that's more than enough to get excellent size and resolution. This is all detailed somewhere in our FAQs file, but, to summarize, the procedure I recommend is to 1) crop your image(s) if necessary, 2) resize them (pixel size) to 800 pixels (or less) on the width dimension, and then 3) save them with enough JPG compression to bring the file size down under 100Kb. Here is an example of an 800-pixel wide photo that I saved at a 26% JPG compression (your software might call this 74%). It is just 97 Kb in file size. More than enough detail here.
With Ellis' council, I've resized and uploaded some pictures, including one new one I took yesterday evening at the Fine Furnishings show in Providence.
The stand received the best in show for student work in traditional design. I was surprised and obviously very pleased! The last photo was taken quickly with an iphone when I was tired, so not very good... the white sheet on the tablet is describing how Beethoven's Fifth is incorporated into the banding.
Let me know if there are specific details or info you want...
Thanks again to everyone for the wonderful comments...
...on all fronts. Your piece is every bit as luscious as we thought, and your photo editing/resizing is spot on. Great work all around! Congratulations on your award.
Thanks for sharing this excellent piece of workmanship with us.
Thanks so much Roger. It is even better than one could imagine from the original, small images. Well deserved first prize in my opinion. I doubt that there would have been any arguments about this.
