We value your privacy.
Whoops, helping daughter to move week of fourth, returning with granddaughter this week, cousins from FL dropping by on way to NY, but mainly demands of the rambunctious granddaughter I forgot about July 1..
We are working on some trim daughters cabinets and a bench for the hall. Her first woodworking lesson was shop cleaning, followed by sanding lessons. This could turn out well!
Having taught the kids on our canoe trip to make "Cobra Bracelets" and it became a big hit, I figured I'd help the process out and make them the jig that speeds things up and makes it a lot easier.
I built it to work with 1/2", 3/8" Buckles and the hooks are for rings. Next I've asked to make a hinged stand so it worked on a table.
No, I have no idea why I have so many. I "need" one for each common grit- 100,120,180,220,400(for leveling finish). They are loaded and ready for service in the box. The rest? Where did they all come from. If I bought them...why?
I finally decided to remove the extras from the box. The problem was with all those in the box when I needed the 100 grit block I couldn't find it. So, I would put a new piece of paper on one of the others. Soon I would have 4- 100 grit blocks, each with partially worn out paper.
Maybe life would be easier with one sanding block, one chisel, one pencil.....I haven't revealed the gel pen collection. I keep searching for one better than the Pilot, but haven't found it yet.
No pics yet, but I'm making an entryway table for our daughter's new house. It's just a simple affair, 32" tall and one drawer, slightly tapered legs. I just spent the past couple hours cutting, flattening, squaring and tapering legs. While not finished with the legs, I can report that my pseudo scrub (post-war #5 with a highly cambered blade) is a wonderful thing and makes quick work of rough stuff. This all has to be finished two weeks from tomorrow.
I'm thinking about calling it a rat bench (after rat bike) because the materials were cheap (as in free or sitting around) but the labor was intensive. A 3" maple top from a butcher shop that had seen a LOT of use (1/2" troughs and a thick layer of grease) and crappy construction doug fir for the base. Putty and paint to make it presentable. The top just sits on the base, located by two posts made from a rolling pin. The base is glued and draw bored (18 mortise & tenons, 24 pegs).
Not much hand tool work here, mostly table saw (to turn pretzels into stretchers) and lots of router work: a sled to flatten one side of the bench, another to do the decorations. Hand tools to plane the top and move the paint brush.
Craig...THAT is some mighty fine embellishment of a doug fir bench base!!.....and I'd bet you used a router with fence free hand....that qualifies as hand tool work for me....great looking bench!!
IMO this shows your ability to take what others have cast off and turn it not only into a fine tool but something to be very proud of on several levels, craftsmanship being only the first of them. The best part IMO is it will be used to make other fine and serviceable things during it`s life.
Don`t underestimate your ability to see beauty where others may see only something that has been discarded because it requires too much work or is longer of value. Not many people have the ability to discern that potential and even fewer can take it to the level you have with this bench.
I got started on the blanket chest for Grandaughter #2. The dovetails were cut and fitted for all 4 corners of the box, and the box dry assembled. That project got set aside for a small (ha-ha) bathroom remodel job. You know the kind -- 3 day job that ends up taking 2 weeks. Anyway, I tore out an old built in clothes hamper that we didn't use, reframed & drywalled the area, and laid down new tile. Will install a modified dresser in the new area today and call the project complete.
But don't tell my wife Last batch I shipped she spent all the $$$
Kinda sucks the wind right out of one's sails...
I also finally got a finish I like on some stocks I'm trading to a friend of mine. First experiment with a pumice-rottenstone polish and various oils. Didn't take a picture of those though.
Quartered satinwood. All sawn veneer over baltic birch core--lots of war stories later about how it went. Gonna take Warren's advice on the next one and use a wooden core.
Thanks everyone for the complements, much appreciated!
Ha! not even. I made a x-y fence so I could trap the wood in one axis and route in the other. Actually, those "mouldings" are something I'd rather do with hand tools but don't have the profiles.
A small joint stool bench, this one made of cherry. The stiles (legs) are riven, but the rest is sawed. The lower stretchers are what's left from a tree from my Grandmother's farm, sawed about 50 years ago.
That is a special box for him. very thoughtful, reserved. I can't imagine what it would be like to make something like this for someone I knew. It's a delight to see that his memory continues in this vessel.
