We value your privacy.
finally got back to working on the dining room table....now taking on the top.....we've talked of panel glue-ups before.....lately, I've taken to using clamps on their sides and am using a LV aluminum straight edge to check for panel flatness during the glue-up....I really like that the straight edge is aluminum as I don't have to worry about rust from glue or water during this procedure....
time to get back....the squeeze out should be rubbery by now and ready to remove.
Thanks.....some practical discussion of the wood might be in order.....I bought the wood from Frank Miller Lumber in Union City, Indiana.....a great source of QSWO (I believe they are the major supplier of the Stickley Corp.).....it would be best if you could buy all boards from the same tree for consistent color but I was not able to do this.....hopefully the finishing process will minimize any color variation.....also, you have to take what the lumber gives you....the top will be 42" wide and I thought I'd get 7 boards 6" wide from my rough stock.....as I went about the rough milling; knots, splits, and other defects, which were not initially seen, became apparent.....so I'm still at 7 boards but I'm using a pattern of increasing board width to the center board and then decreasing width to the far edge to get my 42".....I'm still a fan of symmetry....I also expend a lot of effort before the glue-up to get the boards as flat and edge square as possible (note the bench slave held in my bench tail vise which is used with a plane to adjust for any edge high spots which are causing a gap between each board as they are glued one board at a time).....hopefully, the top will be very close to flat out of the clamps and will only need a #80 scraper and sanding.....I've got two small knots in one board and am thinking I'll use tinted epoxy to fill those defects before finish.
agreed.....but I like to minimize potential problems as I go.....I'm going to use a little different method of attaching this top (there's nothing that's really new.....so I'm sure its been done before).....I'll be showing that later in the build.
Not sure, but orienting the clamps that way may encourage the panel to bow - the clamp heads don't cover the entire width. Granted, opposing clamps will more or less cancel each other out, but are their particular advantages to orienting the clamps this way? One disadvantage from experience is that glue is more likely to get on the clamp bar. Just a thought.
I've found there are disadvantages to orienting the clamps in the traditional way also....glue makes it to the bar then as well.....these are great clamps but it does not take much pressure to induce a bow in the glue-up.....thus the use of that aluminum straight edge.....you can work your way down the table top and adjust the bow with the opposing clamps.....very easy to do....after 45 minutes, I begin to clean up the squeeze out with the glue in a rubbery state and I remove each clamp individually and wipe off any glue on the bar.....there are many ways to do things so YMMV.
just to see it as a unit before finish and final assembly, I decided to put the parts together to get an idea of how the finished table would look.....
think we will be able to sit, eat, and entertain here in fine fashion.
I like the arched skirt. A bit lighter leg could blend well with this arch.
It looks nice in its natural "fresh" color. It has a nice modern look with this color and the arched skirt. I finished one modern piece of oak natural. I used a water based nonyellowing stain and the color has preserved well for a few years. So it looks possible to keep this color if you wish.
Well Ellis, I think that tidy thing comes from working with my dad who was a carpenter/home builder. He insisted on cleaning the job site twice a day....once before lunch and again before quitting for the day. As the young guy on the crew, cleaning fell to me and if I was standing around with nothing to do, it was just smart to be cleaning and putting things away....after all, you got to eat when things were straight!!....I'm not sure if he knew about Pavlov's dog, but he had me figured out.
Chairs??....you know instead of having a BYOB gathering, I thought about having a BYOC but was voted down....I got some chairs on order....that hurt to admit, but there you have it....I plan to be taking on my first chair soon....a shop stool and then a Morris chair or two....got to keep it simple....I'm a long way from cabriole legs I fear.
Thanks Bill....I'm liking that arch as well....you might be right about the leg thickness, but that did allow for a good size mortise/tenon....I like that natural oak look also but I'm committed to that finish I used last year on the night stand....looking forward to seeing your chest....I really like the finish you used on some past walnut pieces you've shown.
Thanks....its 42" x 72"....and will seat six and fit into a dining room that is 12' x 12'....so the end seats will have about 36" between table and wall.
I'd love to be hosting some table top dancers but those days are long gone I'm afraid. Here is another method for stiffening those corners....I'm using a piece of plywood that will be glued into slots cut in the aprons....
I don't think that the stiffening shown is nearly as effective as a traditional corner brace. A mortise is weakest when it is stressed by a rotation of the leg about the length of the skirt, for example pushing the table across the floor (dismissing table dancing for the time being). I think a traditional brace would be much more effective in resisting this motion for it will prevent any rotation of the leg about the skirt length.
The corner brace is a cheap 20th century method. They loosen up over time because they are only as strong as the tiny bit of tissue that holds the screws. The traditional deep mortise method holds up for centuries.
