Diamond sharpening - questions
Denis Chenard in Ottawa
Hello all,
I finally got myself a cast iron plate. I plan on using it for final honing only. Tools to be used on the plate will have a slight hollow grind (setup not completed yet for that).
Now I can get water-based or oil-based diamond paste, some in monocrystalline or polycrystalline form (although one often can't find through the product description). Is water-based paste bound to rust the CI surface, or is it not an issue?
I guess I have two other questions. First, I've seen listed paste down to 0.1 micron; I'd like to get as fine as possible even if it means more honing strokes, I want the best edge possible. Will this work with a standard Blanchard ground plate? Where's the best place to get the paste?
Second, in a recent thread, Wiley scared me off trying diamond on Japanese tools... I wouldn't use coarse on these tools, but would sub-micron diamonds damage the steel? I would think not, but I wouldn't mind some reassurance before I try my Imai sword steel chisels on such a setup...
TIA,
DC
