New WoodChat!
Dimensional Lumber for Furniture
Al R.
Howdy folks.
A while back I started to notice that some folks were using dimensional lumber from the big box stores as secondary woods in their furniture (primary wood for painted pieces). It made sense since you see a lot of quarter sawn pine on hte stacks of 2x 12''s. The most notable was Adam Cherubini.
My question is, how do you process this stuff down to a usefull thickness.(1.5 inch down to .75-1.0 inches)? Scrub plane or saw?
Any input based on personal experiences?
Thanks for your time/.
Al R.
Re: Dimensional Lumber for Furniture
Jack Guzman from Maine
Where I live the big box stores only carry pressure treated Southern yellow pine or KD spruce in 1.5" thicknesses.That stuff isn't much use in furniture. White pine is 3/4" and when I do buy it to use in a project I use it as is. When I need to dimension my own I buy boards in the rough from local sawyers. Then I use either a scrub or a jack plane to bring the board down to flat. I use a power planer to get final thickness.---Jack
TomD
I run it through my planer, for flats, or resaw on the bandsaw depending on how the blade in question works.
Funny thing is once it get big enough and hard and heavy enough I can't move it to a machine. I built my first scrub when making an 8' maple bench.
With planes my personal pick is a scrub on the diagonal, followed by a jack, one sort of cleans the others tracks, on down the piece.
TomD
It is usually more expensive to buy HD lumber in my area than to get actual cabinet grade woods. I am not a business, but one does need to lick the lower rungs of that category to get some of the cheap deals.
Michael Donaldson
Michael Donaldson
It depends on how much you need to take off. If I have to remove 1/4" or less, I'll use the jack plane with cambered iron. If its more than that, its easier to use a saw and rip it close to final thickness and finish with a plane.
Al R
Thanks for the info. I usuAlly use white pine from the saw mill but last couple of trips through HD I saw some 2x12's that had some really tight growth rings and were quArter sawn.
Just wondered how others approach it. Thought maybe I needed to build a frame saw to help thickness it.
Thanks for the responses.
Al R
roger lance
Last year, I built a sharpening station and used some tight straight grained 2x4's for some of the internal structure of this shop piece....
and I keep some of it around the shop for jigs/wedges/etc.....but I would not recommend it for general use in furniture.....some people like to use this wood in building roubo style benches again for the shop.....there is some very soft wood between those growth rings.....theres reasons that some woods are construction grade material and other woods are used in furniture.....get some next time you see an impressive board and experiment with it to satisfy your curiosity.
TomD
Wood is wood, I don't discount unconventional sources, sometimes you can get some great stuff at the HD.
Sometimes you can find useful framing lumber. For example I built a window sash out of some particularly suitable fir 2x12s. Either side of the center was nice quartersawn material. No knots at all throughout the board. However, it was in the same pile as a knotty piece of spruce.It depends on what the lumberyard gets in that particular load. ---Jack
Patrick Gibbons
I'm lucky enough to have a Borg near me that sells SYP stair treads in 5/4" x 12" x 72" that has a lot of quartersawn grain. I've made a lot of pieces out of it. Sorry about the poor quality of the included picture.
