We value your privacy.
Two of my four walls are poured concrete. I would like to put up some french cleats and hang some shelves for tool storage. I know about tapcon bits and screws.
I would attach triangular braces to the ends of the shelves to help support weight. What are reasonable
limits? I am thinking about a shelf for 8 pairs of h and r s, a rack to hang some braces and bits, etc. Anybody who has done this willing to give some advice?
Ron....I'm also in a basement shop with poured walls and I've used tapcon screws to attach various equipment holding devices. The structure holding the most weight is probably my clamp storage rack which is just a 3/4" plywood frame that is tapcon screwed to the concrete wall with pegboard on top....there are a lot of clamps on that rack and no issues so far....
also a similar set up for jigs which was built the same way.....
you should have no problem with what you are proposing.....get a hammer drill and go to town....
If you're renting, spend the little bit extra to get a rotary hammer, which will beat you up less than will a hammer drill. The difference is that the bits on a rotary hammer are loosely held, in the direction of the drill's movement, so that they can bounce. A hammer drill is like a regular drill that hammers on the end of the bit, and YOU do the bouncing.
Bondo is an excelent adhesive for gluing wood to concrete or masonry. Clean the area with a bit of acetone and only use dry wood and you will be amazed at its holding power.
I recently went on a mission trip and used a half horse corded drill and tapcon bit to put screws in a concrete floor and it worked great. Will that not work on my walls.
Regular drills will work in many cases. A lot depends on the mix and the age of the concrete. Stronger mixes and older concrete will test your drill and your patience. A lot also depends on how many anchors you're installing. Two is one thing; two dozen is another. When I screwed down some treated plywood to serve as the base for a floor in our little cottage out back (on a slab), I was putting in tapcons every six inches at the edges, every foot in the field of the plywood. Probably could have done it with a regular drill, but I might still be out there, drilling holes.
Give it a try; if it's too slow, consider renting a rotary hammer.
There's also the time/money tradeoff. If you have the money to rent a specific tool, it will save you time; if you don't, you just have to find the time.
My basement workshop has cinder block walls. What I did was to use Redhead anchors to attach 2x4's flat against the wall at 16" intervals, with the bottom of each 2x4 resting on pressure treated 2x4's that I laid on the ground up against the wall. I then screwed pine 1x12's to the 2x4's. All my tool storage and shelves then gets screwed to the pine boards.
This was definitely overkill, but I'm glad I did it. The pine boards look a lot nicer than the cinder block, and I have complete flexibility in rearranging my tool storage. Attaching French cleats directly to the walls would be just as good, but if I wanted to move things around, it would be a bit of a hassle.
Whatever you decide, get a hammer drill or a rotary hammer, and buy real masonry bits.
